Calculating Plating/Coating Weight for IMDS
tomvehoski
Hello everyone. Have not been around here much lately...
I've run into a technical curiosity from my company's history that I though someone here might know about. I am now in the world of fastener manufacturing - primarily nuts and bolts - and we are required to submit to IMDS.
For calculating the weight of plating and coatings, most of our plants use Surface Area X Thickness X Density. At some point in the past, well before my time, we also published an internal IMDS guide along with training slides that used the following formulas:
Coating Weight of:
Bolt = .005 x Part Weight
Washer = .003 x Part Weight
Patch (Loctite, etc.) weight = .25 X Plating Weight
Using a fudge factor such as these is easier than calculating surface area, but I can't justify using them without knowing where the numbers came from - especially with the varying thicknesses and densities of coatings we use. Most of the documentation I have seen comes out of IMDS information, so I get the feeling these may have been generally accepted factors. It could also be someone pulled them out of thin air. The usage goes back at least eight years.
Has anyone seen factors like this used in the past and know of their source?
Coating Weight of:
If you have a reliable scale, weigh 100 or so pieces (all at once) before and after coating. That should give you a reasonably accurate and empirical idea. If you do it with enough different items, you should be able to develop a reliable formula to use.
Ron Rompen
I have seen 'fudge factors' used in the past, particularly in the early days of IMDS, when it wasn't well understood by the people who were forced to come into immediate compliance with it. The thought process then seemed to be 'better close than nothing at all'.
In my personal experience, I have always done my best to accurately report the correct mass of all my coatings; not always an easy task, but cutting corners just isn't the right way to do things.
Kimmy
I always weigh parts before and after plating but since most of our pieces come back from the plater weighing the same or less than they did before the plating, I wait until after they are plated to get a weight and then remove the plating with dilute hydrochloric acid aka muriatic acid for the before weight.
C Calculating the Lead (Pb) ppm from the Plating Layer RoHS, REACH, ELV, IMDS and Restricted Substances 6
M Lean: Conducting Capacity Study, calculating Cycle times on laser cutting machines Lean in Manufacturing and Service Industries 2
A Calculating Carbon Footprint in the Organization Miscellaneous Environmental Standards and EMS Related Discussions 2
C Calculating your KPIs ISO 13485:2016 - Medical Device Quality Management Systems 7
K Calculating Heat Dissipation Manufacturing and Related Processes 1
Q Calculating Defect Rates ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
S Formula for Calculating NoGo Major Diameter for UN gages Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
P Calculating a weight for a machine for the CE label CE Marking (Conformité Européene) / CB Scheme 0
R Remote Support - Calculating Number of Employees IATF 16949 - Automotive Quality Systems Standard 2
G Calculating Tolerance of a Panel Meter with a 2 degrees of an Arc General Measurement Device and Calibration Topics 0
T Calculating LCL, UCL, Cp, and Cpk in an Excel Spreadsheet Statistical Analysis Tools, Techniques and SPC 3
V Product Development - When to start calculating Process Capability Capability, Accuracy and Stability - Processes, Machines, etc. 3
J Calculating Reliability for Subsystems in Series Reliability Analysis - Predictions, Testing and Standards 15
Stijloor Calculating (3rd Party) Audit Days for Company with Seasonal Employees General Auditing Discussions 3
T Formulas for Calculating Coefficients for RTD / PRTD Calibration According to ITS-90 General Measurement Device and Calibration Topics 5
J Calculating part variation from historic data for GRR study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
P Purpose of calculating Ta, Tb & R Square in Linearity Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
P Purpose of calculating Uncertainty value in calibration study Measurement Uncertainty (MU) 5
M Calculating MTBF for plug-in PCI cards Reliability Analysis - Predictions, Testing and Standards 2
J Calculating impact force, expressed in lbs, of a 5 lb weight dropped 48 inches Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
M Calculating Cpk when sample size equals to 1 Capability, Accuracy and Stability - Processes, Machines, etc. 12
D Calculating Cpk on Non-Normal Data Distribution Capability, Accuracy and Stability - Processes, Machines, etc. 10
K Calculating Capability of a process when data is skewed in the upper range Capability, Accuracy and Stability - Processes, Machines, etc. 4
A Calculating Accuracy for a Multimeter General Measurement Device and Calibration Topics 1
M Calculating Coefficients for an RTD (Resistance Temperature Detector) Probe General Measurement Device and Calibration Topics 3
D Calculating Lower and Upper 3 Sigma Control Limits Statistical Analysis Tools, Techniques and SPC 2
M Calculating Adequate Receiving Inspection Sample Size Statistical Analysis Tools, Techniques and SPC 2
M Calculating Capability of Delivery Performance Capability, Accuracy and Stability - Processes, Machines, etc. 5
K Advice on Calculating Control Chart Control Limits Statistical Analysis Tools, Techniques and SPC 13
B Calculating Combined DPMO and Sigma Level for Two or More Different Work Areas Six Sigma 3
G Calculating the Fraction Defective Confidence Interval for a Lot Statistical Analysis Tools, Techniques and SPC 2
A Calculating Combined Measurement Uncertainty - VDA 5 Measurement Uncertainty (MU) 1
B Calculating Precision to Tolerance Ratio Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
D DPPM - Calculating the Defect Rate of a Software Test Statistical Analysis Tools, Techniques and SPC 9
L FMEA - Calculating RPN = S*O*D FMEA and Control Plans 3
I Shewhart Constants vs Central Limit Theorem in calculating Control Limits Statistical Analysis Tools, Techniques and SPC 18
B Please share a template for calculating Cp Cpk Document Control Systems, Procedures, Forms and Templates 3
S Is a Stable Process (within Control Limits) required for Calculating Pp, Ppk? Capability, Accuracy and Stability - Processes, Machines, etc. 6
M Calculating the IATF TS 16949 Recertification Audit Man Days - Clarification ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
J IEC60825 - Laser Safety - Calculating Maximum Permissible Exposure Correctly Other ISO and International Standards and European Regulations 1
P Calculating Process Capability from Data of attached spreadsheet Statistical Analysis Tools, Techniques and SPC 4
I AQL Formula in Excel - Calculating Sample Size based on an AQL Chart AQL - Acceptable Quality Level 8
D Formula for Calculating Warp Measurement of Corrugated Boxes General Measurement Device and Calibration Topics 1
S Need Help Calculating and Implementing Cs - Wright's Index Statistical Analysis Tools, Techniques and SPC 11
S Calculating an Uncertainty Budget for an Optical Comparator General Measurement Device and Calibration Topics 4
D One-Two-Three Sigma Control Limits - Calculating Control Limits for X-bar Charts Statistical Analysis Tools, Techniques and SPC 3
K Calculating (Approximate) Parallelism Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
S Calculating MTBF (Mean Time Between Failures) for the whole Production Unit Reliability Analysis - Predictions, Testing and Standards 2
J Need help calculating actual Ppk - Result of % GR&R=11.8% when conducting MSA Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
M Calculating Cp and Cpk - Is my calculation correct? Capability, Accuracy and Stability - Processes, Machines, etc. 7
