Calculating the IATF TS 16949 Recertification Audit Man Days - Clarification
martin.valdes
Hi All; I just was transfered to the quality systems area in the same company, a contract manufacturing company we have the ISO/TS 16949 certification, this year our certificate will expire that's why I am trying to calculate the recertification audit man days, I have on hand the Rules for achieving IATF recognition and the IAF MD5-2009 -QMS-EMS for consult but I can not understand the second part statement into the IAF MD5 section 6 paragraph 6.1, can someone clarify this for me? is the 2/3 applicable for a recertification process or not?. appreciate your help
Jen Kirley
Quality and Auditing Expert
Hi Martin,
I am afraid I do not understand your question fully.
Are you a single site or will there be multiple sites?
How many employees at each site?
How many shifts at each site?
Are there design activities at the site?
Are any functions split off to other sites, such as design or warehousing?
Are there nonconformances from last year to review?
Given answers to these criteria, your CB can give you a manday estimate. Have you asked them?
Howard Atkins
Forum Administrator
IAF and their mandatory documents have no connection to TS certification or the IATF
TS only works according to the TS rules and the only accreditation body is IATF.
The CBs are audited to the rules and not to ISO 17021 for TS certifications so the mandays are only according to the rules 5.2
martin.valdes
Thanks to all;
Hi Jennifer,
We have a corporate scheme, with 1 manufacturing site in Mexico with 875 employees (this site is ISO/TS), in US have manufacturing site with 166 employees, (this site is only ISO and support for Mexico ops), a warehouse site with 47 employees (support for Mexico ops) and purchasing offices with 10 employees (support for both Mexico and US Ops). there are no nonconformities and we have design excluded from our scope scheme.
Thanks for your help and support
martin.valdes
Hi
the question still there regarding to the 2/3 is or not applicable the complete IAF text is as follow:
6 RECERTIFICATION
6.1 The duration of the recertification audit should be calculated on the basis of the updated
information of the client and is normally approximately 2/3 of the time that would be required for
an initial certification audit (Stage 1 + Stage 2) of the organization if such an initial audit were to
be carried out at the time of recertification (i.e. not 2/3 of the original initial certification audit
duration). The audit duration shall take account the outcome of the review of system performance
The first part of the text is understable but for me the second part is a little bit confuse.:confused:
Randy Lefferts
I am not entirely sure I understand what you are asking but will give a go as if I did :)
Let's say your initial certification would require 6 mandays of auditing. After you have the certification audit performed (6 mandays) you will then have periodic recertification audits. The recertification audits would take 4 mandays (2/3*6 mandays), assuming your employee count didn't change from the initial audit. However, we are using the initial certification of mandays to determine this as if nothing has changed (and it may not have.)
The 2nd part is saying that when it comes time to recertify, you need to recalculate what it would take (regarding mandays) to audit based on the current state of the company, not what it was when you initially certified. So you would look at your number of employees, locations and determine how many mandays it would take for an intial certification, THEN take 2/3's of that and that would be the mandays needed for the recertification audit.
While it might not make sense to those whose situations (employees remain the same, locations remains the same) think of the situation where a company goes through a downsizing of employees. The current number of employees might result in a lower number of mandays needed to audit. (Same could be said of a location increasing their number of employees, thus resulting in additional manday(s) needed to audit.)
If I have misunderstood, disregard my post :)
martin.valdes
Thanks to all;
I already agreed with our Registrar the audit man days based on the ISO/TS rules table 5.2 and using the annex 2 example 6.
thanx:
A Calculating Risk Estimation ISO 14971 - Medical Device Risk Management 29
G Calculating Ppk for Design Verification - Variable Sampling Design and Development of Products and Processes 15
S Help needed in choosing the method of calculating the minimum sample size Internal Auditing 12
M True position, calculating theoretical distances General Measurement Device and Calibration Topics 0
M Lean: Conducting Capacity Study, calculating Cycle times on laser cutting machines Lean in Manufacturing and Service Industries 2
A Calculating Carbon Footprint in the Organization Miscellaneous Environmental Standards and EMS Related Discussions 2
C Calculating your KPIs ISO 13485:2016 - Medical Device Quality Management Systems 7
K Calculating Heat Dissipation Manufacturing and Related Processes 1
Q Calculating Defect Rates ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
S Formula for Calculating NoGo Major Diameter for UN gages Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
P Calculating a weight for a machine for the CE label CE Marking (Conformité Européene) / CB Scheme 0
R Remote Support - Calculating Number of Employees IATF 16949 - Automotive Quality Systems Standard 2
G Calculating Tolerance of a Panel Meter with a 2 degrees of an Arc General Measurement Device and Calibration Topics 0
T Calculating LCL, UCL, Cp, and Cpk in an Excel Spreadsheet Statistical Analysis Tools, Techniques and SPC 3
V Product Development - When to start calculating Process Capability Capability, Accuracy and Stability - Processes, Machines, etc. 3
J Calculating Reliability for Subsystems in Series Reliability Analysis - Predictions, Testing and Standards 15
Stijloor Calculating (3rd Party) Audit Days for Company with Seasonal Employees General Auditing Discussions 3
T Formulas for Calculating Coefficients for RTD / PRTD Calibration According to ITS-90 General Measurement Device and Calibration Topics 5
J Calculating part variation from historic data for GRR study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
P Purpose of calculating Ta, Tb & R Square in Linearity Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
P Purpose of calculating Uncertainty value in calibration study Measurement Uncertainty (MU) 5
M Calculating MTBF for plug-in PCI cards Reliability Analysis - Predictions, Testing and Standards 2
J Calculating impact force, expressed in lbs, of a 5 lb weight dropped 48 inches Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
M Calculating Cpk when sample size equals to 1 Capability, Accuracy and Stability - Processes, Machines, etc. 12
D Calculating Cpk on Non-Normal Data Distribution Capability, Accuracy and Stability - Processes, Machines, etc. 10
K Calculating Capability of a process when data is skewed in the upper range Capability, Accuracy and Stability - Processes, Machines, etc. 4
A Calculating Accuracy for a Multimeter General Measurement Device and Calibration Topics 1
M Calculating Coefficients for an RTD (Resistance Temperature Detector) Probe General Measurement Device and Calibration Topics 3
T Calculating Plating/Coating Weight for IMDS RoHS, REACH, ELV, IMDS and Restricted Substances 3
D Calculating Lower and Upper 3 Sigma Control Limits Statistical Analysis Tools, Techniques and SPC 2
M Calculating Adequate Receiving Inspection Sample Size Statistical Analysis Tools, Techniques and SPC 2
M Calculating Capability of Delivery Performance Capability, Accuracy and Stability - Processes, Machines, etc. 5
K Advice on Calculating Control Chart Control Limits Statistical Analysis Tools, Techniques and SPC 13
B Calculating Combined DPMO and Sigma Level for Two or More Different Work Areas Six Sigma 3
G Calculating the Fraction Defective Confidence Interval for a Lot Statistical Analysis Tools, Techniques and SPC 2
A Calculating Combined Measurement Uncertainty - VDA 5 Measurement Uncertainty (MU) 1
B Calculating Precision to Tolerance Ratio Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
D DPPM - Calculating the Defect Rate of a Software Test Statistical Analysis Tools, Techniques and SPC 9
L FMEA - Calculating RPN = S*O*D FMEA and Control Plans 3
I Shewhart Constants vs Central Limit Theorem in calculating Control Limits Statistical Analysis Tools, Techniques and SPC 18
B Please share a template for calculating Cp Cpk Document Control Systems, Procedures, Forms and Templates 3
S Is a Stable Process (within Control Limits) required for Calculating Pp, Ppk? Capability, Accuracy and Stability - Processes, Machines, etc. 6
J IEC60825 - Laser Safety - Calculating Maximum Permissible Exposure Correctly Other ISO and International Standards and European Regulations 1
P Calculating Process Capability from Data of attached spreadsheet Statistical Analysis Tools, Techniques and SPC 4
I AQL Formula in Excel - Calculating Sample Size based on an AQL Chart AQL - Acceptable Quality Level 8
D Formula for Calculating Warp Measurement of Corrugated Boxes General Measurement Device and Calibration Topics 1
S Need Help Calculating and Implementing Cs - Wright's Index Statistical Analysis Tools, Techniques and SPC 11
S Calculating an Uncertainty Budget for an Optical Comparator General Measurement Device and Calibration Topics 4
D One-Two-Three Sigma Control Limits - Calculating Control Limits for X-bar Charts Statistical Analysis Tools, Techniques and SPC 3
K Calculating (Approximate) Parallelism Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
