Calculation of the Mean - Student Question about Cpk calculation
jal8712
Ok so i was given this question. I just am getting lost cause it doesnt say a mean. Does this mean i have to calculate the mean
Elle Tire Company recently bought a new compressor which automatically fills automotive tires to specified pressure. It was specified by the compressor manufacturer that standard deviation for the fillings was 2 PSI. For getting best fuel economy, it is suggested the tire pressures should be set in the range 30 to 35 PSI. Since under inflation is lot more undesirable than over inflation, the manager set the compressor to fill the tires at 33.5 PSI. Answer the following questions-
What is the process capability of the system for filling tires?
so what i did is take
33.5-30/3*2 or 35-33.5/3*2
.5833 or .25
to get these values. Am i doing this right?
Or do i have to find the mean and use the 30 and 35 number than divide by 2?
i am assuming the lsl=30 and usl=35?
most problems we are given had like 10+-3 so we could identity the lsl and usl by that. and the mean was always given to us
Re: question about cpk
Do you just want to see whether this compressor is capable or not? Under the best case, that you are centered within the specification at 32.5, you can calculate the Cp index as (USL - LSL)/6s, that would be (35 - 30)/6*2, 0r 5/12 = 0.417. Since the compressor is set higher, at 33.5 you should calculate Cpk upper, which is (35 - 33.5)/3*2, or 1.5/6 = 0.25.
So, the compressor is far from capable. Even centered within the spec, it will still produce many tires that are both over and under inflated. Currently, it will produce more over-inflated tires.
JasonAREdwards
I agree with your math assuming that 33.5 is the mean.
However, just because the manager sets the machine to 33.5 pounds does not necessarily result in 33.5 as the process mean. It appears that you do not have enough information to answer the question.
jal8712
ok im so lost. Do we not need to get mean for this? So we can just assume 33.5 is the mean? we are using lower to? so would the lower be 33.5-30/3*2? since we dont need lower you just left it out right?
jal8712
my teacher gave us this question and its just confusing. Every other time he has supplied the mean and all that.there is this formula as well. xi/n
where xi=observed value and n=total number of observed values. But i didnt think we would use this formula
Miner's answer is correct and complete.
to address your explicit and unstated questions: you cannot calculate the mean in this exercise as you don't have the individual values, but for this exercise you don't need it. you simply assume that the mean will be where the compressor is set (33.5). in real life of course this probably won't be the actual mean - but this is just an exercise. you also have to assume that the vendors claim of the SD is correct, which won't be correct in real life either. but these assumptions are OK for the exercise if only because you don't have any other data.
as for Cpk_lower, you could of course calculate it in the same manner as Miner did, but traditionally, Cpk is only calculated and reported for the value that comes form the closest spec limit. IF you were taught to also use or report the other Cpk then do so...the math is straightforward.
remember that sometimes questions are 'tricky'. the instructor or author intends them to be that way to get you to THINK.
R Calculation Mean for Control Chart -X Double Bar Statistical Analysis Tools, Techniques and SPC 13
K MTBF (Mean Time Between Failures) Calculation Reliability Analysis - Predictions, Testing and Standards 4
Sidney Vianna IATF 16949 News Risked Based Audit Day Calculation IATF 16949 - Automotive Quality Systems Standard 2
L Uncertainty calculation for an average Measurement Uncertainty (MU) 1
L Scrap % calculation for a year. Manufacturing and Related Processes 3
T Question for: Cg & Cgk calculation General Measurement Device and Calibration Topics 3
E 21 CFR 211.103 Calculation of Yield Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 5
S Cost of Poor Quality (CoPQ) - Scrap element of calculation includes lost margin? Misc. Quality Assurance and Business Systems Related Topics 7
K Analysis variation among the lots during cpk calculation. Design and Development of Products and Processes 1
0 PPM calculation of customer complaints for PMS Customer Complaints 10
T Overvoltages consideration in Applied Part for RMS Calculation. IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
U Cpk Calculation - I analyse a double seam cans Manufacturing and Related Processes 15
I Lifetime Support Calculation - Thermal Operating Profile Reliability Analysis - Predictions, Testing and Standards 7
qualprod Stock Reorder point calculation Lean in Manufacturing and Service Industries 1
G 3 Operator Std. Dev. and uncertainty calculation Measurement Uncertainty (MU) 2
F Determining what type of scrap to include in my internal PPM calculation Quality Manager and Management Related Issues 5
F Holes position inspection - Calculation of centre distance and plug sizes of a gauge Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
P Any official doc/spec on different types of Yield calculation? Manufacturing and Related Processes 0
M Benchmarking Process Data - Man-day calculation gone wrong Benchmarking 5
H Taguchi mixed model DoE [L16 (4^3 2^6): factors interaction and ANOVA calculation Using Minitab Software 3
L P-Chart Control Limit Calculation help Statistical Analysis Tools, Techniques and SPC 1
H Sample Size Calculation (Confidence Interval and Reliability) - Medical Devices Reliability Analysis - Predictions, Testing and Standards 6
E Questions regarding Cpk Calculation - Should we be using LSL/USL or LCL/UCL? Capability, Accuracy and Stability - Processes, Machines, etc. 5
L Number of Distinct Categories" or NDC Calculation in MSA Studies Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
V Sample Size Calculation for Image Analysis - Microscopy Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
Q Rule 5.2h - Site Separation - Audit Manday Calculation (IATF 16949) IATF 16949 - Automotive Quality Systems Standard 17
kedarg6500 Gage R&R - Is my sheet calculation wrong? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 21
C Practical use of Heat Input calculation for Manual MIG Welding Manufacturing and Related Processes 4
J CMM Uncertainty Calculation Question - Deviations Measurement Uncertainty (MU) 9
S Scrap % Calculation Formula Manufacturing and Related Processes 10
T Reliability calculation for repairable system Reliability Analysis - Predictions, Testing and Standards 14
F Calculation of reduction on audit time - IAF MD1:2007, IAF MD5:2015 and IAF MD11:2013 General Auditing Discussions 1
M Is there a calculation in Net Promoter Score (NPS) ? Statistical Analysis Tools, Techniques and SPC 3
bobdoering Unilateral Tolerance Capability Calculation Imported Legacy Blogs 0
M Help with uncertainty calculation in the calibration of a Pyrogen Test Processor Measurement Uncertainty (MU) 7
H ROI (Return on Investment) Calculation of Employees ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Q PPM - Filtering Defects out of calculation Quality Tools, Improvement and Analysis 5
J Calculation of σ within subgroups for Cpk in Minitab Using Minitab Software 1
E How does Non-Linear UUT affect TAR (Test Accuracy Ratio) Calculation? Measurement Uncertainty (MU) 3
O Takt Time Calculation for Long Runner Product Lean in Manufacturing and Service Industries 5
M Packaging Material Requirement Calculation Sheet for a Bottle Packaging Line Manufacturing and Related Processes 3
B Histogram beginner dilemma - Manual Calculation vs. JMP 7 Quality Tools, Improvement and Analysis 12
S SPC Control Limit Calculation Statistical Analysis Tools, Techniques and SPC 2
N Procedure/calculation for determining the foot pressure of dial thickness gauge General Measurement Device and Calibration Topics 11
T Calculation Question - Calculate the runner weight for a part Manufacturing and Related Processes 2
A Accuracy Calculation of Leakage Current for an Electrical Safety Analyzer General Measurement Device and Calibration Topics 5
E Composite Position Calculation on a 12 X 4 Hole Pattern Inspection, Prints (Drawings), Testing, Sampling and Related Topics 13
M Sigma Calculation in Excel Capability, Accuracy and Stability - Processes, Machines, etc. 3
H Uncertainty Measurement Calculation in Chemical Testing Measurement Uncertainty (MU) 1
V How to use a Calibration Certificate in Uncertainty Calculation for a Test Measure Measurement Uncertainty (MU) 13
