Calculation of Upper and Lower Control Limits for Control Chart?
samsung
Can anyone please let me know if the upper and lower control limits calculated in the attached sheet are OK and under what circumstances these formulae are applicable?
So far I knew that these limits are Avg +/- 3 sigma. The attached template is from Microsoft.
Your inputs are appreciated.
Steve Prevette
Deming Disciple
What it appears is being done is that the data are organized into subgroups of 5. The statistical standard deviation of each subgroup is being calculated, then a grand average of the subgroup standard deviations is calculated. So far, unconventional but might not be too bad. Then that average standard deviation is added and subtracted from the grand average. I don't see a calculation of 3 standard deviations, though you'd have to divide that by the square root of 5, so someone may have figured that was close enough.
Especially if you are just starting in SPC, I would not support using this spreadsheet. Generally, the traditional method is to go with "xbar-R", and that includes two charts - a range chart (which must be in control first) and then a xbar chart.
samsung
Infact I wish to apply SPC to the data given in the attached sheet. The measurements are taken daily on the average sample (composite day sample). Based on the attached data what would be the most appropriate type of chart that I should be using. Could you also refer a good excel template for the type of chart I'm looking for.
I'm in the process of procuring QI Macros but before it's delivered, I want to learn the basics of SPC.
Thanks.
bobdoering
Stop X-bar/R Madness!!
It appears to me with a quick look at the data that X-MR is probably a good place to start. BUT....I will emphasize that there needs to be documentation of any changes in the process - start up, raw materials, operator, etc. Also, a confidence that you measurement system is adequate. I see some variation that might be explained by these types of things - which is OK...if you have the documentation to verify it. The control chart does not show an issue, but the distribution does.
It is a handy tool! I use it and Distribution Analyzer a lot for these evaluations
samsung
Thanks Bob for a quick analysis. I agree there must be some documentation of changes in man, machine, material, method etc. The variation appears to be somewhat high and there's scope for minimizing it through control on inputs.
As suggested, I'll start with X-MR.
samsung
Hi Bob,
One thing I would like to know is why you have calculated ppk instead of cpk in the above post. Is ppk a better indicator in this case and what is the optimum level where it should be maintained? 1.33 or so?
bobdoering
That is the software's preference - it defaults to ppk, which is also preferred for many non-normal distributions. Some customers are also shifting from their preference of Cpk to Ppk. As far as what should be maintained - generally customers look for between 1.33 and 1.67 as a minimum. BUT - that depends on whether going to 1.66 is simply an adjustment of the mean, and improvement of the process (both of which are OK) or more frequent adjustment (or, over-adjustment, if you will, which is a bad thing because the adjustment becomes the process).
T Upper and Lower Limit Calculation with Capability Formula - Product Weight Capability, Accuracy and Stability - Processes, Machines, etc. 12
E 21 CFR 211.103 Calculation of Yield Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 5
S Cost of Poor Quality (CoPQ) - Scrap element of calculation includes lost margin? Misc. Quality Assurance and Business Systems Related Topics 7
K Analysis variation among the lots during cpk calculation. Design and Development of Products and Processes 1
0 PPM calculation of customer complaints for PMS Customer Complaints 10
T Overvoltages consideration in Applied Part for RMS Calculation. IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
U Cpk Calculation - I analyse a double seam cans Manufacturing and Related Processes 15
I Lifetime Support Calculation - Thermal Operating Profile Reliability Analysis - Predictions, Testing and Standards 7
Q Stock Reorder point calculation Lean in Manufacturing and Service Industries 1
G 3 Operator Std. Dev. and uncertainty calculation Measurement Uncertainty (MU) 2
F Determining what type of scrap to include in my internal PPM calculation Quality Manager and Management Related Issues 5
F Holes position inspection - Calculation of centre distance and plug sizes of a gauge Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
P Any official doc/spec on different types of Yield calculation? Manufacturing and Related Processes 0
M Benchmarking Process Data - Man-day calculation gone wrong Benchmarking 5
H Taguchi mixed model DoE [L16 (4^3 2^6): factors interaction and ANOVA calculation Using Minitab Software 3
L P-Chart Control Limit Calculation help Statistical Analysis Tools, Techniques and SPC 1
H Sample Size Calculation (Confidence Interval and Reliability) - Medical Devices Reliability Analysis - Predictions, Testing and Standards 6
E Questions regarding Cpk Calculation - Should we be using LSL/USL or LCL/UCL? Capability, Accuracy and Stability - Processes, Machines, etc. 5
L Number of Distinct Categories" or NDC Calculation in MSA Studies Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
V Sample Size Calculation for Image Analysis - Microscopy Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
Q Rule 5.2h - Site Separation - Audit Manday Calculation (IATF 16949) IATF 16949 - Automotive Quality Systems Standard 17
kedarg6500 Gage R&R - Is my sheet calculation wrong? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 21
C Practical use of Heat Input calculation for Manual MIG Welding Manufacturing and Related Processes 4
J CMM Uncertainty Calculation Question - Deviations Measurement Uncertainty (MU) 9
S Scrap % Calculation Formula Manufacturing and Related Processes 10
T Reliability calculation for repairable system Reliability Analysis - Predictions, Testing and Standards 14
F Calculation of reduction on audit time - IAF MD1:2007, IAF MD5:2015 and IAF MD11:2013 General Auditing Discussions 1
Mikael Is there a calculation in Net Promoter Score (NPS) ? Statistical Analysis Tools, Techniques and SPC 3
bobdoering Unilateral Tolerance Capability Calculation Imported Legacy Blogs 0
M Help with uncertainty calculation in the calibration of a Pyrogen Test Processor Measurement Uncertainty (MU) 7
H ROI (Return on Investment) Calculation of Employees ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Q PPM - Filtering Defects out of calculation Quality Tools, Improvement and Analysis 5
J Calculation of σ within subgroups for Cpk in Minitab Using Minitab Software 1
E How does Non-Linear UUT affect TAR (Test Accuracy Ratio) Calculation? Measurement Uncertainty (MU) 3
O Takt Time Calculation for Long Runner Product Lean in Manufacturing and Service Industries 5
M Packaging Material Requirement Calculation Sheet for a Bottle Packaging Line Manufacturing and Related Processes 3
B Histogram beginner dilemma - Manual Calculation vs. JMP 7 Quality Tools, Improvement and Analysis 12
S SPC Control Limit Calculation Statistical Analysis Tools, Techniques and SPC 2
N Procedure/calculation for determining the foot pressure of dial thickness gauge General Measurement Device and Calibration Topics 10
T Calculation Question - Calculate the runner weight for a part Manufacturing and Related Processes 2
A Accuracy Calculation of Leakage Current for an Electrical Safety Analyzer General Measurement Device and Calibration Topics 5
E Composite Position Calculation on a 12 X 4 Hole Pattern Inspection, Prints (Drawings), Testing, Sampling and Related Topics 13
M Sigma Calculation in Excel Capability, Accuracy and Stability - Processes, Machines, etc. 3
H Uncertainty Measurement Calculation in Chemical Testing Measurement Uncertainty (MU) 1
V How to use a Calibration Certificate in Uncertainty Calculation for a Test Measure Measurement Uncertainty (MU) 13
D Siemens MES software DPMO Calculation Six Sigma 4
N Uncertainty calculation for a voltage measurement Measurement Uncertainty (MU) 3
T Calculation of Unified Thread Limits - Non-standard thread 1 ? 36 UNS-2A Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
0 Calculation of Contamination Reduction Efficiency Statistical Analysis Tools, Techniques and SPC 4
E RSD (Relative Standard Deviation) Calculation for two series of numbers Statistical Analysis Tools, Techniques and SPC 4
