Calibrating a Template Gage
L
Lab Geezer
This is just my second post after lurking for quite some time but my question is this. We are a precision forging and machining operation of drivetrain components for the heavy truck industries and in our forging operation we use a considerable number of templete gages to "hot" check the form on drivr pinion and spindle forgings and I am concerned about our method of calibrating these template gages. We make them from the print on a wire EDM and at this time we verify them to the print on a optical comparator. This has past muster in the past but we are working on TS 16949 certification and I am not sure if this will satisfy the auditor.
Any comments and suggestions would be greatly appericated. The basic use of the gage is to insure enough stock for machining and the forged blank has a tolerance of +.060 / -.030 in most cases. I have about 200 of these in my gage system so it can be time consuming to calibrate them. I also have them on a 2 year cycle as wear has never been a problem.
Thanks in advance for your help:confused:
Stijloor
This is just my second post after lurking for quite some time but my question is this. We are a precision forging and machining operation of drive train components for the heavy truck industries and in our forging operation we use a considerable number of template gages to "hot" check the form on driver pinion and spindle forgings and I am concerned about our method of calibrating these template gages. We make them from the print on a wire EDM and at this time we verify them to the print on a optical comparator. This has past muster in the past but we are working on TS 16949 certification and I am not sure if this will satisfy the auditor.
Any comments and suggestions would be greatly appreciated. The basic use of the gage is to insure enough stock for machining and the forged blank has a tolerance of +.060 / -.030 in most cases. I have about 200 of these in my gage system so it can be time consuming to calibrate them. I also have them on a 2 year cycle as wear has never been a problem.
Here is a post from our Friend Jim Wynne that may help you.
Stijloor.
E
erbearica
I verify all templates/mylars but do not enter them in our calibration system. We replace as needed.
bobdoering
Stop X-bar/R Madness!!
Verification is good, but they should be in the gage system to track when they were verified, how, when is next due date, and link to a print if they need to be remade.
I place a 1" X 1" box on the template to very the polyester is still stable using a gage block, check a couple lines on the comparator, check readability and cleanliness and let them go.
Stijloor.
As bobdoering has pointed out, while actual calibration might not be required, the things still need to be included in the gage control system, and requirements for use/replacement/refurbishment should be documented.
Before anyone decides that calibration for a given item isn't necessary, you must be prepared to justify the decision on the basis that calibration isn't required to ensure valid results, which is the criterion given in the standard(s).
JaxQC
Just for an example, overlays used to pass / reject product, are calibrated. This is done by having (3) targets (crosshatch) on the master Cam template. Picture “L” shaped made up of the three targets. To calibrate we measure both the “X” & “Y” directions or distance between the hatches. Quick and easy for what we do and hold max +/- .020”.
P
Patzer
Hi Guys,
I'm just looking at this issue from the outside and as far as I can see the following line in the original post is very important:
Basically the gauges you use are for an in process check and do not have an impact on the final quality of the parts. While there is a business risk i.e. parts are too big, therefore longer machining times etc., too, small, not possible to machine them, I presume that the finished parts will undergo further inspection, therefore reducing/removing the potential impact of errors in the gauges (and therefore the need to calibrate). The suggestion to verify is a very good one though..
My expertise is in pharma/med devices but I hope that this adds something to the topic.
Thanks,
Pat.
E
erbearica
As a company with 3700 active gages in our calibration system we consider templates/mylars visual aids. We have a procedure in place we follow for this. We have never had a problem during an audit.
F Calibrating Gagemaker Products General Measurement Device and Calibration Topics 1
S Calibrating our own equipment, can we? Micrometers to calibrate vernier calipers General Measurement Device and Calibration Topics 13
I Tool maintenance and calibration procedure - Calibrating tools/equipment AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
Crusader Interval for Self-Calibrating Measurement Device? Calibration Frequency (Interval) 15
A Calibrating a PRT sensor - Temperature Sensitivity Coefficient General Measurement Device and Calibration Topics 2
M Calibrating Digital Pressure Gages In-House General Measurement Device and Calibration Topics 10
F OEM has no procedure for calibrating their device General Measurement Device and Calibration Topics 4
B Problem Calibrating a Krautkramer DMS 2 Ultrasonic Thickness Meter Calibration Frequency (Interval) 2
J Calibrating an 80,000 psi Fluid Pressure Gauge General Measurement Device and Calibration Topics 6
S Calibrating Thermometer with Simulated Output Temperature from Fluke 5520A General Measurement Device and Calibration Topics 6
hogheavenfarm Is there a relatively inexpensive method of Calibrating our Torque Wrenches? General Measurement Device and Calibration Topics 7
L Calibrating Tool Makers Personal Tools General Measurement Device and Calibration Topics 9
P Exempt from Calibrating our Tape Measures and Micrometers ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 32
C Best Method for Calibrating Multimeters General Measurement Device and Calibration Topics 8
D How much Deviation is Acceptable when Calibrating a Hygrometer? General Measurement Device and Calibration Topics 3
K Calibrating Plain Tapered Bores at the Small End Diameter General Measurement Device and Calibration Topics 7
M Calibrating a Weight Scale in a Laboratory Calibration Frequency (Interval) 4
S Calibrating Panel Mounted Pressure Gauges located on Hydraulic Test Stands General Measurement Device and Calibration Topics 3
D Calibrating a Thermometer for use in Cold Rooms - ISO 9001 Clause 7.6 General Measurement Device and Calibration Topics 8
T Hands-On training on calibrating equipment General Measurement Device and Calibration Topics 2
L Calibrating Press Brakes, How to do? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
H Calibrating a Matheson Flowmeter-help appreciated General Measurement Device and Calibration Topics 2
Jerry Eldred Calibrating Mitutoyo SJ-201P Surface Roughness Testers General Measurement Device and Calibration Topics 4
S Calibrating a 1/8-27 NPT thread gage General Measurement Device and Calibration Topics 4
J Calibrating Electronic Equipment Tester Software - ISO 9001 Clause 7.6 Benchmarking 1
M Calibrating 1/2-20 UNF 2B STI Threaded Plug Gage General Measurement Device and Calibration Topics 3
A Calibrating 4" and larger Micrometers General Measurement Device and Calibration Topics 6
R Checking (Calibrating) Truncated Thread Set Plugs General Measurement Device and Calibration Topics 11
G Calibrating a reflectometer - Scale uncertainty with reading? Measurement Uncertainty (MU) 1
D Calibrating Lufkin ID Micrometer ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Z Calibrating Sunnen PG800 precision bore gage & PG700 setting fixtures General Measurement Device and Calibration Topics 1
C Gage pin calibration procedure for accurately calibrating gage pins General Measurement Device and Calibration Topics 18
Crusader Self-Calibrating Furnace does not require calibration General Measurement Device and Calibration Topics 15
B Using & Calibrating Ultrasonic Micrometer General Measurement Device and Calibration Topics 4
M Calibrating Angle Gage Blocks General Measurement Device and Calibration Topics 2
R Validation of A Procedure for Calibrating Dial Calipers using Traceable Gauge Blocks General Measurement Device and Calibration Topics 6
J Measurement Uncertainty for Calibrating Custom Check Fixtures with a Portable CMM Measurement Uncertainty (MU) 3
S Calibrating Biomed equipment in an ISO 17025 accredited calibration laboratory ISO 17025 related Discussions 5
T Calibrating or Verifying Metal or Steel Tape Measures General Measurement Device and Calibration Topics 195
T Calibrating the calibrator (torque test) - Electronic torque tester CDI 4001-0-ETT General Measurement Device and Calibration Topics 3
R Calibrating Leak Testers - Old fashioned water tank type tester General Measurement Device and Calibration Topics 2
P Calibrating Density Cups & Viscosity Cups In-House - Seeking Procedure / Help General Measurement Device and Calibration Topics 2
R Micrometer resolution for calibrating thread plug gages General Measurement Device and Calibration Topics 7
J Thread Wire Chart to use when Calibrating a particular size Thread Gage General Measurement Device and Calibration Topics 16
S Calibrating some of our equipment in house - Where do I start? General Measurement Device and Calibration Topics 19
