Calibrating Digital Pressure Gages In-House
Minda
Hello everyone! I have a question about calibrating digital single pressure gages in our facility. We have found a hand pump by Dwyer that will give us the pressure we need, but I am wondering about the gage that will be used as the "master". Can it have the same accuracy (?0.25% of full scale) as the gage that is being tested, or will I need to get a gage to use as the master with a better accuracy (?0.05% of full scale)?
We are planning to have the "master" sent out annually to be calibrated, and then do our in-house gages quarterly.
Thanks for the help!!~!
Jeff Frost
You might be better off purchasing a calibration system. But most calibration master gauges have an accuracy of ? of 1% full scale. Calibration fluid is nitrogen, (yes the gas is call a fluid in gauge calibration) usually using a calibration rig made up of a pressure regulator, master gauge and a volumetric controller.
Minda
I need to post links to the equipment we are considering but I cannot yet. Please excuse the multiple posts that I am about to make.
Minda
We have several pressure gages in house, and we are looking for a way to calibrate most of them ourselves to make a huge cost savings.
Minda
If we can find the right equipment, we can have one pressure gage and one vacuum gage calibrated annually, then check our internal gages on a quarterly basis.
Minda
This will allow us to do more check of the testing equipment, and save money and time in the long run.
Minda
We found our potential equipment on the Dwyer website, since we primarily use their brand of gages in our testing.
Minda
And the following post will finally detail our train of thought.
Once again, sorry for the multiple posts to get the post count up so I can do links.
Minda
If I am thinking correctly, we will be using a calibration system. Here is the setup we were thinking of.
The gages we use for our production testing are these in the 0.25% FS accuracy:
www.dwyer-inst.com/Product/Pressure/SinglePressure/Gages-Digital/SeriesDPG
The pump we found that we believe will work for calibration is this one:
www.dwyer-inst.com/Product/TestEquipment/CalibrationPumps/ModelHP
Using the proper tubes you connect the unit you are testing to one side, the calibrated master to the other, and then get the pressure from the pump that you are looking for and compare the two readouts.
The gage we looked at initial to use for calibration is this one:
www.dwyer-inst.com/Product/Pressure/SinglePressure/Gages-Digital/SeriesDCGII
But I am thinking we can use the regular DPG series just like we use for testing instead of the second option. I can get the DPG series we use in pressure and vacuum so that I can do both types in house, but the DCGII only comes in pressure, and is about $800 more expensive for a single unit.
Advice? Thanks!!
Performing a 1:1 calibration check is not recommended. At a minimum, a 4:1 ratio is recommended. Ratio's less than 4:1 can be "guardband" to compensate for ratio's less than 4:1.
If your gauge is 0-100 psi with a accuracy of ?0.25% of full scale, the accuracy of the gauge would be 0.25 psi. To maintain the 4:1 ratio, the standard needs to have a maximum error of 0.0625 psi (0.25/4).
R Calibrating Solid Thread Rings with HILO master General Measurement Device and Calibration Topics 1
Slo_Glenn Calibrating Clocks General Measurement Device and Calibration Topics 13
I Calibrating the monitoring device but not the unit General Measurement Device and Calibration Topics 7
F Calibrating Gagemaker Products General Measurement Device and Calibration Topics 1
S Calibrating our own equipment, can we? Micrometers to calibrate vernier calipers General Measurement Device and Calibration Topics 13
I Tool maintenance and calibration procedure - Calibrating tools/equipment AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
Crusader Interval for Self-Calibrating Measurement Device? Calibration Frequency (Interval) 15
A Calibrating a PRT sensor - Temperature Sensitivity Coefficient General Measurement Device and Calibration Topics 2
F OEM has no procedure for calibrating their device General Measurement Device and Calibration Topics 4
B Problem Calibrating a Krautkramer DMS 2 Ultrasonic Thickness Meter Calibration Frequency (Interval) 2
J Calibrating an 80,000 psi Fluid Pressure Gauge General Measurement Device and Calibration Topics 6
S Calibrating Thermometer with Simulated Output Temperature from Fluke 5520A General Measurement Device and Calibration Topics 6
hogheavenfarm Is there a relatively inexpensive method of Calibrating our Torque Wrenches? General Measurement Device and Calibration Topics 7
L Calibrating Tool Makers Personal Tools General Measurement Device and Calibration Topics 9
P Exempt from Calibrating our Tape Measures and Micrometers ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 32
L Calibrating a Template Gage General Measurement Device and Calibration Topics 7
C Best Method for Calibrating Multimeters General Measurement Device and Calibration Topics 8
D How much Deviation is Acceptable when Calibrating a Hygrometer? General Measurement Device and Calibration Topics 3
K Calibrating Plain Tapered Bores at the Small End Diameter General Measurement Device and Calibration Topics 7
M Calibrating a Weight Scale in a Laboratory Calibration Frequency (Interval) 4
S Calibrating Panel Mounted Pressure Gauges located on Hydraulic Test Stands General Measurement Device and Calibration Topics 3
D Calibrating a Thermometer for use in Cold Rooms - ISO 9001 Clause 7.6 General Measurement Device and Calibration Topics 8
T Hands-On training on calibrating equipment General Measurement Device and Calibration Topics 2
L Calibrating Press Brakes, How to do? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
H Calibrating a Matheson Flowmeter-help appreciated General Measurement Device and Calibration Topics 2
Jerry Eldred Calibrating Mitutoyo SJ-201P Surface Roughness Testers General Measurement Device and Calibration Topics 4
S Calibrating a 1/8-27 NPT thread gage General Measurement Device and Calibration Topics 4
J Calibrating Electronic Equipment Tester Software - ISO 9001 Clause 7.6 Benchmarking 1
M Calibrating 1/2-20 UNF 2B STI Threaded Plug Gage General Measurement Device and Calibration Topics 3
A Calibrating 4" and larger Micrometers General Measurement Device and Calibration Topics 6
R Checking (Calibrating) Truncated Thread Set Plugs General Measurement Device and Calibration Topics 11
G Calibrating a reflectometer - Scale uncertainty with reading? Measurement Uncertainty (MU) 1
D Calibrating Lufkin ID Micrometer ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Z Calibrating Sunnen PG800 precision bore gage & PG700 setting fixtures General Measurement Device and Calibration Topics 1
C Gage pin calibration procedure for accurately calibrating gage pins General Measurement Device and Calibration Topics 18
Crusader Self-Calibrating Furnace does not require calibration General Measurement Device and Calibration Topics 15
B Using & Calibrating Ultrasonic Micrometer General Measurement Device and Calibration Topics 4
M Calibrating Angle Gage Blocks General Measurement Device and Calibration Topics 2
R Validation of A Procedure for Calibrating Dial Calipers using Traceable Gauge Blocks General Measurement Device and Calibration Topics 6
J Measurement Uncertainty for Calibrating Custom Check Fixtures with a Portable CMM Measurement Uncertainty (MU) 3
S Calibrating Biomed equipment in an ISO 17025 accredited calibration laboratory ISO 17025 related Discussions 5
T Calibrating or Verifying Metal or Steel Tape Measures General Measurement Device and Calibration Topics 210
T Calibrating the calibrator (torque test) - Electronic torque tester CDI 4001-0-ETT General Measurement Device and Calibration Topics 3
R Calibrating Leak Testers - Old fashioned water tank type tester General Measurement Device and Calibration Topics 2
P Calibrating Density Cups & Viscosity Cups In-House - Seeking Procedure / Help General Measurement Device and Calibration Topics 2
