Calibrating or Verifying Metal or Steel Tape Measures
dwperron
I have seen a process where the tape measures are calibrated using another tape measure. All tape measures were of the same brand and length. One tape measure was kept as a "master" and sent out annually to an accredited lab. All other tape measures would be compared to this tape measure. Is this an acceptable method to calibrate tape measures? The part that I found questionable is that the master tape measure listed its tolerance as +/- 1/32". The tape measures calibrated using this master tape measure were also stated to be at +/- 1/32"
This depends on your definition of "acceptable".
You can compare a tape measure to a "master", it is done. In this case you would be accepting a measurement uncertainty that is larger than the tolerance of your tape measure, so that will determine if the calibration is "acceptable" to your requirements.
I have attached a NIST SOP that uses this method to calibrate a tape measure.
What if the Tape was not put to use say for 3 months after being bought along with Calibration certificate.Now when it should be calibrated? Is it one year from the Start date of Actual Usage or one year from the date of Calibration as mentioned in the certificate. Assume the tape was preserved well while in Storage. I have this issue in my organisation. how to answer the auditor reg this.thank u
Helmut Jilling
Auditor / Consultant
There is a very easy way to verify if a measuring tape is accurate - calibrate a 3 or 6 ft quality steel rule and verify your tape measures to the calibrated steel rule. There is measurement certainty with the steel rule.... if the tapes match the increments, then the tape is accurate as well. I have seen tape measures which were off by 1/8".... it can be a problem....
Jen Kirley
Quality and Auditing Expert
In addition to the consequence of wear and tear (the rivets holding the hook wear and elongate the holes, adding as much as 1/16 inch to the total length) I once purchased a tape measure that I was amazed to find significantly off: I mean almost 1/8 inch short in every 12 inches. It was a cheap model, I never see that in the name brand tape measures. I have often wished I'd kept that "black sheep" tape measure; it would make a good case study.
Jen Kirley
Setting up verification plans for measuring instruments is pretty consistent in the general rules:
  • Wear and tear in typical use (environment and handling by users)
  • Protection when not in use
  • The instrument's sensitivity or ruggedness
  • Amount of use that incurs wear in even best case scenarios
  • The tolerances you are expected to meet
  • The cost of getting it wrong
Tape measures are among the most underappreciated of measurement instruments. It would be easy to question the expense of purchasing a tape measure that comes with a calibration certificate, but as I described above, I once purchased a (cheap) tape measure that was significantly short. I mean almost 1/8 inch short in 0-12 inches, another (almost) 1/8 in 12-24 inches, etc. For a lot of applications, real accuracy seems unimportant but I once had a client that fabricated 10-foot-square catalytic converter units for coal and gas-fired power plants. If size and squareness was off by much, these products might not fit or their effectiveness could be impaired by escaped gases. We can't have that... so yes, it can sometimes really matter.
The only reasonable answer as to whether a tape measure needs to be calibrated is, "It depends." It's all about risk and choosing the right device for the task. If an error of 1/8" (.125) in ten feet can cause a significant problem, a tape measure isn't the right device.
EDIT: See this post from 11 years ago.
F Calibrating Gagemaker Products General Measurement Device and Calibration Topics 1
S Calibrating our own equipment, can we? Micrometers to calibrate vernier calipers General Measurement Device and Calibration Topics 13
I Tool maintenance and calibration procedure - Calibrating tools/equipment AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
Crusader Interval for Self-Calibrating Measurement Device? Calibration Frequency (Interval) 15
A Calibrating a PRT sensor - Temperature Sensitivity Coefficient General Measurement Device and Calibration Topics 2
M Calibrating Digital Pressure Gages In-House General Measurement Device and Calibration Topics 10
F OEM has no procedure for calibrating their device General Measurement Device and Calibration Topics 4
B Problem Calibrating a Krautkramer DMS 2 Ultrasonic Thickness Meter Calibration Frequency (Interval) 2
J Calibrating an 80,000 psi Fluid Pressure Gauge General Measurement Device and Calibration Topics 6
S Calibrating Thermometer with Simulated Output Temperature from Fluke 5520A General Measurement Device and Calibration Topics 6
hogheavenfarm Is there a relatively inexpensive method of Calibrating our Torque Wrenches? General Measurement Device and Calibration Topics 7
L Calibrating Tool Makers Personal Tools General Measurement Device and Calibration Topics 9
P Exempt from Calibrating our Tape Measures and Micrometers ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 32
L Calibrating a Template Gage General Measurement Device and Calibration Topics 7
C Best Method for Calibrating Multimeters General Measurement Device and Calibration Topics 8
D How much Deviation is Acceptable when Calibrating a Hygrometer? General Measurement Device and Calibration Topics 3
K Calibrating Plain Tapered Bores at the Small End Diameter General Measurement Device and Calibration Topics 7
M Calibrating a Weight Scale in a Laboratory Calibration Frequency (Interval) 4
S Calibrating Panel Mounted Pressure Gauges located on Hydraulic Test Stands General Measurement Device and Calibration Topics 3
D Calibrating a Thermometer for use in Cold Rooms - ISO 9001 Clause 7.6 General Measurement Device and Calibration Topics 8
T Hands-On training on calibrating equipment General Measurement Device and Calibration Topics 2
L Calibrating Press Brakes, How to do? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
H Calibrating a Matheson Flowmeter-help appreciated General Measurement Device and Calibration Topics 2
Jerry Eldred Calibrating Mitutoyo SJ-201P Surface Roughness Testers General Measurement Device and Calibration Topics 4
S Calibrating a 1/8-27 NPT thread gage General Measurement Device and Calibration Topics 4
J Calibrating Electronic Equipment Tester Software - ISO 9001 Clause 7.6 Benchmarking 1
M Calibrating 1/2-20 UNF 2B STI Threaded Plug Gage General Measurement Device and Calibration Topics 3
A Calibrating 4" and larger Micrometers General Measurement Device and Calibration Topics 6
R Checking (Calibrating) Truncated Thread Set Plugs General Measurement Device and Calibration Topics 11
G Calibrating a reflectometer - Scale uncertainty with reading? Measurement Uncertainty (MU) 1
D Calibrating Lufkin ID Micrometer ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Z Calibrating Sunnen PG800 precision bore gage & PG700 setting fixtures General Measurement Device and Calibration Topics 1
C Gage pin calibration procedure for accurately calibrating gage pins General Measurement Device and Calibration Topics 18
Crusader Self-Calibrating Furnace does not require calibration General Measurement Device and Calibration Topics 15
B Using & Calibrating Ultrasonic Micrometer General Measurement Device and Calibration Topics 4
M Calibrating Angle Gage Blocks General Measurement Device and Calibration Topics 2
R Validation of A Procedure for Calibrating Dial Calipers using Traceable Gauge Blocks General Measurement Device and Calibration Topics 6
J Measurement Uncertainty for Calibrating Custom Check Fixtures with a Portable CMM Measurement Uncertainty (MU) 3
S Calibrating Biomed equipment in an ISO 17025 accredited calibration laboratory ISO 17025 related Discussions 5
T Calibrating the calibrator (torque test) - Electronic torque tester CDI 4001-0-ETT General Measurement Device and Calibration Topics 3
R Calibrating Leak Testers - Old fashioned water tank type tester General Measurement Device and Calibration Topics 2
P Calibrating Density Cups & Viscosity Cups In-House - Seeking Procedure / Help General Measurement Device and Calibration Topics 2
R Micrometer resolution for calibrating thread plug gages General Measurement Device and Calibration Topics 7
J Thread Wire Chart to use when Calibrating a particular size Thread Gage General Measurement Device and Calibration Topics 16
S Calibrating some of our equipment in house - Where do I start? General Measurement Device and Calibration Topics 19
