Calibrating our own equipment, can we? Micrometers to calibrate vernier calipers
Stefanos Papadakis
The due date for calibrating our measuring tools is next month and my boss insists on postponing it, the reason for that is that we have a lot of work and we can't work without them. I am new to ISO 9001 and I would like to know if we can calibrate two or three micrometers through an external provider (ranging from 0-150) and then using the calibrated micrometers, calibrate our vernier calipers.
Thank you in advance!
Ron Rompen
How would you use the micrometers to calibrate your vernier calipers?
And it is not necessary to use a 3rd party to calibrate the micrometers. Purchase a calibration set of gauge blocks, use those blocks to calibrate both your calipers and micrometers, and send the blocks out on a regular schedule (I use 3 yrs) for 3rd party calibration. Makes things much easier, and more cost-effective.
JoshuaFroud
It depends on what you are using them for, what level of calibration is required and your industry requirements.
A calibration lab/facility would normally be certified to ISO 17025 which is the ISO standard for calibration. If you are not, then you could run into issues showing that your calibration procedure is valid.
The real question is, what are you using them for and why do you get them calibrated in the first place? Depending on this answer depends on what you can do going forward.
With regards to having all the tools sent away at one time, I've worked in places where we have either staggered the send-off of key equipment and always had a replacement available while one was away or we have brought someone on site to calibrate so tools were only away for hours rather than days.
Stefanos Papadakis
Well we are a manufacturing company, some of the parts have very tight tolerances so good calibration is of high importance! I guess that in order to lose as less time as possible we must call someone on site. Thank you very much.
Jane_S
We are a manufacturer of medical devices and some of the parts, especially from our precise mechanics shop, have very tight tolerances (think 1-100 microns). None of the standards applicable to our products explicitly require to use measuring devices calibrated by a lab with ISO 17025 certification. We use the approach described by JoshuaFroud. Never had any issue with external auditors and we are both ISO 9001 and 13 485 certified so I would advise to implement this approach as it is more cost/time efficient than sending the devices to external lab or inviting someone over.
Stefanos Papadakis
So we can calibrate our own devices using gauge blocks as stated from Ron Rompen ?
F Calibrating Gagemaker Products General Measurement Device and Calibration Topics 1
I Tool maintenance and calibration procedure - Calibrating tools/equipment AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
Crusader Interval for Self-Calibrating Measurement Device? Calibration Frequency (Interval) 15
A Calibrating a PRT sensor - Temperature Sensitivity Coefficient General Measurement Device and Calibration Topics 2
M Calibrating Digital Pressure Gages In-House General Measurement Device and Calibration Topics 10
F OEM has no procedure for calibrating their device General Measurement Device and Calibration Topics 4
B Problem Calibrating a Krautkramer DMS 2 Ultrasonic Thickness Meter Calibration Frequency (Interval) 2
J Calibrating an 80,000 psi Fluid Pressure Gauge General Measurement Device and Calibration Topics 6
S Calibrating Thermometer with Simulated Output Temperature from Fluke 5520A General Measurement Device and Calibration Topics 6
hogheavenfarm Is there a relatively inexpensive method of Calibrating our Torque Wrenches? General Measurement Device and Calibration Topics 7
L Calibrating Tool Makers Personal Tools General Measurement Device and Calibration Topics 9
P Exempt from Calibrating our Tape Measures and Micrometers ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 32
L Calibrating a Template Gage General Measurement Device and Calibration Topics 7
C Best Method for Calibrating Multimeters General Measurement Device and Calibration Topics 8
D How much Deviation is Acceptable when Calibrating a Hygrometer? General Measurement Device and Calibration Topics 3
K Calibrating Plain Tapered Bores at the Small End Diameter General Measurement Device and Calibration Topics 7
M Calibrating a Weight Scale in a Laboratory Calibration Frequency (Interval) 4
S Calibrating Panel Mounted Pressure Gauges located on Hydraulic Test Stands General Measurement Device and Calibration Topics 3
D Calibrating a Thermometer for use in Cold Rooms - ISO 9001 Clause 7.6 General Measurement Device and Calibration Topics 8
T Hands-On training on calibrating equipment General Measurement Device and Calibration Topics 2
L Calibrating Press Brakes, How to do? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
H Calibrating a Matheson Flowmeter-help appreciated General Measurement Device and Calibration Topics 2
Jerry Eldred Calibrating Mitutoyo SJ-201P Surface Roughness Testers General Measurement Device and Calibration Topics 4
S Calibrating a 1/8-27 NPT thread gage General Measurement Device and Calibration Topics 4
J Calibrating Electronic Equipment Tester Software - ISO 9001 Clause 7.6 Benchmarking 1
M Calibrating 1/2-20 UNF 2B STI Threaded Plug Gage General Measurement Device and Calibration Topics 3
A Calibrating 4" and larger Micrometers General Measurement Device and Calibration Topics 6
R Checking (Calibrating) Truncated Thread Set Plugs General Measurement Device and Calibration Topics 11
G Calibrating a reflectometer - Scale uncertainty with reading? Measurement Uncertainty (MU) 1
D Calibrating Lufkin ID Micrometer ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Z Calibrating Sunnen PG800 precision bore gage & PG700 setting fixtures General Measurement Device and Calibration Topics 1
C Gage pin calibration procedure for accurately calibrating gage pins General Measurement Device and Calibration Topics 18
Crusader Self-Calibrating Furnace does not require calibration General Measurement Device and Calibration Topics 15
B Using & Calibrating Ultrasonic Micrometer General Measurement Device and Calibration Topics 4
M Calibrating Angle Gage Blocks General Measurement Device and Calibration Topics 2
R Validation of A Procedure for Calibrating Dial Calipers using Traceable Gauge Blocks General Measurement Device and Calibration Topics 6
J Measurement Uncertainty for Calibrating Custom Check Fixtures with a Portable CMM Measurement Uncertainty (MU) 3
S Calibrating Biomed equipment in an ISO 17025 accredited calibration laboratory ISO 17025 related Discussions 5
T Calibrating or Verifying Metal or Steel Tape Measures General Measurement Device and Calibration Topics 195
T Calibrating the calibrator (torque test) - Electronic torque tester CDI 4001-0-ETT General Measurement Device and Calibration Topics 3
R Calibrating Leak Testers - Old fashioned water tank type tester General Measurement Device and Calibration Topics 2
P Calibrating Density Cups & Viscosity Cups In-House - Seeking Procedure / Help General Measurement Device and Calibration Topics 2
R Micrometer resolution for calibrating thread plug gages General Measurement Device and Calibration Topics 7
J Thread Wire Chart to use when Calibrating a particular size Thread Gage General Measurement Device and Calibration Topics 16
S Calibrating some of our equipment in house - Where do I start? General Measurement Device and Calibration Topics 19
