K
kixxy
Hello first of i hope i'm posting in the correct forum. (Sorry if i'm not)
An issue i have been having at work is calibrating Plain Tapered bores @ the small end diameter. Our company manufactures Plain taperd bore gauges and the Work shop and i measure them. I take my reading from the Large end diameter with comparison to a calibrated plug gauge.
So now i have the measured large end diameter of the plain ring bore i also take the overall length of the plain bore gauge.
The problem/dispute i have
I was told the maths is simple all i have to do is:
Divide the overall length by the rate of taper then take away that figure of the measured large end diameter.
The question is what if the rate of taper/angle is incorrect ?
The procudure i have been given assumes that the Rate of taper/angle is correct.
I Hope that this isn't confusing as my grammer isn't that great. I was just hoping that any one with experiance with plain tapered bores could give me and insight/ infomation in this matter.
