Calibrating the monitoring device but not the unit
imecoli
So, this is new to me, we are building out a facility and we were told for validations we would be doing a "Family approach" where we only conduct an IOPQ on one unit and if is passes it sets precedent for all other units with the same model number. If that wasn't strange enough, I was just asked about not calibrating the units, only the monitoring device and using that for justification. this would demonstrate that the unit is within spec. I am concerned that the controller probe will not be calibrated and in the event of opposite temperature drifts in the probes we may potentially approach OOT conditions.
Hs anyone done this? I am not comfortable with this but am I being obtuse?
imecoli
This is coming from someone from {a different company} , he said this is how they handled equipment there.
dwperron
If you perform an IOPQ on one unit and it fails would they then reject the total "family"?
I think not.....
A question. What is the monitoring device being used for if not for calibrating the units?
Ninja
Looking for Reality
Howdy,
I removed the specific company name in Post#3... just to be safe.
imecoli
I think not.....
I made sure if the unit fails it invalidates the whole "family approach"
The monitoring will be our Siemens EMS.
An MSA, which includes a bias/linearity study (i.e., calibration) includes the entire measurement system, not just a portion of the system. In your case the system includes the probes for the very reason that you cited.
A company that I used to work at performed 100% leak testing on the product. The entire measurement system consisted of a mass spectrometer, 3-4 feet of tubing, a robot controlled nozzle and tested at a speed of ~ 1 inch/second. During calibration, they connected a calibrated leak directly to the mass spec, eliminating the tubing and nozzle and tested statically. If you tested the entire system dynamically on the same calibrated leak the results were an order of magnitude different.
Calibrate the entire system.
Enghabashy
As ISO IEC 17025 requirements for verification & calibration , we shall maintain & perform Calibration & intermediate checks plans which covering Re-Calibration date ( it's shall considering the calibration results & uncertainty results as written in the calibration certificates ) , & the mandatory also to plan the interval for internal checks by using another comparison tool ( as example another device ,verification checks blocks gauges, another micrometers , ---etc, " , you can use MSA techniques also as tool of verifications,
The Req. as ISO 17025 /6.4.10 :When intermediate checks are necessary to maintain confidence in the performance of the equipment, these checks shall be carried out according to a procedure.
-the another Req.: 6.4.13 Records shall be retained for equipment--- :e) calibration dates, results of calibrations, adjustments, acceptance criteria, and the due date of the next calibration or the calibration interval;-- e) interlaboratory comparisons;
-other Req.: 7.7 Ensuring the validity of results ; e) intermediate checks on measuring equipment;/7.7.1 inter Lab. comparison
R Calibrating Solid Thread Rings with HILO master General Measurement Device and Calibration Topics 1
Slo_Glenn Calibrating Clocks General Measurement Device and Calibration Topics 13
F Calibrating Gagemaker Products General Measurement Device and Calibration Topics 1
S Calibrating our own equipment, can we? Micrometers to calibrate vernier calipers General Measurement Device and Calibration Topics 13
I Tool maintenance and calibration procedure - Calibrating tools/equipment AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
Crusader Interval for Self-Calibrating Measurement Device? Calibration Frequency (Interval) 15
A Calibrating a PRT sensor - Temperature Sensitivity Coefficient General Measurement Device and Calibration Topics 2
M Calibrating Digital Pressure Gages In-House General Measurement Device and Calibration Topics 10
F OEM has no procedure for calibrating their device General Measurement Device and Calibration Topics 4
B Problem Calibrating a Krautkramer DMS 2 Ultrasonic Thickness Meter Calibration Frequency (Interval) 2
J Calibrating an 80,000 psi Fluid Pressure Gauge General Measurement Device and Calibration Topics 6
S Calibrating Thermometer with Simulated Output Temperature from Fluke 5520A General Measurement Device and Calibration Topics 6
hogheavenfarm Is there a relatively inexpensive method of Calibrating our Torque Wrenches? General Measurement Device and Calibration Topics 7
L Calibrating Tool Makers Personal Tools General Measurement Device and Calibration Topics 9
P Exempt from Calibrating our Tape Measures and Micrometers ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 32
L Calibrating a Template Gage General Measurement Device and Calibration Topics 7
C Best Method for Calibrating Multimeters General Measurement Device and Calibration Topics 8
D How much Deviation is Acceptable when Calibrating a Hygrometer? General Measurement Device and Calibration Topics 3
K Calibrating Plain Tapered Bores at the Small End Diameter General Measurement Device and Calibration Topics 7
M Calibrating a Weight Scale in a Laboratory Calibration Frequency (Interval) 4
S Calibrating Panel Mounted Pressure Gauges located on Hydraulic Test Stands General Measurement Device and Calibration Topics 3
D Calibrating a Thermometer for use in Cold Rooms - ISO 9001 Clause 7.6 General Measurement Device and Calibration Topics 8
T Hands-On training on calibrating equipment General Measurement Device and Calibration Topics 2
L Calibrating Press Brakes, How to do? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
H Calibrating a Matheson Flowmeter-help appreciated General Measurement Device and Calibration Topics 2
Jerry Eldred Calibrating Mitutoyo SJ-201P Surface Roughness Testers General Measurement Device and Calibration Topics 4
S Calibrating a 1/8-27 NPT thread gage General Measurement Device and Calibration Topics 4
J Calibrating Electronic Equipment Tester Software - ISO 9001 Clause 7.6 Benchmarking 1
M Calibrating 1/2-20 UNF 2B STI Threaded Plug Gage General Measurement Device and Calibration Topics 3
A Calibrating 4" and larger Micrometers General Measurement Device and Calibration Topics 6
R Checking (Calibrating) Truncated Thread Set Plugs General Measurement Device and Calibration Topics 11
G Calibrating a reflectometer - Scale uncertainty with reading? Measurement Uncertainty (MU) 1
D Calibrating Lufkin ID Micrometer ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Z Calibrating Sunnen PG800 precision bore gage & PG700 setting fixtures General Measurement Device and Calibration Topics 1
C Gage pin calibration procedure for accurately calibrating gage pins General Measurement Device and Calibration Topics 18
Crusader Self-Calibrating Furnace does not require calibration General Measurement Device and Calibration Topics 15
B Using & Calibrating Ultrasonic Micrometer General Measurement Device and Calibration Topics 4
M Calibrating Angle Gage Blocks General Measurement Device and Calibration Topics 2
R Validation of A Procedure for Calibrating Dial Calipers using Traceable Gauge Blocks General Measurement Device and Calibration Topics 6
J Measurement Uncertainty for Calibrating Custom Check Fixtures with a Portable CMM Measurement Uncertainty (MU) 3
S Calibrating Biomed equipment in an ISO 17025 accredited calibration laboratory ISO 17025 related Discussions 5
T Calibrating or Verifying Metal or Steel Tape Measures General Measurement Device and Calibration Topics 210
T Calibrating the calibrator (torque test) - Electronic torque tester CDI 4001-0-ETT General Measurement Device and Calibration Topics 3
R Calibrating Leak Testers - Old fashioned water tank type tester General Measurement Device and Calibration Topics 2
P Calibrating Density Cups & Viscosity Cups In-House - Seeking Procedure / Help General Measurement Device and Calibration Topics 2
