Calibration and Tolerance Ranges of Pressure Gages
dwhite624
We have a new testing facility in our shop which uses many different pressure gages to measure various gasses and air pressures. The person who did the calibration did not have tolerance ranges on his certs and I was curious if we:
1. Need them on the certs?
2. If so, what is a standard rule of thumb when it comes to pressure gage tolerances for calibration (i.e. -.00004 / -.00001 for Deltronics Pins)?
Thank you all in advance for your help!
Kales Veggie
People: The Vital Few
I have a couple of questions:
1) do the gages have to be calibrated? (...to ensure valid results...)
2) rule of thumb is a factor of 10 between calibration tolerance and the resolution you need for your test / measurement.
dwhite624
Thank you for your quick response.
1. Yes, the gages do have to be calibrated. There are many gages in the system but only a few are actually measuring critical pressure. These are the gages that need calibration.
2. I am thinking about just using the rule of +/- 1/2 the smallest increment on the gage.
Any thoughts on this?
Ninja
Looking for Reality
What happens when the smallest increment on the gage is larger than your process needs?
That's why you should base your calibration off of the process need...
the gage doesn't need the calibration, it won't care.
It is the process that needs the gage to be accurate.
sandore
pressure gauges have categories named Class, it's at front of them like Kl 1.0; CL 2.0. Each class means a error tolerance of the full range, example class 1.0 of a gauge range 100 psi means the maximum error 1% of 100 psi = -/+ 1 psi. calibrating the gauge error is found and the gauge satisfied if the error is at or below the class.
Class of manometers are
0.1% for standard gauges
0.2%
0.3%
0.6%
1.0% for process needed of good precision
1.6%
2.5%
4.0% the most of industrial gauges
One more thing: standard gauge to calibrate should have a better class of gauge to be tested, preferably, where possible, a 4:1 ratio and standard range the must be equal or maximum twice.
I hope that helps a little.
F
fast_hedgehog
We use this for all bourdon tube gauges:
BS EN 837-1:1998
Pressure gauges. Bourdon tube pressure gauges. Dimensions, metrology, requirements and testing
Status : Current Published : March 1998
It includes the classes mentioned already.
0.2%
0.3%
0.6%
1.6%
2.5%
Great info. Also note that some pressure gauges may have a tolerance of 3-2-3% FS.
sandore
Good morning, Charles.
Sorry for the lateness of the response.
In bourdon tube pressure gauges at the beginning and end of the range of the cover often have errors, hence these tolerances. In such cases the more tolerant classifies gauge. In the center the error is smaller, so the choice of a gauge of this type must be remembered that. Find that reading interest is in the central part of the manometer.
Best regards
Sandore
D Tolerance and MPEs for Re-calibration Manufacturing and Related Processes 0
D Calibration tolerance question using Pipettes Medical Device and FDA Regulations and Standards News 3
WEAVER Electronic Weighing Scale Calibration Tolerance Manufacturing and Related Processes 1
A Calibration tolerance for data logger General Measurement Device and Calibration Topics 3
K Calibration Standards - Master weight having more tolerance than our gram scale General Measurement Device and Calibration Topics 3
T Calibration Laboratory Temperature/Humidity goes out of tolerance due to Power Loss General Measurement Device and Calibration Topics 9
H Determining Calibration Tolerance for new Leak and Occlusion Equipment Measurement Uncertainty (MU) 2
C Out of Calibration vs. Out of Tolerance - Calibration Definitions Nonconformance and Corrective Action 7
H Is there ISO 13485 Guidance for Calibration Tolerance? General Measurement Device and Calibration Topics 14
M Out of Tolerance Calibration Report Document Control Systems, Procedures, Forms and Templates 12
M Calibration Problem - Range of Use, Calibration Acceptance Tolerance IATF 16949 - Automotive Quality Systems Standard 11
B Calibration Accuracy vs. Gage/Part Tolerance General Measurement Device and Calibration Topics 4
N Universal/International Symbol for Tolerance and/or Calibration Levels? General Measurement Device and Calibration Topics 7
B Tolerance for Digital Indicator Calibration - Machinists Indicators General Measurement Device and Calibration Topics 1
R Setting Calibration Tolerance on Gauges - Oven Calibration and Stepped Plug Gage General Measurement Device and Calibration Topics 10
F Accuracy of calibration relationship to tolerance General Measurement Device and Calibration Topics 2
B Electric 0-8" Caliper Calibration Tolerance Question. General Measurement Device and Calibration Topics 9
D Calibration - Out of Tolerance - Trace Back System General Measurement Device and Calibration Topics 1
M Calibration System - Finding Product Made with Out of Tolerance Torque Drivers General Measurement Device and Calibration Topics 7
H Calibration / Capability in a PCP FMEA and Control Plans 1
R First Time Managing Calibration and Measurement System. Need Help. General Measurement Device and Calibration Topics 11
M CE marked medical device - do they need UKAS certified calibration provider ISO 17025 related Discussions 4
JDJohnson Micrometer & Caliper Calibration (ISO-9001) General Measurement Device and Calibration Topics 26
B Precision Current Loop for Current Probe Calibration Reliability Analysis - Predictions, Testing and Standards 2
Strange Juan Freezers fridges Incubators Calibration Labels General Measurement Device and Calibration Topics 12
D ISO 9001:2015 Calibration Procedures Manufacturing and Related Processes 16
G Calibration of Angle microscope stage micrometer General Measurement Device and Calibration Topics 1
K END CALIBRATION CANNOT BE PERFORMED Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
C Gage Block Grade 1 - Calibration Measurement Uncertainty (MU) 15
JoeRandom11 Question of Calibration Cycles AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
placebo_master What is the difference between "Fitness for Purpose" and "Calibration/Verification"? General Measurement Device and Calibration Topics 6
G AMS 2750 F Instrument Calibration Results and Recording AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
Q Gage calibration in disarray ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
R GearBox Test Bench Calibration General Measurement Device and Calibration Topics 2
Q Internal calibration (stopwatch) IATF 16949 - Automotive Quality Systems Standard 3
D Is calibration really required? IATF 16949 - Automotive Quality Systems Standard 6
B AS9100 Calibration Register AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
N Misc Calibration Standard Inquiry Various Other Specifications, Standards, and related Requirements 5
G IATF 7.1.5.2.1 Calibration/verification records :Program/software verification IATF 16949 - Automotive Quality Systems Standard 7
J What risk to cover when NOT using ISO 17025 accredited/certified labs for calibration ISO 17025 related Discussions 3
Moncia ISO 9001 calibration question please ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
CaliperJim Double Ended Thread Plug Gauge Calibration General Measurement Device and Calibration Topics 9
R Calibration due dates. Using GAGEpack Software 3
B Calibration Tolerances - Pipettes ISO 8655 General Measurement Device and Calibration Topics 0
A Calibration of spring loaded test fixture General Measurement Device and Calibration Topics 5
G Adjustments after calibration ISO 17025 related Discussions 11
