CALIBRATION CERTIFICATE REQUIREMENTS
Calgirl319
DOES THE SPEC USED FOR CALIBRATION HAVE TO ON THE CERTIFICATE OF CALIBRATION OR JUST THE PROCEDURE OR BOTH? WHAT STANDARD TELLS ME EVERYTHING THAT MUST BE ON A CERTIFICATE OF CALIBRATION?
BradM
Hello there!!
A few questions. Is this a calibration being performed by a commercial entity for an end user? A customer?
Does the calibration lab have any certifications/ accreditations?
Is this an "inside" calibration? One performed for equipment owned by a company by employees of that company?
Finally... what kind of industry specifications/ guidelines are in place here?
I would suggest minimally the certificate should attest to what kind of accuracy performance the instrument was tested against. It could be a simple statement like "Caliper xxx was verified and found within specifications listed in procedure YYYYY". But to me the piece of paper is pretty worthless if it doesn't have some kind of statement what was tested, what standard was used, and what it was tested against.
Ron Rompen
In my past experience (QS9000, ISO 9001, TS 16949) I have used software to keep records of the 'as found' and 'as left' status of any calibrated gauge. I don't reference any specific procedure number - I have a set of calibration guidelines which have fairly generic statements (e.g. calibrate calipers using gauge block set GB-001). The software contains the values that I compare against, and the limits of accuracy of the gauge. So far, I have not had any complaints or criticism from external and RB auditors.
With that being said, it will depend a LOT on who you are doing this for, and under what conditions/requirements. If I send a gauge out to a 3rd party for calibration, I expect that they will have documented procedures in place which detail how to perform the calibration on the gauge - this may also be a requirement under some standards.
BradM
Agreed, Ron. The only "certificates" I get now are from standards sent out for calibration. Everything else is logged in the software system.
In case of audit and we need to print stuff out, it has the ID, make, model, etc. As-found/ as-left data, procedure used, standard used and such.
Ironic... they offer to send instead a PDF file. But... they lock them down so we're not able to add a cover page from our software system.
So we have to obtain, scan, and shred the paper copy. If they would lock down the text and contents, that would be fine. But they lock the whole file, so you can't do anything with it!
qualitymanagerTT
Have you asked if they would add your cover page to the file?
dwperron
What standard do you want to comply with?
For instance ANSI Z540, ISO 17025, and ISO 10012 all have lists of what is required to be on a calibration report. If you are not complying with one of these calibration standards then you probably don't have such guidance. Documents like ISO 9001, AS9100, ISO 13485, etc. will have sections on control of monitoring and test equipment, but they don't go into detail as to what they require to be on a calibration record.
qualitymanagerTT
... Documents like ISO 9001, AS9100, ISO 13485, etc. will have sections on control of monitoring and test equipment, but they don't go into detail as to what they require to be on a calibration record.
This is correct (at least for ISO 9001 as I can't speak for the others listed), however, the "ISO 9001 Auditing Practices Group Guidance on Measurement Traceability" references ISO/IEC 17025 (though the APG guidance is a 2016 document, and thus references the 2005 version of 17025, and not the 2017 version).
In the 2017 version, clauses 7.8.2 and 7.8.4 list requirements for calibration certificates. In the Caribbean, I haven't met anybody outside of a National Standards Body / National Metrology Institute who understands measurement traceability, far less metrological traceability.
And, of course, much more needs to be on a calibration certificate than just metrological traceability.
E Calibration Certificate Content Requirements General Measurement Device and Calibration Topics 3
N Calibration Certificate Requirements for Pressure Gauges General Measurement Device and Calibration Topics 9
T Class "F" Weight "Certificate of Traceability" Requirements - Calibration General Measurement Device and Calibration Topics 7
B Validating calibration certificate as per API Q1 General Measurement Device and Calibration Topics 9
L A certificate of conformance used to support a calibration General Measurement Device and Calibration Topics 6
M Storing Calibration Certificate Document Control Systems, Procedures, Forms and Templates 7
M Calibration Certificate Result issued by an accredited external laboratory General Measurement Device and Calibration Topics 9
F Calibration certificate content - Average Value and True Value ISO 17025 related Discussions 6
M How to read a calibration certificate for thermo hygrometer General Measurement Device and Calibration Topics 2
V Calibration certificate verification Qualification and Validation (including 21 CFR Part 11) 3
A Calibration Certificate Results General Measurement Device and Calibration Topics 3
M Accredited Calibration Sevice Provider using computerized system to issue calibration certificate Qualification and Validation (including 21 CFR Part 11) 3
M Accredited Calibration Sevice Provider using computerized system to issue calibration certificate General Measurement Device and Calibration Topics 2
G Is the calibration due date of equipment used to be on calibration certificate ISO 17025 related Discussions 38
G Calibration Certificate, fancy paper or not? General Measurement Device and Calibration Topics 9
Crusader Certificate of calibration from Manufacturer allowed? General Measurement Device and Calibration Topics 14
T Calibration Certificate Readings After Adjustment General Measurement Device and Calibration Topics 5
C Calibration Certificate "As Found" condition - TS16949 Section 7.6.2 General Measurement Device and Calibration Topics 7
M ILAC Regulations - Expression of Units on the Calibration Certificate General Measurement Device and Calibration Topics 6
A Coverage factor in calibration certificate for a multimeter General Measurement Device and Calibration Topics 4
N Client Request for Reference Equipment Calibration Certificate General Measurement Device and Calibration Topics 3
T Microsoft Access Database to create a Simple Calibration Certificate General Measurement Device and Calibration Topics 6
V How to use a Calibration Certificate in Uncertainty Calculation for a Test Measure Measurement Uncertainty (MU) 13
T Uncertainty in Hygrometer Calibration Certificate General Measurement Device and Calibration Topics 4
O How can I use reading from calibration certificate in measurement Calibration Frequency (Interval) 7
K New Gauges calibration certificate shows deviations from the measurement uncertainty IATF 16949 - Automotive Quality Systems Standard 5
Q Can we go by different Calibration Frequency vs. What's on the Certificate ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
R Torque Tester Calibration Traceability and Certificate question ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
S No Calibration Due Date on a Calibration Certificate unless requested by a customer? Calibration Frequency (Interval) 9
P Rounding Uncertainty to Zero on a Calibration Certificate Measurement Uncertainty (MU) 7
N Calibration Lab unable to issue Accredited Certificate when error is too high? General Measurement Device and Calibration Topics 3
S How to Evaluate a Calibration Report Certificate General Measurement Device and Calibration Topics 8
R LCP 01201P and ICPF2P Calibration Methods Stated in Calibration Certificate General Measurement Device and Calibration Topics 2
M ILAC p14:12/2010 - Accredited Calibration Certificate Uncertainty General Measurement Device and Calibration Topics 2
A Can any organization issue a Calibration Certificate? General Measurement Device and Calibration Topics 5
A No Uncertainty Listed on Calibration Certificate: Is it traceable calibration? General Measurement Device and Calibration Topics 8
M External Calibration Certificate Review ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
A Fluke Digital MultiMeter Calibration Traceability and Certificate General Measurement Device and Calibration Topics 11
S Reference to original Calibration Certificate - ISO 17025 Section 5.10.9 ISO 17025 related Discussions 4
howste Calibration Certificate Contents: How to report Measurement Uncertainty? Measurement Uncertainty (MU) 18
C Accredited Calibration Certificate Content - ISO 17025 Section 5.10.4.2 Question ISO 17025 related Discussions 7
D Calibration Certificate - 'test report shall not be reproduced except in full' General Measurement Device and Calibration Topics 2
howste Condition of Item Calibrated - ISO 17025 Clause 5.10.2f - Calibration Certificate ISO 17025 related Discussions 13
C Interpreting Outside Laboratory Calibration Certificate Measurement Uncertainty (MU) 3
Al Rosen Calibration Certificate content for New Equipment General Measurement Device and Calibration Topics 8
R What to do after I receive a calibration certificate General Measurement Device and Calibration Topics 4
E Calibration - Manufacturer's Calibration Certificate Date ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
S Verification of calibration certificate Miscellaneous Environmental Standards and EMS Related Discussions 1
B ISO 17025 logo & ISO 9001 logo on calibration certificate/report ISO 17025 related Discussions 7
P Certificate of Calibration Suppliers for an ISO 9001 company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
