Not only does the OEM not know how often the instrument is used, the OEM does not know the environment in which the instrument is stored and used. If we are to question their recommended period (for example, one year) we should be ready to say why we deviate from it.The OEM doesn’t have anymore idea on how frequently a device is used - they often recommend 12 months! You have to experiment and get data. A screw plug gauge used to check threads in aluminium will wear less than one used on stainless steel. Yes, it’s work, and you may not want to do what is necessary to generate the data on which to base a decision. However, this talk of time based recalls is only OK when you want to throw money at calibration.
To be clear, I am completely aligned with the suggestion that usage frequency should be a factor in determining calibration frequency. However, a gage that sits on a shelf with zero usage can become unreliable as is the gage that is used every day. So the sum of considerations should be applied to decide the calibration frequency.
