Calibration Frequency - Evidential Breath Analizer
Tungsten
#11
Re: Calibration Frequency
Something that could be questioned is the number of times a gage is utilized between calibrations. I have extend calibration intervals for those gages that only see occasional use where those that see continual use are calibrated more often. It becomes more of a count for the number of uses vs. a time period, for my use, a bit more accurate for maintaining calibration of a precision gage.
This IS exactly what I was thinking. The number of time the device was used in between calibrations. For a breath analyzer it should NOT be more than a thousand times. Frankly, in Ireland, this can be more. Far more.:tg: Thanks very much for your input!:applause:
bobdoering
Stop X-bar/R Madness!!
#12
Yes, but again, that is just a manner of developing calibration intervals. It it was used a bazillion times between calibrations - or just once -and both calibrations passed, it is still all good.
Tungsten
#13
I think if there is a solid trend in using the instrument significantly MORE times than the recommended, but the cal intervals (6 mos) were NOT tightened, I'd definitely question accuracy. Don't you think?:(
Tungsten
#14
Yes and no. There is a specific guide for EBS' that the unit can not be used MORE than a thousand times in between calibrations. Again, this is all legality vs. practicality. (Unfortunately) I don't have much room for science to support the case. All I can grab into is LEGALITY. :thanks: for your input!
bobdoering
#15
You can always question it - but there really is nothing to support a problem existed by exceeding "recommendations" if the device passed the calibration each time. It's not quite the same thing as conceptually as running your car 20,000 miles between oil changes.
Tungsten
#17
True, and you're right! However there is one other thing. The manual of the LION Intoxilizer 6000IRL states that the machine produces an "ambient fail" reading if unable to conduct a test due to temperature, but this did not happened. Question: if the unit set to produce acceptable readings and print between 15 and 35 degrees C, how come it STILL printed a result at 14.5? :confused: Thanks for your inputs.:agree:
#18
Hi, and thanks very much for your reply. So, otherwords if I stopped by the cops on 19th and they took a breath test with a device which was due for calibration on the 12th of the same month, there is no, or little argument from the point of legality?
You're in Ireland, so I have no idea what the laws might be. In the US, assuming evidence is admissible to begin with, the idea is to convince a jury that the calibration status of a device used in a particular instance is questionable--reasonable doubt.
bobdoering
#19
Now THAT is a valid question!
BradM
#20
Calibration is simply verifying the instrument is operating like it is intended. So either the instrument has been working like it should, or not.
The instrument has a tolerance, and there is error with testing methods. That tolerance and error may/ may not be a factor in testing.
Say.. you are testing Blood Alcohol content, and it's important if the actual BAC is .08 or .1. If the instrument is only accurate to within .05, say, then you may have a case. If it is accurate to like .01 or better, I don't think you would get too far with that.
Now, if this instruments has a "calibration" program that must be ran prior to each use, that is different.
I would think you would be interested in determining the repeatability of the instrument. How reliable is this thing?
Bottom line: This instrument is suitable to be making the claims during testing, or it is not. Your burden is to prove in court that the instrument is/ was not suitable.
L Calibration Frequency for Surftest SJ-400 General Measurement Device and Calibration Topics 0
J 95% reliability for calibration frequency Calibration Frequency (Interval) 7
G Sequence and Frequency of Calibration for Thread Gauges General Measurement Device and Calibration Topics 2
Marc Calibration Frequency (Interval) Discussions Sub-Forum General Measurement Device and Calibration Topics 0
J Digital Scale Re-Calibration Interval Frequency General Measurement Device and Calibration Topics 10
M A Guide or Standard for Calibration Interval (Frequency) Calibration Frequency (Interval) 2
smryan Weight Calibration Standards - External Calibration Frequency General Measurement Device and Calibration Topics 11
G UID Compliance Verifier Calibration Test Card Calibration Frequency General Measurement Device and Calibration Topics 3
Q Can we go by different Calibration Frequency vs. What's on the Certificate ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
K Pin Gage Use vs. Calibration Frequency Calibration Frequency (Interval) 13
S Gage Calibration Requirement and Frequency/Extended Frequency ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
drgnrider Calibration Schedule (Frequency) not properly reflected on Laboratory Paperwork Calibration Frequency (Interval) 7
Y Calibration Frequency Requirements of Liquid in Glass Thermometer General Measurement Device and Calibration Topics 2
D Calibration Frequency of Thread Gages use for Aluminium and Stainless Steel Products Calibration Frequency (Interval) 6
G Dial Indicator Calibration Frequency - ASME/ANSI B89.1.10M-1987 Calibration Frequency (Interval) 4
G Usage and Calibration History for Calibration Frequency AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
S Calibration Frequency for a Measurement Device: Vibration Meter Calibration Frequency (Interval) 4
M Thread Plug Gage - Calibration Frequency ISO 13485:2016 - Medical Device Quality Management Systems 1
A How Companies Coordinate their Calibration Frequency General Measurement Device and Calibration Topics 3
B Definition of Calibration Frequency - Dispute during Audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
K Determination of Calibration Frequency by an Outside Laboratory Calibration Frequency (Interval) 5
E Calibration Frequency of Reference Magnets for Gauss Meter Calibration General Measurement Device and Calibration Topics 5
V Gage Block Calibration Frequency Requirements Calibration Frequency (Interval) 20
Z CMM (Coordinate Measuring Machine) Calibration Interval (Frequency) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
MarilynJ6354 Torque Wrench Calibration Frequency (Calibration Interval) Calibration Frequency (Interval) 38
AnaMariaVR2 Plate washer maintenance & calibration frequency? US Food and Drug Administration (FDA) 3
R CMM Calibration Frequency - Bendix manual Coordinate Measuring Machine Calibration Frequency (Interval) 5
C Extending the Calibration Frequency of a Measurement Device Calibration Frequency (Interval) 17
L CMM - Calibration Frequency and Variation Calibration Frequency (Interval) 3
D Calibration Frequency of CMM as per ISO/IEC 17025 ISO 17025 related Discussions 11
C Calibration Frequency and training a new calibration coordinator IATF 16949 - Automotive Quality Systems Standard 5
J In car position check fixtures - Calibration frequency and How to Calibrate them IATF 16949 - Automotive Quality Systems Standard 8
D Minimum Frequency for Thermometer Calibration Food Safety - ISO 22000, HACCP (21 CFR 120) 5
R Calibration of a frequency measurement device/frequency source General Measurement Device and Calibration Topics 2
R New Equipment Calibration and determination of Calibration Frequency General Measurement Device and Calibration Topics 8
M What is the recommended calibration frequency for gage blocks? Calibration Frequency (Interval) 2
M Extending Surface Plate Calibration Frequency General Measurement Device and Calibration Topics 3
Ajit Basrur Reduction of calibration frequency for CMM (coordinate measuring machine) General Measurement Device and Calibration Topics 9
H Determining Measurement (Measuring) Device Calibration Frequency Calibration Frequency (Interval) 36
K Calibration Frequency of a CMM Machine (Coordinate Measuring Machine) Calibration Frequency (Interval) 1
K Calibration Frequency for Leica Laser Tracker Calibration Frequency (Interval) 4
R Microwave Time and Frequency Calibration Measurement Uncertainty (MU) 11
T Basis for Calibration Method and Intervals (Frequency) - FAA approved repair station Federal Aviation Administration (FAA) Standards and Requirements 10
F Calibration Intervals (Frequency) for Stereoscopes, Microscopes, etc. Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
H Determining Calibration Frequency for Ammeters & Voltmeters used on the line Calibration Frequency (Interval) 7
N Calibration Frequency of Measurement and Test Devices Calibration Frequency (Interval) 26
R Calibration Intervals (Frequency) derived from Variables Data Calibration Frequency (Interval) 30
