Calibration Frequency of Reference Magnets for Gauss Meter Calibration
E
EMacP
Anybody knows what is the recommended calibration interval for Reference Magnets? Currently I in the process of getting some reference Magnets. The company is issuing a 1 yr cal interval.
Another thing, anybody can recommend me a manufacturer who can produce reference magnet of 100kG transverse. It is good if can give me website or email link.
Stijloor
Any magnet/calibration experts that can help?
Thank you!!
Stijloor.
Jerry Eldred
Sorry that I'm so overwhelmed at work, I am just checking messages.
If it were me (and I'm not a magnet expert - at all), I would go with the manufacturer's recommendations of a year (if that is who calibrated it). The definition (highly simplified and my version of it) is basically the probability to some defined statistical level (quite often, 95%) is the amount of time an item can be expected to remain within its specified tolerance. In my 35+ years of calibrating a little of everything, most items remain within tolerance longer than their interval (there's the 95%).
All that said, first, I would go with the manufacturer's recommended interval (because in establishing an interval, there should be a legitimate basis for it). BUT... once you have it recertified a few times, if you get your certifications with the measurements and perhaps uncertainty, you can plot over a few years how well it holds its specifications and how far it actually drifts over its interval, and eventually come up with a calculated interval, which may be longer than a year.
I do not recommend arbitrarily establishing a longer interval just to save money, because in doing so, although you may save some vendor calibration costs, until you establish a statistical trail of evidence, you are increasing the risk/probability of making bad measurements based on the calibration of the item.
Just my two cents.
MIREGMGR
Years ago, I owned a company that made precision microgaussmeters. Probably not what you're doing, but similar enough from the point of view of calibration physics.
Our experience was that it was far easier to establish an effective calibration field geometry using active circuitry and a constructed coil system than with one or more permanent magnets. It's very difficult with a permanent magnet to know how far from the magnet the UUT is located, and whether some ferromagnetic object in the far field is affecting the near field enough to make a difference.
With a wound coil and readily controlled active drive, OTOH, we were able to show from physical principles and verify with measurements that our field geometry was constant over a sufficiently large volume that it was not necessary to precisely locate the UUT in x:y:z to achieve known and repeatable calibration conditions. We did of course have to precisely control the UUT in regard to angular orientation, which is unavoidable.
I don't know if that's helpful, of course. You probably just want to buy a calibration magnet and have that be a sufficient solution.
Hershal
Metrologist-Auditor
I have used a guass meter to measure to 30k Gauss. Some magnets may possibly be treated as reference materials. Now the question is whether those are charged or not.
Passing a high momentary current around the magnets (e.g., neodymium) will give them a high charge.
Charged or not, material, and other influences must be considered for uncertainty.
L Calibration Frequency for Surftest SJ-400 General Measurement Device and Calibration Topics 0
J 95% reliability for calibration frequency Calibration Frequency (Interval) 7
G Sequence and Frequency of Calibration for Thread Gauges General Measurement Device and Calibration Topics 2
Marc Calibration Frequency (Interval) Discussions Sub-Forum General Measurement Device and Calibration Topics 0
J Digital Scale Re-Calibration Interval Frequency General Measurement Device and Calibration Topics 10
M A Guide or Standard for Calibration Interval (Frequency) Calibration Frequency (Interval) 2
smryan Weight Calibration Standards - External Calibration Frequency General Measurement Device and Calibration Topics 11
G UID Compliance Verifier Calibration Test Card Calibration Frequency General Measurement Device and Calibration Topics 3
Q Can we go by different Calibration Frequency vs. What's on the Certificate ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
K Pin Gage Use vs. Calibration Frequency Calibration Frequency (Interval) 13
S Gage Calibration Requirement and Frequency/Extended Frequency ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
drgnrider Calibration Schedule (Frequency) not properly reflected on Laboratory Paperwork Calibration Frequency (Interval) 7
Y Calibration Frequency Requirements of Liquid in Glass Thermometer General Measurement Device and Calibration Topics 2
D Calibration Frequency of Thread Gages use for Aluminium and Stainless Steel Products Calibration Frequency (Interval) 6
G Dial Indicator Calibration Frequency - ASME/ANSI B89.1.10M-1987 Calibration Frequency (Interval) 4
G Usage and Calibration History for Calibration Frequency AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
S Calibration Frequency for a Measurement Device: Vibration Meter Calibration Frequency (Interval) 4
M Thread Plug Gage - Calibration Frequency ISO 13485:2016 - Medical Device Quality Management Systems 1
A How Companies Coordinate their Calibration Frequency General Measurement Device and Calibration Topics 3
B Definition of Calibration Frequency - Dispute during Audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
K Determination of Calibration Frequency by an Outside Laboratory Calibration Frequency (Interval) 5
V Gage Block Calibration Frequency Requirements Calibration Frequency (Interval) 20
Z CMM (Coordinate Measuring Machine) Calibration Interval (Frequency) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
MarilynJ6354 Torque Wrench Calibration Frequency (Calibration Interval) Calibration Frequency (Interval) 38
AnaMariaVR2 Plate washer maintenance & calibration frequency? US Food and Drug Administration (FDA) 3
R CMM Calibration Frequency - Bendix manual Coordinate Measuring Machine Calibration Frequency (Interval) 5
C Extending the Calibration Frequency of a Measurement Device Calibration Frequency (Interval) 17
L CMM - Calibration Frequency and Variation Calibration Frequency (Interval) 3
D Calibration Frequency of CMM as per ISO/IEC 17025 ISO 17025 related Discussions 11
T Calibration Frequency - Evidential Breath Analizer Calibration Frequency (Interval) 25
C Calibration Frequency and training a new calibration coordinator IATF 16949 - Automotive Quality Systems Standard 5
J In car position check fixtures - Calibration frequency and How to Calibrate them IATF 16949 - Automotive Quality Systems Standard 8
D Minimum Frequency for Thermometer Calibration Food Safety - ISO 22000, HACCP (21 CFR 120) 5
R Calibration of a frequency measurement device/frequency source General Measurement Device and Calibration Topics 2
R New Equipment Calibration and determination of Calibration Frequency General Measurement Device and Calibration Topics 8
M What is the recommended calibration frequency for gage blocks? Calibration Frequency (Interval) 2
M Extending Surface Plate Calibration Frequency General Measurement Device and Calibration Topics 3
Ajit Basrur Reduction of calibration frequency for CMM (coordinate measuring machine) General Measurement Device and Calibration Topics 9
H Determining Measurement (Measuring) Device Calibration Frequency Calibration Frequency (Interval) 36
K Calibration Frequency of a CMM Machine (Coordinate Measuring Machine) Calibration Frequency (Interval) 1
K Calibration Frequency for Leica Laser Tracker Calibration Frequency (Interval) 4
R Microwave Time and Frequency Calibration Measurement Uncertainty (MU) 11
T Basis for Calibration Method and Intervals (Frequency) - FAA approved repair station Federal Aviation Administration (FAA) Standards and Requirements 10
F Calibration Intervals (Frequency) for Stereoscopes, Microscopes, etc. Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
H Determining Calibration Frequency for Ammeters & Voltmeters used on the line Calibration Frequency (Interval) 7
N Calibration Frequency of Measurement and Test Devices Calibration Frequency (Interval) 26
R Calibration Intervals (Frequency) derived from Variables Data Calibration Frequency (Interval) 30
