Ran into an amusing situation and thought it worth passing on. My wife and I are both bread bakers. Among serious bread hobbyists there is a trend toward weighing the ingredients instead of using volume measures. King Arthur Flour sells a converting scale made by Escali. Using a conversion code from a provided chart you can switch between volume and weight. Seemed like a great idea so I bought one. When it arrived I tried to demonstrate how it worked by using a measured cup of water then converting it. I used a Pyrex 2 cup glass measuring cup as the receiving vessel and a Pyrex 1 cup glass measuring cup as the delivery vessel. I set the scale on grams, set the larger cup on the scale are tared it out, then poured in a measured 1 cup into the larger cup where it also read 1 cup. I pressed the volume button, punched in the code for water, 61, and to my surprise it read 3/4 cup. I repeated it several times with the same results.
This morning I called Escali Technical Support and he walked me through checking out the scale. First we checked the accuracy of the scale using nickles. US nickles weigh 5 grams each. The scale was accurate with nickles. Then we did what was done before with the Pyrex measuring cups with the same results as before. Then we weighted out 240 grams of water into the same larger Pyrex measuring cup. 240 grams is the correct weight for a cup of water. It showed 1 and 1/8 cup on the Pyrex cup. I repeated it with the Pyrex 1 cup and it also read 1 and 1/8 cup. So I took a stainless steel 1 cup measuring cup and tared it out, then poured 240 grams of water into it. It filled it right to the brim and the scale showed 1 cup.
It appears that Pyrex glass measuring cups don't have NIST calibration traceability. What a shame for a well know scientific glass provider.
