Calibration method for a Neptune 10 Water Meter
V
Van_H
Hi, Please help. :mg:
What is the correct procedure and/or equipment required to calibrate or verify a water meter?
BradM
Re: Water Meter
Van, can you explain a little more about your water meter, what it does, mfg/model, etc.? We'll try to help you figure something out.:yes:
V
Van_H
Re: Water Meter
Thanks Yeah.
This is the info copy/pasted
T-10 5/8” - 1”
Neptune T-10
n Meets or exceeds the latest AWWA C700 Standard
ANSI/NSF 61 certified
Nutating disc measuring chamber
Coury Ferguson
Moderator here to help
Its going to be used lots of times everyday so we want to verify it still meets the standard.
Maybe you want to consider out-sourcing the calibration.
The specification of the equipment was posted here:
DsqrdDGD909 said:
Why are you calibrating it?
Here is a link to the spec. http://www.neptunetg.com/uploadedFiles/NTG-240 PS T10SMALL 04.06.pdf
You will need to establish the change in the variation to the specification over a period of time (3 months or so) and determine if it falls out of stated specification requirements. If it doesn't than maybe a periodic maintenance schedule might be in order.
I would also call the Original Equipment Manufacturer (OEM) and ask them.
B Dosimeter Calibration Method General Measurement Device and Calibration Topics 5
L ISO 17025 Para. 5.4.5 - Method (Calibration Procedure) Validation Requirements ISO 17025 related Discussions 2
C One Inch Micrometer Calibration Method General Measurement Device and Calibration Topics 2
M Fixed Point Temperature Cells Calibration Method General Measurement Device and Calibration Topics 3
N Calibration Method of Dial Thermometer Gauges General Measurement Device and Calibration Topics 7
K Validation of an Analytical Method that relies on Multi-Variate Calibration General Measurement Device and Calibration Topics 7
A Calibration Method and Measurement Uncertainty General Measurement Device and Calibration Topics 5
D Calibration Process - What do they mean by "Check Method"? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
T ISO 17025 Clause 5.4.2 - Calibration and Test Method Requirements ISO 17025 related Discussions 6
D Calibration Method for Small Surface Plates (6" x 6") General Measurement Device and Calibration Topics 8
M Sorvall 100S Centrifuge Calibration - SOP (Method and Procedure) Needed General Measurement Device and Calibration Topics 5
Q Does this calibration method of a specific fixture make sense? General Measurement Device and Calibration Topics 7
M Calibration of Load Cells in devices by a comparison method General Measurement Device and Calibration Topics 13
S NPT Thread Calibration Method - NPT Taper Thread Plug Gages General Measurement Device and Calibration Topics 9
B Method for Calibration of Thread Plug Gauges General Measurement Device and Calibration Topics 13
B Planekator Calibration Method Details - Calibration of a Surface Plate General Measurement Device and Calibration Topics 6
V Internal Scale and Balance Calibration Method Tolerances and Limits General Measurement Device and Calibration Topics 4
T Basis for Calibration Method and Intervals (Frequency) - FAA approved repair station Federal Aviation Administration (FAA) Standards and Requirements 10
Icy Mountain ISO/TS 16949 Compliant Calibration Method - Laboratory Calibration Levels IATF 16949 - Automotive Quality Systems Standard 13
K Calibration method for Torque Wrench & AC gas leakage Tester General Measurement Device and Calibration Topics 4
M Calibration Method According to ISO Guide 25 General Measurement Device and Calibration Topics 5
T Anyone have an example of a calibration method validation procedure? General Measurement Device and Calibration Topics 4
lanley liao Question regarding the calibration of monitoring and measure equipment. Oil and Gas Industry Standards and Regulations 0
N IATF Calibration Lean in Manufacturing and Service Industries 3
Q Do these certificates of calibration meet ISO 9001 requirements for traceability to NIST? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
E Calibration Records needed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
D Limited Range Calibration - 5000 lb Industrial floor scale General Measurement Device and Calibration Topics 3
D Calibration of Small Scales General Measurement Device and Calibration Topics 26
I IQOQ or just initial calibration required? General Measurement Device and Calibration Topics 3
B Calibration in real life ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Ron Rompen Calibration by manufacturer ISO 17025 related Discussions 4
Q Calibration verification records 7.1.5.2.1 IATF 16949 - Automotive Quality Systems Standard 2
W Next Calibration Due Date Calibration Frequency (Interval) 5
A OEM On-Site Calibration issues during Covid19 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
M Calibration Certificate Result issued by an accredited external laboratory General Measurement Device and Calibration Topics 9
G Calibration of "Master Parts" Used as Gauges Calibration Frequency (Interval) 5
R Calibration lab environmental monitoring General Measurement Device and Calibration Topics 4
G Calibration of Rotronic probe but not digital readout? General Measurement Device and Calibration Topics 3
F Standard Calibration Procedures: Recommended Practice ISO 17025 related Discussions 0
