"Calibration Not Required" label requirements
Ajit Basrur
#11
Could you give me some examples of justification?
Thank you! :)
Calibration Not Required could be for an instrument that
  1. does not require calibration, like clocks for display purpose only or
  2. an instrument that requires calibration but due to its application (not for measurement), calibration is not required. This could be for the innumerable dial guages on the Utility systems
  3. self calibrating instruments, eg. FTIR Spectrophotometers
  4. patended pre-calibrated instruments - this is for spirometers
These are just few examples for justification.
L
lego55
#12
We have Master blocks sets that are calibrated regularly, but we also have "reference only" pins and blocks. How about these?
Thank you!
Ajit Basrur
#13
Thank you!
Sorry, I do not know about the Master Block and pins. Btw, does that fit any of the categories that I mentioned earlier ?
bobdoering
Stop X-bar/R Madness!!
#15
If they were made "For Reference Only" because the job they used them for is now obsolete and they did not want to maintain calibration on them to save costs, then that would be OK. But, they will need calibration again if they are used for qualifying product in the future.
L
lego55
#16
If they are verified by a calibrated instrument (mic, etc.) before use, does one still have to have the pins/blocks calibrated?
Thank you!
bobdoering
#17
Yes, if it is being used for product or process verification. And it has to be calibrated with an appropriate piece of equipment for the gage tolerance (such as 4:1 to 10:1 resolution to the gage tolerance being calibrated), reviewed for any damage (burrs, etc.), and documented. Verification is handy if you tend to mix up pins, and need to make sure you have the correct one, or if you have little calibration history, and want to track the gage condition more closely.
Richard Pike
#18
Hi everyone,
I have a quick question about calibration labels.
In our surveillance audit, we received a "Sensitive Point" indicating:
"Some test equipments are not calibrated and not identified as 'calibration not required'".
Are there any standard/official formats for the "Calibration Not Required" labels? Must I purchase these labels from a company who makes them or may I use say a standard white mailing label and print out my own "Calibration Not Required" label?
Thanks!
I believe your auditor got it wrong.
Test Equipment does not require calibration? If you make a decision based on the results of that equipment - then calibration IS required. (the extent of calibration is up to you to justify).
If you put labels on gauges to indicate their calibration status - and some don't have labels due to your scenario that its not required - then consider NOT having any labels on the gauges at all ! Control your gauges via gauge serial number from a central data base and the problem goes away.
Don't let anybody tell you that this is not possible (or the most efficient method) In my experience 80% of modern organizations no longer use the (very) old fashioned management tool of applying labels to gauges.
L
lego55
#19
A couple of questions:
1) could they be calibrated by us or do we need an accredited lab?
2) how long can the calibration intervals be for commonly used plug gages, pins, blocks, etc.?
Thank you again!
Richard Pike
#20
Thank you again!
How long is a piece of string?
There are so many variables. What is required is competence in the Calibration of Equipment. Have you considered outsourcing your calibration function? Not jsut Calibration - but the calibration Process!
I IQOQ or just initial calibration required? General Measurement Device and Calibration Topics 3
G Is repeatability required for equipment calibration? General Measurement Device and Calibration Topics 10
S Is Optical Parallel Set required calibration? ISO 17025 related Discussions 1
A Calibration required by OEM General Measurement Device and Calibration Topics 2
M Are model# and Serial # required on a calibration cert? General Measurement Device and Calibration Topics 4
H In-house device calibration record - Actual values obtained required? General Measurement Device and Calibration Topics 9
B Changing out Thermocouple - Is new calibration required? General Measurement Device and Calibration Topics 1
C ISO17025 for In-House Calibration Labs: Is it required? ISO 17025 related Discussions 30
Manix Calibration of Scales to Traceable Standards (Clause 7.6) - Required or Not Calibration Frequency (Interval) 6
A Is NIST traceability required if a Refractometer calibration is done in-house? Calibration Frequency (Interval) 6
S Is calibration of a weigh scale required? Calibration Frequency (Interval) 8
L Is calibration required for weighing scales used for shipping purposes ? Misc. Quality Assurance and Business Systems Related Topics 10
D Functional Test Fixtures - Calibration Required? Quality Manager and Management Related Issues 8
L Are Outside Calibration Companies required to NADCAP Certified? General Measurement Device and Calibration Topics 6
Q Engineering purchased a new Caliper - 7.6 - Initial Calibration Required? General Measurement Device and Calibration Topics 6
H When is Calibration not required? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 11
K Survey Meter Calibration - Accredited Laboratory required? General Measurement Device and Calibration Topics 5
S Required Complete calibration SOP, calibration Plan and master list template! IATF 16949 - Automotive Quality Systems Standard 3
B CMM Stylus Calibration - Required to record the As Found condition AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
M ISO 17025 - Recommended or Required and other Calibration questions ISO 17025 related Discussions 5
J Equipment required for a Dimensional Calibration Laboratory Document Control Systems, Procedures, Forms and Templates 1
A ISO 17020 Audit Findings - Calibration from Accredited Laboratory required Other ISO and International Standards and European Regulations 8
W Is an Oven I/O/Q Validation Required or is Calibration Sufficient? Qualification and Validation (including 21 CFR Part 11) 7
B Can I Claim That Periodic Calibration is Not Required? ISO 13485:2016 - Medical Device Quality Management Systems 6
R HP8481A Power Sensor Calibration - What standards are normally required? General Measurement Device and Calibration Topics 5
D TS 16949 In-House Calibration Requirements - Certification Required? IATF 16949 - Automotive Quality Systems Standard 26
L Is a Supplier Audit required for an ISO certified calibration company? Process Audits and Layered Process Audits 12
M Gage pin calibration - Actual calibration readings required on the calibration cert General Measurement Device and Calibration Topics 3
P Are we required to register to REACH? Small CMM service and calibration company RoHS, REACH, ELV, IMDS and Restricted Substances 3
E Recalculation of MU for Test Equipment after every Calibration required? Measurement Uncertainty (MU) 11
V Gage Calibration Stickers in harsh environments - Are Calibration Stickers Required General Measurement Device and Calibration Topics 14
A Is Calibration Required for Equipment/Devices Used for Measuring Support Services General Measurement Device and Calibration Topics 6
F What are the specifications required in the preparation of a calibration laboratory? General Measurement Device and Calibration Topics 4
S Calibration required? We buy part of our machined parts - Supplier gage calibration? General Measurement Device and Calibration Topics 6
C What type of Calibration is Required for TS16949? IATF 16949 - Automotive Quality Systems Standard 5
C Thermohygrometer Calibration - Number of Required Calibration Points General Measurement Device and Calibration Topics 13
A Are ISO 9001 certified companies required to use ISO17025 facilities for calibration? ISO 17025 related Discussions 13
S Is official MSA training required person performing calibration? IATF 16949 - Automotive Quality Systems Standard 6
B Weight class required for scale calibration General Measurement Device and Calibration Topics 2
D ISO/IEC 17025 required for a calibration lab to be ISO certified? ISO 17025 related Discussions 6
D Interesting Discussion Using "Not A Calibrated Device" or "No Calibration Required" stickers General Measurement Device and Calibration Topics 63
A Calibration Discrimination - Acceptance criteria is not having the accuracy required? General Measurement Device and Calibration Topics 2
K Should QS/TS certified internal test/calibration labs be required to be ISO17025 ISO 17025 related Discussions 16
K Dimensional Lab (CMM Room) vs. Physical Test/Calibration Lab - Same required temp/hum General Measurement Device and Calibration Topics 2
I Calibration Stickers on instruments are NOT required! General Measurement Device and Calibration Topics 28
Marc Required Calibration Certificate Contents General Measurement Device and Calibration Topics 2
D Level of accuracy required for the calibration of glass mercury thermometers General Measurement Device and Calibration Topics 6
lanley liao Question regarding the calibration of monitoring and measure equipment. Oil and Gas Industry Standards and Regulations 0
N IATF Calibration Lean in Manufacturing and Service Industries 3
