"Calibration Not Required" label requirements
bobdoering
Stop X-bar/R Madness!!
#31
I look forward to getting things set "right!" As usual, I won't be the most popular person here, but I'll feel much better getting them on track. "Popular" is overrated anyway, right?
It beats being unpopular for recalls or scrap from measuring with a gage that was out of specification from wear or damage - especially parts made from expensive raw materials.
At least that's what I think. :tg:
Richard Pike
#32
Thank you all for your great information and support!
:D
Can i I possibly repeat a few of the things that have been said and with due respect you seem to be ignoring.
a) If an instrument is used to make a decision on a product or process - then it SHALL be calibrated unless by contract you have implemented an alternative.
b) The Calibration frequency depends on your historical usage - and trend / wear patterns.
(In the absence of these, they should be "immediately" calibrated.
The subsequent frequency - you can worry about later! It is not an issue at the moment and wont be for some months!
If the gauges come back - worn (which may not be detectable as you appear not to know the original condition!) then based on the amount of wear, you can guesstimate a time for the next calibration.
If you don't know the original condition - you can at least assume that when the were introduced - they were in specification - and use this as a basis for guesstimating wear.
However - it may be viable to take a representative selection of the gauges for re-calibration after say 4 months - if no wear is detected then you may be able to assume that similar gauges will be OK and subsequently - calibrate a few more after say 8 months. You can then repeat this action on selected gauges until you are able to detect a wear history.
That,s one solution - however if your company still considers such action as too expensive - as they are "checked" against a customer product ( I cannot imagine how this works) you may be able to get your customer to agree, (in writing) that there master product can be used to verify the gauges.
The other question (which may have been asked - but I may have missed) is Are you getting any complaints / rejects from your customer?
So there you have it - some solid things that you can practically implement - or not!
L
lego55
#33
Richard,
We get a very small amount of rejections here; recent ones have been related to particular vendor processes, not the dimensions.
All of what you said is very helpful information and greatly appreciated! Thanks for getting me started on the right track and taking the time to respond. Wish me luck getting the pack to follow. I'm goin' in......:frust:
bobdoering
#34
We get a very small amount of rejections here...
That's good - want to keep it that way - and not just based on luck! :tg:
Remember this - for gages used very little (annual inspection, spares kept for use when gages are out for calibration, etc.), you maybe able to save money by extending the calibration period. If little or no wear is detected in the subsequent calibrations AND no new, more frequent use has been introduced to the gage, then you may have justification for extending the gage period. Don't calibrate - but lock up - gages not used, that also saves money. Just pay for the ones on the floor, and the spares you have for when the other gages are out for calibration.
L
lego55
#35
Thanks for the $-saving advice! We all can use it now.
:thanks:
F
Freddyg63
#36
"Calibration Not Required" should be acceptable, as long an adequate justification is included in your procedures.
The pins can act as "transfer" tools (like telescoping gages). You measure the pin with a calibrated micrometer and record that data.
SHall
#37
One advantage of using pre-printed labels, is that the person in possession of the labels is able to confirm the equipment should be labeled as Calibration Not Required, and that any requirements in the procedure (as other posts have described) have been met.
Been using these guys forever, no complaints:
http://www.gmplabeling.com/stock_labels/detail_item.php?product_id=172
For less than $100, you get a bit more control over what gets labeled.
I IQOQ or just initial calibration required? General Measurement Device and Calibration Topics 3
G Is repeatability required for equipment calibration? General Measurement Device and Calibration Topics 10
S Is Optical Parallel Set required calibration? ISO 17025 related Discussions 1
A Calibration required by OEM General Measurement Device and Calibration Topics 2
M Are model# and Serial # required on a calibration cert? General Measurement Device and Calibration Topics 4
H In-house device calibration record - Actual values obtained required? General Measurement Device and Calibration Topics 9
B Changing out Thermocouple - Is new calibration required? General Measurement Device and Calibration Topics 1
C ISO17025 for In-House Calibration Labs: Is it required? ISO 17025 related Discussions 30
Manix Calibration of Scales to Traceable Standards (Clause 7.6) - Required or Not Calibration Frequency (Interval) 6
A Is NIST traceability required if a Refractometer calibration is done in-house? Calibration Frequency (Interval) 6
S Is calibration of a weigh scale required? Calibration Frequency (Interval) 8
L Is calibration required for weighing scales used for shipping purposes ? Misc. Quality Assurance and Business Systems Related Topics 10
D Functional Test Fixtures - Calibration Required? Quality Manager and Management Related Issues 8
L Are Outside Calibration Companies required to NADCAP Certified? General Measurement Device and Calibration Topics 6
Q Engineering purchased a new Caliper - 7.6 - Initial Calibration Required? General Measurement Device and Calibration Topics 6
H When is Calibration not required? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 11
K Survey Meter Calibration - Accredited Laboratory required? General Measurement Device and Calibration Topics 5
S Required Complete calibration SOP, calibration Plan and master list template! IATF 16949 - Automotive Quality Systems Standard 3
B CMM Stylus Calibration - Required to record the As Found condition AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
M ISO 17025 - Recommended or Required and other Calibration questions ISO 17025 related Discussions 5
J Equipment required for a Dimensional Calibration Laboratory Document Control Systems, Procedures, Forms and Templates 1
A ISO 17020 Audit Findings - Calibration from Accredited Laboratory required Other ISO and International Standards and European Regulations 8
W Is an Oven I/O/Q Validation Required or is Calibration Sufficient? Qualification and Validation (including 21 CFR Part 11) 7
B Can I Claim That Periodic Calibration is Not Required? ISO 13485:2016 - Medical Device Quality Management Systems 6
R HP8481A Power Sensor Calibration - What standards are normally required? General Measurement Device and Calibration Topics 5
D TS 16949 In-House Calibration Requirements - Certification Required? IATF 16949 - Automotive Quality Systems Standard 26
L Is a Supplier Audit required for an ISO certified calibration company? Process Audits and Layered Process Audits 12
M Gage pin calibration - Actual calibration readings required on the calibration cert General Measurement Device and Calibration Topics 3
P Are we required to register to REACH? Small CMM service and calibration company RoHS, REACH, ELV, IMDS and Restricted Substances 3
E Recalculation of MU for Test Equipment after every Calibration required? Measurement Uncertainty (MU) 11
V Gage Calibration Stickers in harsh environments - Are Calibration Stickers Required General Measurement Device and Calibration Topics 14
A Is Calibration Required for Equipment/Devices Used for Measuring Support Services General Measurement Device and Calibration Topics 6
F What are the specifications required in the preparation of a calibration laboratory? General Measurement Device and Calibration Topics 4
S Calibration required? We buy part of our machined parts - Supplier gage calibration? General Measurement Device and Calibration Topics 6
C What type of Calibration is Required for TS16949? IATF 16949 - Automotive Quality Systems Standard 5
C Thermohygrometer Calibration - Number of Required Calibration Points General Measurement Device and Calibration Topics 13
A Are ISO 9001 certified companies required to use ISO17025 facilities for calibration? ISO 17025 related Discussions 13
S Is official MSA training required person performing calibration? IATF 16949 - Automotive Quality Systems Standard 6
B Weight class required for scale calibration General Measurement Device and Calibration Topics 2
D ISO/IEC 17025 required for a calibration lab to be ISO certified? ISO 17025 related Discussions 6
D Interesting Discussion Using "Not A Calibrated Device" or "No Calibration Required" stickers General Measurement Device and Calibration Topics 63
A Calibration Discrimination - Acceptance criteria is not having the accuracy required? General Measurement Device and Calibration Topics 2
K Should QS/TS certified internal test/calibration labs be required to be ISO17025 ISO 17025 related Discussions 16
K Dimensional Lab (CMM Room) vs. Physical Test/Calibration Lab - Same required temp/hum General Measurement Device and Calibration Topics 2
I Calibration Stickers on instruments are NOT required! General Measurement Device and Calibration Topics 28
Marc Required Calibration Certificate Contents General Measurement Device and Calibration Topics 2
D Level of accuracy required for the calibration of glass mercury thermometers General Measurement Device and Calibration Topics 6
lanley liao Question regarding the calibration of monitoring and measure equipment. Oil and Gas Industry Standards and Regulations 0
N IATF Calibration Lean in Manufacturing and Service Industries 3
