Calibration of 200 sets of Thread Ring Gages - Return them to the manufacturer?
G
Grizz1345
I am looking for feedback on how people approach the calibration of thread ring gages. My experience has been to return them to the manufacturer. I am really looking for a faster and more economical approach. I have approximately 200 sets of thread ring gages in my database. All comments would be appreciated.:)
D.Scott
We return our ring gages for calibration. Our schedule rotates the sets so we are never without calibrated sets.
I suppose, depending on the criticality if the measurement, you could verify the gages in-house. Buy a master set of calibrated plug gages and verify the ring gages internally. That way you would only need to send out the master for calibration. 200 sets may be pushing the limits of the master set though so you may have to calibrate it more often.
Dave
Crusader
Dave
Your suggestion would pass an ISO 9001:2000 audit?
Duke Okes
Rather than thinking of it as one set of 200 gages, think of it as 200 ring gages. Are all used at the same degree? If not, calibration could be set differently for various sizes, which might save a substantial amount.
Wes Bucey
FWIW:
My [relatively] small shop specializing in turning had as many as 20 or 30 tapered pipe thread ring gages for each size thread we ran, all mastered to the same plug master at the manufacturer (retained for our use only.) We had two or three on-site master plugs made as identical as possible to the manufacturer's master. We contracted with our customer to use gages also made and calibrated to the same master by our manufacturer. We would only have one ring gage for each machine running a specifc size thread. We would check each active gage every shift against our plug master. Any discrepancy got that ring taken out of service and cycled to the manufacturer for evaluation and either refurbished, calibrated and certified OR destroyed.
Because we had different size runs, setting refurbish/recalibrate by calendar instead of actual wear was not practical.
Our customers followed a similar policy. Having an ample inventory meant we ALWAYS had certified calibrated rings and never had to rush the manufacturer or deal with rings not calibrated to our "special" master.
OFF TOPIC::topic:
we used stepped gages for tapered threads. The link may not be the best explanation, but it's the first I googled. http://welcome.gsgage.com/Tech CD Rev 1.0a PDF/4.1_Pipes.pdf
G
Grizz1345
I can see that I need to ask the question a little differently. Is there another way to calibrate thread ring gages? I find that using "set masters" is very subjective. It is almost imperative that they be checked to the master used to manufacture them. I find it hard to believe that 2 people using the same master could come up with the exact same numbers when calibrating a thread ring gage. From what I have learned the pitch is never measured, it is more of a "feeling" on a set master. Am I beating a dead horse here?
Hershal
Metrologist-Auditor
Proper calibration of thread plugs, unless they are really really coarse, is accomplished using a supermic.....the environment is 20 C +/- 1 C, RH usually between 35-45%.....in other words.....
Send them to a calibration laboratory that is accredited to ANS/ISO/IEC 17025 for thread plugs, and have metrology professionals calibrate them.
The argument here for having metrology professionals calibrate your items instead of your folks calibrating them, is exactly the same as having machinists operate the CNC (or similar machines) instead of having the shipping clerk run them.....the metrology professionals have the proper equipment and environment, and the training and experience to make effective use of them.
Hope this helps.
Hershal
We calibrate the majority of ours in-house using master plugs. It works for us.:agree1:
Russ
Wes Bucey
I was always a great one for "division of labor" and never had any hesitation about outsourcing tasks outside of our core proficiencies. I could have easily put in a system to apply electroless nickel plating, but it would have meant nothing to our bottom line and very little to our quality, since we were very good at selecting competent suppliers of such service. Similarly, I have written elsewhere about dumping our grinding operation and getting better service in return.
Similarly, even with hundreds of plug and ring gages in addition to 3-wire mikes, snap ring gages, etc., I never found it cost-effective to even consider doing our own manufacture, refurbish, etc. It was sufficient for our purpose to check only active ring and plug gages against masters before each shift. If they didn't pass this perfunctory review, we put the problem in the hands of specialists and moved on to the next gage, since we only got paid for pieces we delivered to customers and preferred to devote our time and energy to that.
kedarg6500
We do not return thread gauges to the manufacturer. We have master thread plug gauges to check calibrated thread ring gauges & vice versa. All the gauges are spread over a year , hence we do not have issue of faster checking. It has not created any issue during ISO audit.
C Calibration of Torque Wrenches and Screwdrivers using Torque mate 200 General Measurement Device and Calibration Topics 4
lanley liao Question regarding the calibration of monitoring and measure equipment. Oil and Gas Industry Standards and Regulations 0
N IATF Calibration Lean in Manufacturing and Service Industries 3
Q Do these certificates of calibration meet ISO 9001 requirements for traceability to NIST? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
E Calibration Records needed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
D Limited Range Calibration - 5000 lb Industrial floor scale General Measurement Device and Calibration Topics 3
D Calibration of Small Scales General Measurement Device and Calibration Topics 26
I IQOQ or just initial calibration required? General Measurement Device and Calibration Topics 3
B Calibration in real life ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Ron Rompen Calibration by manufacturer ISO 17025 related Discussions 4
Q Calibration verification records 7.1.5.2.1 IATF 16949 - Automotive Quality Systems Standard 2
W Next Calibration Due Date Calibration Frequency (Interval) 5
A OEM On-Site Calibration issues during Covid19 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
M Calibration Certificate Result issued by an accredited external laboratory General Measurement Device and Calibration Topics 9
G Calibration of "Master Parts" Used as Gauges Calibration Frequency (Interval) 5
R Calibration lab environmental monitoring General Measurement Device and Calibration Topics 4
G Calibration of Rotronic probe but not digital readout? General Measurement Device and Calibration Topics 3
F Standard Calibration Procedures: Recommended Practice ISO 17025 related Discussions 0
T Temperature Requirements For In House Calibration - AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
Crimpshrine13 Laboratory Scope - Calibration vs. Test Methods - IATF 16949 IATF 16949 - Automotive Quality Systems Standard 3
Crimpshrine13 Calibration of pH Meter Probe Calibration and Metrology Software and Hardware 3
F ESD workbench "calibration" Manufacturing and Related Processes 2
F Nist traceable calibration certificates General Measurement Device and Calibration Topics 1
G Tool tracebility and First calibration requirements for aerospace (AS9100) organisation AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
D Calibration of Digital thermometer with surface probe General Measurement Device and Calibration Topics 1
T Calibration or Verification -> Cm and Cmk, etc. Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
G Is repeatability required for equipment calibration? General Measurement Device and Calibration Topics 10
was named killer AS 9100D - Calibration Instructions - Controlled documents? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
B Photovoltaic Tester Calibration General Measurement Device and Calibration Topics 0
B Temperature loop: partial calibration General Measurement Device and Calibration Topics 10
G Glass scale calibration at 74 degrees F? General Measurement Device and Calibration Topics 4
A Digital Timer Calibration Requirements General Measurement Device and Calibration Topics 3
Ron Rompen Barcode Verifier Calibration and Use Calibration and Metrology Software and Hardware 5
S Is Optical Parallel Set required calibration? ISO 17025 related Discussions 1
A Calibration of Power Supplies AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
D Calibration Process Flow Map Example Wanted General Measurement Device and Calibration Topics 3
M Calibration or Verification? What terminology to use ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
N Calibration Requirements for Production Equipment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
