I have a bulk tank, with weigh scale, that needs calibrated. Operating capacity is 3400lbs. The current calibration method is to empty tank, tare and calibrate using increments of 100lbs up to 500lbs. I know that standard calibration practice should be to calibrate with increments upto 3400lbs, but the equipment structure itself doesn't have the space to load the tank with 3400 lbs of weights.
What calibration method would you propose?
