Calibration of Bulk Tank with Scale - Operating capacity is 3400lbs
mlthompson
#11
Re: Bulk Tank Calibration
I am still trying to figure out your setup here. Is this tank on load cells? Or, is it permanently affixed to a scale? Like Jim asked, what capacity do you use this to will assist in determining how high you need to calibrate this.
We have a series of tanks. Some sit directly on load cells, some sit on scale platforms. Either way they are permanently installed.
#12
With your water supply, if you have a known supply that you will use just take a sample to an accredited lab and get the water certified for weight and gravity and once you have your supply certified then periodically you can sample and check it against your standard certified water supply.
Just audit you lab to make sure their instruments are calibrated and traceable!
BradM
#13
I have seen all kinds of setups. Some load cells can be pulled off and have weights placed on them. The output of the load cells can be measured.
Let’s face it… It’s hard verifying the accuracy of tanks/large weights.
mlthompson
#14
Well folks I was getting goose bumps for having a solution with using the water idea. The concern that came back from our process engineer is that after calibration, the water will be contaminated due to residual chemical from the tank and will have to be disposed of as hazardous material. Also, after calibration, any residual chemical still in tank will be saturated with water which will have adverse effects on future chemical blends.
BradM
#15
You could use the same setup with the chemicals you put into the tank.
It all boils down (to me) how accurate you really need to be. You could tank measurement dimensions and go off of volume, if you didn't need to be that accurate.
mlthompson
#17
I'm thinking the following:
  • Make chemical blend as normal
  • Drain chemical into secondary tote(s) sitting on calibrated scale
  • Pump chemical back into same tank in metered amounts
  • Calibrate tank scale at various increments
Does this sound legit?
DsqrdDGD909
#18
What is the chemical? Flow meter and specific gravity is still the way to go. What is the required accuracy? Over what range, with what needed precision? How do you currently clean the tank? Can it be heated?
Scott Catron
True Artisan
#19
Are the chemicals water soluble? Why would a minor amount of chemical contamination make the water a hazardous waste? Would it violate a discharge permit?
If the chamicals are water soluble and there's no problem with disposing of the water, using a calibrated flow meter would be the way to go.
This issue would be moot if the calibration company would do what you asked them to do - is there some reason they won't other then they think you don't have to? That's not really for them to decide.
You could write an SOP for calibration companies to follow when they calibrate your equipment.
Tim Folkerts
#20
Here is a table I found for the temperature dependence of density for pure water.
Temp (°C) Density (g/cm3)
30 0.9957
20 0.9982
10 0.9997
0 0.9998
If you can measure the temp to within a couple degrees, then the density will be correct to within 0.1%
Also, I don't know specifically about dnsity of tap water, but seawater is about 1.025 g/cm^3. Since this has much more dissolved solids than tap water, the different in density between pure water and tap water will be much less than this 0.25% difference.
And I just found another source at http://www.simetric.co.uk/si_water.htm
that suggests that tap water is practically idential in density to pure water.
On the other hand, why even bother with density? Wouldn't it be easier to just weight the water, rather than measure the volume?
Tim
lanley liao Question regarding the calibration of monitoring and measure equipment. Oil and Gas Industry Standards and Regulations 0
N IATF Calibration Lean in Manufacturing and Service Industries 3
Q Do these certificates of calibration meet ISO 9001 requirements for traceability to NIST? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
E Calibration Records needed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
D Limited Range Calibration - 5000 lb Industrial floor scale General Measurement Device and Calibration Topics 3
D Calibration of Small Scales General Measurement Device and Calibration Topics 26
I IQOQ or just initial calibration required? General Measurement Device and Calibration Topics 3
B Calibration in real life ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Ron Rompen Calibration by manufacturer ISO 17025 related Discussions 4
Q Calibration verification records 7.1.5.2.1 IATF 16949 - Automotive Quality Systems Standard 2
W Next Calibration Due Date Calibration Frequency (Interval) 5
A OEM On-Site Calibration issues during Covid19 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
M Calibration Certificate Result issued by an accredited external laboratory General Measurement Device and Calibration Topics 9
G Calibration of "Master Parts" Used as Gauges Calibration Frequency (Interval) 5
R Calibration lab environmental monitoring General Measurement Device and Calibration Topics 4
G Calibration of Rotronic probe but not digital readout? General Measurement Device and Calibration Topics 3
F Standard Calibration Procedures: Recommended Practice ISO 17025 related Discussions 0
T Temperature Requirements For In House Calibration - AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
Crimpshrine13 Laboratory Scope - Calibration vs. Test Methods - IATF 16949 IATF 16949 - Automotive Quality Systems Standard 3
Crimpshrine13 Calibration of pH Meter Probe Calibration and Metrology Software and Hardware 3
F ESD workbench "calibration" Manufacturing and Related Processes 2
F Nist traceable calibration certificates General Measurement Device and Calibration Topics 1
G Tool tracebility and First calibration requirements for aerospace (AS9100) organisation AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
D Calibration of Digital thermometer with surface probe General Measurement Device and Calibration Topics 1
T Calibration or Verification -> Cm and Cmk, etc. Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
G Is repeatability required for equipment calibration? General Measurement Device and Calibration Topics 10
was named killer AS 9100D - Calibration Instructions - Controlled documents? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
B Photovoltaic Tester Calibration General Measurement Device and Calibration Topics 0
B Temperature loop: partial calibration General Measurement Device and Calibration Topics 10
G Glass scale calibration at 74 degrees F? General Measurement Device and Calibration Topics 4
A Digital Timer Calibration Requirements General Measurement Device and Calibration Topics 3
Ron Rompen Barcode Verifier Calibration and Use Calibration and Metrology Software and Hardware 5
S Is Optical Parallel Set required calibration? ISO 17025 related Discussions 1
A Calibration of Power Supplies AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
D Calibration Process Flow Map Example Wanted General Measurement Device and Calibration Topics 3
M Calibration or Verification? What terminology to use ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
N Calibration Requirements for Production Equipment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
S Calibration Equipment Selection General Measurement Device and Calibration Topics 2
