Calibration of Cable & Antenna Tester: Site Analyzer
MALAYA - 2007
Hi!
I would like to set up a calibration system for calibrating, "Cable & Attenna Tester for Wireless System: Bird Site analyzer". Please suggest me the Reference Standards which can calibrate the following parameters:
1. RF Power
2. RF Frequency
3. VSWR, Return Loss
Your reply will be highly appreciated.
Sarju
BradM
Re: Calibration of Cable & Attenna Tester: Site Analyzer
Hello Sarju!
Welcome to the Elsmar Cove!:agree1:
First, just a few preliminary questions. How many units are you wanting to calibrate?
Would you not think that it would be better in the end to send them to a qualified lab and have them calibrate them?
Do you have the accuracy requirement listed?
Depending on what kind of equipment you are wanting to calibrate, it can get very expensive very quickly buying the standards that you need. You will need higher-order power/frequency sensing equipment.
Anyway, when you get a chance, drop a note and let us know a little more about your situation.
Stijloor
Hi!
1. RF Power
2. RF Frequency
Sarju
Hello Sarju,
I did a search and found a listing of various Site Analyzers manufactured by Bird Electronics Corporation.
Each of the product descriptions has a link to a downloadable manual (Pdf) that descibes the calibration method. The analyzer that I looked at has a "self calibration" routine described in Chapter 2. Have you looked at this site and info before?
Here is another collection of links you should look at.
Hope this helps a little. If not, let us know.
Stijloor.
MALAYA - 2007
Glad that u r trying to find something. I have gone through those site. The "self calibration" u r talking about is different. That is actually a zeroing or we can say its a lead compensation kind of function, which we need to do it everytime before using the instrument. I need the "Annual calibration method", to verify whether its specification are still within its limits. I tried to contact Bird, but not getting any reply.
Folks, please help me finding a solution!!!
BradM
Hello Sarju!
I'm pretty confident there are plenty of people to help you with a solution, but I for one will need some more information.
What are you trying to calibrate? Why are you interested in calibrating this instead of having a qualified vendor calibrate it?
Many times a MFG. of equipment will not be interested in providing information about servicing their equipment. It's easier, safer, and more profitable for them to have you send it back to them for service.
As far as setting up your own lab, one piece of test equipment can be $20,000 USD alone, not to mention it's annual calibration cost.
So when you can, please try to provide us answers to my previous questions and the like.
MALAYA - 2007
Dear Mr. Brad,
Thank you for your concern. We have almost 50 nos. of Site Master/ Analyzers. Therefore ,we are planning to set up an inhouse calibration lab. If we consider the cost& time to be spent, it is a better option than sending it all to the MFG. for annual calibration.
RF reference standard/source should have the capability to verify the following parameters:
1. RF Power (dBm)
2. RF Frequency (Hz)
3. Return Loss(dB)
4. VSWR
5. Attenuation
6. Bandwidth
7. Amplitude Modulation
8. Frequency Modulation
9. Phase Modulation
We are trying for Fluke 9640A RF Reference Source( 0.05dB accuracy), but till date Fluke is unable to establish the set up for VSWR/ Return Loss.
Hope, the informations may be of use in finding the best standard that can serve my purpose.
So, please drop your ideas and experiences in the field of RF calibration.
Sarju
Hershal
Metrologist-Auditor
Hi!
1. RF Power
2. RF Frequency
Sarju
Some additional questions.......
First, what are the applicable Standards (e.g., IEC 60101, IEC 60950, IEC 61010)?
Are you testing 1, 3, and 10 meters? Or only 1 and 3? Or.....?
Are you indoors or outdoors?
What is the anticipated frequency range and configuration type of the antenna(s)?
Do you have TDR/FDR equipment for the cables?
Some additional information is helpful.....
MALAYA - 2007
Dear Mr. Hershal,
You seems to be talking about testing of Antenna, may be I've created a confusion using the word Antenna Tester. I've as many as 50 nos. of RF Instruments called, " Site Analyzer( Make: Bird)" which is used for testing cable and antenna and I want to calibrate those Site analyzer using a right Reference Standard. But, unfortunately i dont have the calibration procedure or some alternate method to calibrate its parameters like, Power Level(dBm), VSWR, Return Loss etc.
Hope things are cleared now. So please drop your idea.
Sarju
BradM
Malaya, I'm not for sure, but I think what Hershal was trying to ask had to do with finding out about more of your application. The questions regarding the antennas are not to test the antenna, but to find out what kind of simulation should occur to the equipment hooked to the antenna. Make sense?
Per his response, what is the applicable procedures? Also, are you going to be testing this equipment in a controlled environment, or calibrating them in-place?
You might want to contact Bird again, and offer to pay for a calibration procedure for the meter. In the end, it might be worth it to you. Also, if you perform any American Government work, you can access GIDEP, and they probably have the applicable procedure.
Another suggestion would be to contract someone to come on-site. Pay them to help establish a procedure, identify the correct equipment, train you on how to properly calibrate it and such.
Just some more thoughts.
lanley liao Question regarding the calibration of monitoring and measure equipment. Oil and Gas Industry Standards and Regulations 0
N IATF Calibration Lean in Manufacturing and Service Industries 3
Q Do these certificates of calibration meet ISO 9001 requirements for traceability to NIST? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
E Calibration Records needed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
D Limited Range Calibration - 5000 lb Industrial floor scale General Measurement Device and Calibration Topics 3
D Calibration of Small Scales General Measurement Device and Calibration Topics 26
I IQOQ or just initial calibration required? General Measurement Device and Calibration Topics 3
B Calibration in real life ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Ron Rompen Calibration by manufacturer ISO 17025 related Discussions 4
Q Calibration verification records 7.1.5.2.1 IATF 16949 - Automotive Quality Systems Standard 2
W Next Calibration Due Date Calibration Frequency (Interval) 5
A OEM On-Site Calibration issues during Covid19 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
M Calibration Certificate Result issued by an accredited external laboratory General Measurement Device and Calibration Topics 9
G Calibration of "Master Parts" Used as Gauges Calibration Frequency (Interval) 5
R Calibration lab environmental monitoring General Measurement Device and Calibration Topics 4
G Calibration of Rotronic probe but not digital readout? General Measurement Device and Calibration Topics 3
F Standard Calibration Procedures: Recommended Practice ISO 17025 related Discussions 0
T Temperature Requirements For In House Calibration - AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
Crimpshrine13 Laboratory Scope - Calibration vs. Test Methods - IATF 16949 IATF 16949 - Automotive Quality Systems Standard 3
Crimpshrine13 Calibration of pH Meter Probe Calibration and Metrology Software and Hardware 3
F ESD workbench "calibration" Manufacturing and Related Processes 2
F Nist traceable calibration certificates General Measurement Device and Calibration Topics 1
G Tool tracebility and First calibration requirements for aerospace (AS9100) organisation AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
D Calibration of Digital thermometer with surface probe General Measurement Device and Calibration Topics 1
T Calibration or Verification -> Cm and Cmk, etc. Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
G Is repeatability required for equipment calibration? General Measurement Device and Calibration Topics 10
was named killer AS 9100D - Calibration Instructions - Controlled documents? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
B Photovoltaic Tester Calibration General Measurement Device and Calibration Topics 0
B Temperature loop: partial calibration General Measurement Device and Calibration Topics 10
G Glass scale calibration at 74 degrees F? General Measurement Device and Calibration Topics 4
A Digital Timer Calibration Requirements General Measurement Device and Calibration Topics 3
Ron Rompen Barcode Verifier Calibration and Use Calibration and Metrology Software and Hardware 5
S Is Optical Parallel Set required calibration? ISO 17025 related Discussions 1
A Calibration of Power Supplies AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
D Calibration Process Flow Map Example Wanted General Measurement Device and Calibration Topics 3
M Calibration or Verification? What terminology to use ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
N Calibration Requirements for Production Equipment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
S Calibration Equipment Selection General Measurement Device and Calibration Topics 2
