Calibration of Coating Thickness Standard
W
WilliamM
Hello all!
I need to calibrate a coating thickness standard. Our current procedure calls for using a certified thickness standard and a coating thickness gage, transferring the standard to the gage, and then measuring the UUT. I am looking to try to change this procedure. I haven't been able to find any decent information on the internet, and I have not been able to find any fourm posts here that deal with coating thickness standard calibration. Does anyone know of a good procedure or document standard that could assist me in this endeavor? Any advice is greatly appreciated.
andygr
The standard is the easy part. All you are doing is establishing a defined "air gap". Films are the most common items used to create this gap and can be measured using a micrometer. Use an anvil face the same size as your probe if at all possible since this will account for the same variations in the surface roughness of the substrate. Make sure you add a visual check for the shims since over time they get damaged and in the area of wrinkles, dents and such that thickness of the shim is no longer what it started out to be. I would go with "when in doubt throw it out" approach for visible damage.
The hard part is making sure that your substrate is "the same" under the shim you are using to calibrate. This applies to the part if you are calibrating directly on the part or a test piece used to simulate the part. Changes in conductivity, surface roughness and such can result in differing readings when in fact you might have exactly the same coating thickness. I would recommend that as part of the calibration performed to measure the part you also verify that the "zero" reading is verified.
jawadali29
Dear Mr. William,
I am facing the same issue as i have purchased coating thickness standards from elcometer but i was not able to find any 17025 accredited laboratory to calibrate these standards. Can you tell me what you have done finally for these standards?
W
WilliamM
We eventually had to settle for a rough comparison between our certified coating thickness standards and the UUT. We used a coating thickness gage as a transfer. I wasn't comfortable with it at all, but it was what our customer wanted. We had the same issue with Defelsko, as they would no longer certify coating thickness standards. The only other laboratory that we found that would certify the standards is in Australia, and I am not certain as to their accreditation status. I would agree with andygr and purchase a new coating thickness standard. That might aleviate headache in the future.
S Calibration of a Coating Thickness Gage General Measurement Device and Calibration Topics 3
Q Micrometers to Measure Coating Thickness - Failed Calibration Flatness & Parallelism General Measurement Device and Calibration Topics 9
lanley liao Question regarding the calibration of monitoring and measure equipment. Oil and Gas Industry Standards and Regulations 0
N IATF Calibration Lean in Manufacturing and Service Industries 4
Q Do these certificates of calibration meet ISO 9001 requirements for traceability to NIST? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
E Calibration Records needed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
D Limited Range Calibration - 5000 lb Industrial floor scale General Measurement Device and Calibration Topics 3
D Calibration of Small Scales General Measurement Device and Calibration Topics 26
I IQOQ or just initial calibration required? General Measurement Device and Calibration Topics 3
B Calibration in real life ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Ron Rompen Calibration by manufacturer ISO 17025 related Discussions 4
Q Calibration verification records 7.1.5.2.1 IATF 16949 - Automotive Quality Systems Standard 2
W Next Calibration Due Date Calibration Frequency (Interval) 5
A OEM On-Site Calibration issues during Covid19 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
M Calibration Certificate Result issued by an accredited external laboratory General Measurement Device and Calibration Topics 9
G Calibration of "Master Parts" Used as Gauges Calibration Frequency (Interval) 5
R Calibration lab environmental monitoring General Measurement Device and Calibration Topics 4
G Calibration of Rotronic probe but not digital readout? General Measurement Device and Calibration Topics 3
F Standard Calibration Procedures: Recommended Practice ISO 17025 related Discussions 0
T Temperature Requirements For In House Calibration - AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
Crimpshrine13 Laboratory Scope - Calibration vs. Test Methods - IATF 16949 IATF 16949 - Automotive Quality Systems Standard 3
Crimpshrine13 Calibration of pH Meter Probe Calibration and Metrology Software and Hardware 3
F ESD workbench "calibration" Manufacturing and Related Processes 2
F Nist traceable calibration certificates General Measurement Device and Calibration Topics 1
G Tool tracebility and First calibration requirements for aerospace (AS9100) organisation AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
D Calibration of Digital thermometer with surface probe General Measurement Device and Calibration Topics 1
T Calibration or Verification -> Cm and Cmk, etc. Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
G Is repeatability required for equipment calibration? General Measurement Device and Calibration Topics 10
was named killer AS 9100D - Calibration Instructions - Controlled documents? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
B Photovoltaic Tester Calibration General Measurement Device and Calibration Topics 0
B Temperature loop: partial calibration General Measurement Device and Calibration Topics 10
G Glass scale calibration at 74 degrees F? General Measurement Device and Calibration Topics 4
A Digital Timer Calibration Requirements General Measurement Device and Calibration Topics 3
Ron Rompen Barcode Verifier Calibration and Use Calibration and Metrology Software and Hardware 5
S Is Optical Parallel Set required calibration? ISO 17025 related Discussions 1
A Calibration of Power Supplies AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
D Calibration Process Flow Map Example Wanted General Measurement Device and Calibration Topics 3
M Calibration or Verification? What terminology to use ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
