Calibration of Digital thermometer with surface probe
Dongzkie
Hello Sir, please need a little bit of help. I have a Digital thermometer with surface probe and my question is, is it necessary to calibrate the digital thermometer together with the probe as loop calibration? Or is it just okay to calibrate the digital thermometer alone without the probe?
thanks in advance
dwperron
It depends on what you are looking for.
Most people calibrate the meter only, the sticker on the meter makes it look like you are using a calibrated instrument. But unless you account for the accuracy of the probe you really know nothing about your measurement accuracy. For instance, a type K probe can add up to ± 2.2°C error to your measurements. This measurement can be accurate enough in a lot of cases.
If you want or need more accuracy in your measurements the optimal method is to calibrate them as a system and keep them as a system. But most users want to be able to use multiple probes on each meter, so this doesn't really work.
If you have multiple probes my suggestion would be to calibrate the meter and probes separately, and apply the offsets for the probe that you are using.
G Calibration of Rotronic probe but not digital readout? General Measurement Device and Calibration Topics 3
A Digital Timer Calibration Requirements General Measurement Device and Calibration Topics 3
D AMS 2750E - Digital Instrument Calibration Accuracy Requirements General Measurement Device and Calibration Topics 1
A Automated calibration of Digital Multimeter without communication port Calibration and Metrology Software and Hardware 2
D Hand-held Digital Tension Meter Calibration General Measurement Device and Calibration Topics 1
J Digital Scale Re-Calibration Interval Frequency General Measurement Device and Calibration Topics 10
M Calibration of Digital Panel Meters General Measurement Device and Calibration Topics 4
W Digital Multi-Meter Calibration Procedure for various Meter Brands and Functions General Measurement Device and Calibration Topics 7
A Fluke Digital MultiMeter Calibration Traceability and Certificate General Measurement Device and Calibration Topics 11
N Thermocouple Calibration - Digital Display vs. Converting the Millivolt into ?C General Measurement Device and Calibration Topics 8
N Digital Temperature Indicator Calibration (Thermocouple) - Using a reference junction General Measurement Device and Calibration Topics 1
T In-House Calibration - Digital Micrometer found Out of Calibration General Measurement Device and Calibration Topics 10
V Calibration of a Digital Vernier - Need to check/calibrate/validate all 3 functions? General Measurement Device and Calibration Topics 9
B Tolerance for Digital Indicator Calibration - Machinists Indicators General Measurement Device and Calibration Topics 1
T Calibration of a digital usb temprature probe. General Measurement Device and Calibration Topics 3
O Calibration Supplier needed for Digital Temperature/Pressure Controllers General Measurement Device and Calibration Topics 6
O Calibration tolerances needed - Calipers, digital indicators, feeler gages, etc General Measurement Device and Calibration Topics 4
S Safeguarding Calibration on Digital Equipment General Measurement Device and Calibration Topics 25
F Digital Multimeter - Verification vs. Calibration MSA (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
J Digital Caliper Calibration vs. Verification - Full Scale vs. Used Range General Measurement Device and Calibration Topics 8
C Is calibration of digital panel important in any semicon company? General Measurement Device and Calibration Topics 3
M Calibration of Timers to NIST - How are digital and analog timers calibrated? General Measurement Device and Calibration Topics 15
lanley liao Question regarding the calibration of monitoring and measure equipment. Oil and Gas Industry Standards and Regulations 0
N IATF Calibration Lean in Manufacturing and Service Industries 3
Q Do these certificates of calibration meet ISO 9001 requirements for traceability to NIST? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
E Calibration Records needed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
D Limited Range Calibration - 5000 lb Industrial floor scale General Measurement Device and Calibration Topics 3
D Calibration of Small Scales General Measurement Device and Calibration Topics 26
I IQOQ or just initial calibration required? General Measurement Device and Calibration Topics 3
B Calibration in real life ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Ron Rompen Calibration by manufacturer ISO 17025 related Discussions 4
Q Calibration verification records 7.1.5.2.1 IATF 16949 - Automotive Quality Systems Standard 2
W Next Calibration Due Date Calibration Frequency (Interval) 5
A OEM On-Site Calibration issues during Covid19 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
M Calibration Certificate Result issued by an accredited external laboratory General Measurement Device and Calibration Topics 9
G Calibration of "Master Parts" Used as Gauges Calibration Frequency (Interval) 5
R Calibration lab environmental monitoring General Measurement Device and Calibration Topics 4
F Standard Calibration Procedures: Recommended Practice ISO 17025 related Discussions 0
T Temperature Requirements For In House Calibration - AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
