Calibration of Load Cells in devices by a comparison method
Mohammed Gouda
Good morning my friends....
I am really confused and i want some help from your experts...
I want to make a calibration for a load cell but it is found in universal testing machine by a comparison method....but some problems face me:
1-I don't have the suitable standard method for this kind of calibration..
2-This load cell reach to 5000 N for calibration... it isn't reasonable to hang 500 KG for this calibration,so:what will be the compensation for these loads...i heared about "Tensile Coupling"but i don't have enough info. about it....
Please help me....
Best regards...
Mohammed Gouda....:bigwave:
SteveK
When I used to run a physical test laboratory I used calibrated weights (to traceable standards – in the UK to UKAS or NAMAS certification) to do a weekly test on my Instron Universal Tensile Tester. I had interchangeable load cells, so I had a series of weights which I hung from the particular cell – 50, 500, 1000N and so on. I had the cells also tested every 6 months by a test house. An engineer came in and basically did exactly the same thing and issued a certificate.
By the way your 500kg weight should register 4903.325N on the machine.
I hope this helps.
Hershal
Metrologist-Auditor
For a suitable method that doubles as a procedure, I would use ASTM E 4.
You can acquire it at www.astm.org and in the search box type in e4
The newest edition I believe has both metric and non-metric.
This will describe calibration of the UTM with the load cell installed.
You will need a load cell to calibrate the installed cell, and it should be calibrated using ASTM E 74.
DavidPhillips
You will need to use calibrated master cells and associated electronic displays for larger forces.
Most testing machines suppliers can offer a calibration service and can adjust the system to meet the accuracies specified in the Standards if that is required.
I think the most common calibration standard is ISO 7500 which allows calibration to Class 0.5. If you would like more information please contact me.
Stijloor
I found these:
Stijloor.
Hershal
Metrologist-Auditor
David and Stiljoor have given good information. You might look to see if Egypt has adopted the ISO document, as many of the Egyptian Standards are either ISO or BS documents, and so it may already be there as an Egyptian document also.
DavidPhillips
The correct Standard for Universal Testing Machines is ISO 7500-1:2004 as the ISO 7500-2:2006 Standard is for creep testing machines.
The BS (British Standard) was BS1610 and I think that this was superceded by the ISO some years ago.
BradM
Please help me....
Best regards...
Just a quick point, here. Make sure you test your equipment within the range that you use it. If you test below your use range, you could run into problems.
You can also pull off the cells, turn them on its back, and place the weights on top of them.
DavidPhillips
I think this is not correct advice: first we are talking about 500kg! (think about safety), and second you are then subjecting the load cell to compressive force. The Original Poster talked about "hanging weights" therefore I assume she wants to calibrate in tension. In certain circumstances there can be some differences between calibration in tension and compression using the advice you gave.
BradM
Thank you! I appreciate you correcting that train of thought. I was thinking primarily about force, not tension. You are correct.:agree1:
I have (and do) verify force cells with the manner that I prescribed; however, it does not work for tension.:D
I have seen test rigs, though, for such tests. They take the cell out and place in a frame. The frame has a platform on it. They load the pallet and weight on it to test.
Your caution about safety is a good one, though.:yes: I would be tempted to call in a competent lab for this.
I've just got burned so many times by not testing devices in the true range of use (reduced max loads).
D Calibration of Load Cells - ISO 17025 & MSA (Measurement Systems Analysis) ISO 17025 related Discussions 5
N Damaged Load Cell After Calibration - Who Should Pay? General Measurement Device and Calibration Topics 3
D Calibration Standard of Load Indicating Device General Measurement Device and Calibration Topics 4
W Force Calibration - In-House Load Cell Calibration General Measurement Device and Calibration Topics 7
S Calibration of Load Cell using Compression Machine as Comparator General Measurement Device and Calibration Topics 5
I Procedure for Calibration of my Load Cell Testing Equipment - Needed General Measurement Device and Calibration Topics 5
lanley liao Question regarding the calibration of monitoring and measure equipment. Oil and Gas Industry Standards and Regulations 0
N IATF Calibration Lean in Manufacturing and Service Industries 3
Q Do these certificates of calibration meet ISO 9001 requirements for traceability to NIST? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
E Calibration Records needed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
D Limited Range Calibration - 5000 lb Industrial floor scale General Measurement Device and Calibration Topics 3
D Calibration of Small Scales General Measurement Device and Calibration Topics 26
I IQOQ or just initial calibration required? General Measurement Device and Calibration Topics 3
B Calibration in real life ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Ron Rompen Calibration by manufacturer ISO 17025 related Discussions 4
Q Calibration verification records 7.1.5.2.1 IATF 16949 - Automotive Quality Systems Standard 2
W Next Calibration Due Date Calibration Frequency (Interval) 5
A OEM On-Site Calibration issues during Covid19 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
M Calibration Certificate Result issued by an accredited external laboratory General Measurement Device and Calibration Topics 9
G Calibration of "Master Parts" Used as Gauges Calibration Frequency (Interval) 5
R Calibration lab environmental monitoring General Measurement Device and Calibration Topics 4
G Calibration of Rotronic probe but not digital readout? General Measurement Device and Calibration Topics 3
F Standard Calibration Procedures: Recommended Practice ISO 17025 related Discussions 0
T Temperature Requirements For In House Calibration - AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
Crimpshrine13 Laboratory Scope - Calibration vs. Test Methods - IATF 16949 IATF 16949 - Automotive Quality Systems Standard 3
Crimpshrine13 Calibration of pH Meter Probe Calibration and Metrology Software and Hardware 3
F ESD workbench "calibration" Manufacturing and Related Processes 2
F Nist traceable calibration certificates General Measurement Device and Calibration Topics 1
G Tool tracebility and First calibration requirements for aerospace (AS9100) organisation AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
D Calibration of Digital thermometer with surface probe General Measurement Device and Calibration Topics 1
T Calibration or Verification -> Cm and Cmk, etc. Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
G Is repeatability required for equipment calibration? General Measurement Device and Calibration Topics 10
was named killer AS 9100D - Calibration Instructions - Controlled documents? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
B Photovoltaic Tester Calibration General Measurement Device and Calibration Topics 0
B Temperature loop: partial calibration General Measurement Device and Calibration Topics 10
G Glass scale calibration at 74 degrees F? General Measurement Device and Calibration Topics 4
A Digital Timer Calibration Requirements General Measurement Device and Calibration Topics 3
Ron Rompen Barcode Verifier Calibration and Use Calibration and Metrology Software and Hardware 5
