Greetings,
Our plant uses several Master Parts to check production. These are "known" good parts used for simple fit tests against the production parts. In most cases, the production parts will mate with other parts that are the same type as the Master Part out in the field. There is a dimensional criteria to these. Additionally, the production parts are checked regularly using micrometers and other more formal measuring devices. The Master parts exist as a "Quick Check" that can be used by an operator. I am in the process of writing a procedure to document calibration (verification may be a better term) of these Master parts. What are your thoughts on what to verify? Also, the parts being made are about as low-tech as you can get. No moving parts, no circuits.
Thank you in advance.
G
G
