Calibration of Pin Gages - What are my options?
Montserrat P
I have a doubt with regard to this case:
We are using pin gages to measure dimensions of a part numbers. However, I have detected that the pin gages were not in our calibration system. I request something that validate the accurancy and reliability of that pin gages. Therefore, I would like to know which is the best procedure to accomplish with it.
Option: Request to the manufacturer of the pin gages the calibration certificate of each pin gage that was bought.
Option: Request to the manufacturer a new set of pin gages with the certification certificate and use them as "our standard" for the next pin gages that we could need.
Option: Take the dimensions of a pin gage and make a drawing of it. Then, the calibration technician could verify that dimensions of the pin gages in the area vs the mesauring of fthe drawing.
Which is the best option?
I would like to know your comments with regard it.
Bubba
If you are using the pin gages to measure product, they should definitely be included in the calibration system.
Unless your individual pin gages were originally calibrated by the manufacturer and serialized, it is doubtful that the manufacturer will have any information for you. Even if they did, if the pins have been used for any length of time, it would be beneficial to have them calibrated again to make sure that they are still within tolerance.
Ordering a new set of calibrated pin gages is certainly an option, but then you will still be left with uncalibrated pins that will have to be thrown away or strictly segregated from the calibrated pins to avoid accidental use. A better alternative would probably be to send the original pins to an approved calibration laboratory to have them calibrated. This gives you the additional benefit of knowing whether any of the pins you have already been using are out of tolerance.
If you have the capability to verify the dimensions of the pin gages within the acceptable tolerance, this is probably the best option. You will need to make sure that whatever you are using as a standard to measure the pins has greater accuracy, resolution and precision than the pin gages themselves. If that is not the case, it would probably be better to send them to someone else.
CarolX
what we do
I have a large set of pin gages (.061" to .750"). I have my system set-up to check each pin before use with a micrometer. Thus I avoid having to send them out for calibration. I've used this system for several years and it works well.
CarolX
MsHeeler
Question: Is ASME B89.1.5-1998 a standard or a guidline? I need evidence if it is a standard.
N
NWrubberQA
Re: what we do
Carol, do you document your pin gage verification prior to use? If so, how have you done that. We just had a finding becuse we do not document the verification.
D Calibration of Pin Gages using a Calibrated Caliper that measures to 4 decimal places General Measurement Device and Calibration Topics 15
N Calibration of Setup Fixtures & Pin Gages General Measurement Device and Calibration Topics 5
D Nonadjustable M&TE - 10 year calibration interval? Pin Gages Calibration Frequency (Interval) 11
J Calibration of Pin Gages - AS9100 Calibration Requirements General Measurement Device and Calibration Topics 23
C Black Oxide Gage Pin Calibration Requirements General Measurement Device and Calibration Topics 4
W Setting up a Zmike for Pin Gage Calibration General Measurement Device and Calibration Topics 3
C ZZ Pin Gage Tolerances and Calibration General Measurement Device and Calibration Topics 2
S Pin Gage Calibration - Pins seem to be "growing" General Measurement Device and Calibration Topics 9
K Pin Gage Use vs. Calibration Frequency Calibration Frequency (Interval) 13
M Gage pin calibration - Actual calibration readings required on the calibration cert General Measurement Device and Calibration Topics 3
C Gage pin calibration procedure for accurately calibrating gage pins General Measurement Device and Calibration Topics 18
B Pin Gage Calibration Procedure - ISO 17025:2005 accreditation requirements? ISO 17025 related Discussions 8
V Calibration of Pin Gauges General Measurement Device and Calibration Topics 2
C Pin Gauge Calibration using a Micrometer - Accuracy & Calibration Level Question General Measurement Device and Calibration Topics 10
C Internal Diameter Measurement and Pin Gage Calibration General Measurement Device and Calibration Topics 6
L Gage Pin Gauge R&R - Our calibration guy said he doesn't know how to do one Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 21
N Seeking Procedure(s) - Methodology: Calibration of Pin Gauges General Measurement Device and Calibration Topics 9
N Pin Gage Sets - Calibration costs - Just buy new ones? General Measurement Device and Calibration Topics 9
J Calibration, should we.... Go-No-Go, thread, pin, and ring gauges QS-9000 - American Automotive Manufacturers Standard 2
lanley liao Question regarding the calibration of monitoring and measure equipment. Oil and Gas Industry Standards and Regulations 0
N IATF Calibration Lean in Manufacturing and Service Industries 4
Q Do these certificates of calibration meet ISO 9001 requirements for traceability to NIST? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
E Calibration Records needed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
D Limited Range Calibration - 5000 lb Industrial floor scale General Measurement Device and Calibration Topics 3
D Calibration of Small Scales General Measurement Device and Calibration Topics 26
I IQOQ or just initial calibration required? General Measurement Device and Calibration Topics 3
B Calibration in real life ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Ron Rompen Calibration by manufacturer ISO 17025 related Discussions 4
Q Calibration verification records 7.1.5.2.1 IATF 16949 - Automotive Quality Systems Standard 2
W Next Calibration Due Date Calibration Frequency (Interval) 5
A OEM On-Site Calibration issues during Covid19 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
M Calibration Certificate Result issued by an accredited external laboratory General Measurement Device and Calibration Topics 9
G Calibration of "Master Parts" Used as Gauges Calibration Frequency (Interval) 5
R Calibration lab environmental monitoring General Measurement Device and Calibration Topics 4
G Calibration of Rotronic probe but not digital readout? General Measurement Device and Calibration Topics 3
F Standard Calibration Procedures: Recommended Practice ISO 17025 related Discussions 0
T Temperature Requirements For In House Calibration - AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
Crimpshrine13 Laboratory Scope - Calibration vs. Test Methods - IATF 16949 IATF 16949 - Automotive Quality Systems Standard 3
Crimpshrine13 Calibration of pH Meter Probe Calibration and Metrology Software and Hardware 3
