Calibration of Scales for Weigh Counting
red53angel
First, I would like to say that I have gotten a lot of my ISO questions answered by searching this forum. It is a wonderful resource.
However, I have not found a concise answer to my current question.
My company makes very small parts which are weigh counted to fill orders. Depending on the size of the parts, we count out anywhere from 25 to 150 pieces and weigh them. Once that weight is determined, we enter the count on the scales and then continue adding parts until the desired quantity is achieved.
The argument against calibration is that it does not matter if the scales are accurate, meaning that if it weighed, say 100 pieces at 25g or 25kg would be irrelevant. We do not care what they actually weigh, we are just obtaining a count.
We are working towards ISO 9001 certification, if that makes a difference.
Please let me know your opinion as well as your argument for your opinion.
L
lrowe
You may run into a problem if the uncalibrated scale has a non linear error in it's measurement, that is if the weight error percent is greater when the load is heavier. When you set up the counting function, the scale just assumes the weight divided by the number of pieces you enter is a good average weight per piece. If the scale has some weight measurement error that was not know because of no calibration being run, well that no loner will provide an accurate count. If you depend on this count to fulfill a customer requirement, in this case the number of pieces required, you are obligated to make sure the reading is reliable.
Hope this helps
Larry
WCHorn
Rubber, Too Glamorous?
We use scales for small-parts counting too. We use a two station set up, where a five-pound load cell is used for the sampling, and a separate-but-connected 50-pound platform scale is used to count the parts. We calibrate both because they are separate load cells; an error on either one would affect the count. Do you use a similar set up or is the same scale used for both sampling and counting? If so, I recommend calibrating both.
Regarding ISO, you are required to calibrate devices used to determine product conformance. If you take a wider view of product conformance to include the quantity shipped as specified by the order, then the scale must be calibrated. That calibration need not verify the accuracy of the scale to absolute weights, but the accuracy of the count. You need to demonstrate the accuracy of the count, perhaps by periodic checks of count accuracy using the full range of the scale. You need not worry about the absolute weights, unless of course you use the scale for that purpose. If you’re not going to use it for absolute weights, I’d put a permanent notice to that effect on the scale.
I’ve seen this advice many times on the Cove and I’ll echo it here: when in doubt, calibrate. You have two customers you want to satisfy, the user and the end customer. I’ve found that users have more faith in their counting scales if they are periodically checked for accuracy. Accurate counts help customer satisfaction also.
Daniel Walker - 2011
The above responses have hit the nail on the head.... kudos. You definately need accredited calibrations done on the scales. (Accredited) Calibration service providers do more than just put a weight on an write down a number. You should be getting a fairly comprenensive test which follows nationally recognized or validated procedures. This serves as a preventative maintenance routine which prolongs the life and accuracy of the scale by identifying potential problems before they do harm to the process.
:2cents:
jfgunn
The responses thus far have been great. It is true that a counting scale that only has one platform will often count accurately even if the scale is not calibrated. This is true if the error is linear. Most errors found on scales are linear. Note that i said "most" and not all, therefore you shold have them calibrated.
If you have a dual base system where the sample is made on a small scale and the parts are counted on the larger scale, it is imperative to have both calibrated.
Counting Scales are like cash registers. Parts are money and you would would want your money counting machine to be accurate.
Typically the cost of scale calibration is relatively small when you look at the possilibty of losing inventory. Note that you can provide your customer extra parts all day long and they probably won't call you. If you short them parts once, they will call.
Be sure to use a large enough sample size to get a true part average. If the parts are likely to vary a larger sample would be appropriate. Of course as you increase your sample size, you likelyhood of counting the sample incorrectly increases. Counting scales are pretty smart. Lets say you want to fill boxes to 100 parts. If you tell the scale that the sample has 25 parts but you only count out 24 parts, the boxes will get 96 parts every time.
Hope this helps a bit.
You've had some great answers here! As you proceed towards registration, I hope that the person/people arguing against calibration of these scales are not responsible for process controls or for aspects of the calibration system!
You may wish to take some 'competency adjusting' action with them! It would be very unfortunate if their 'opinion' of the need for calibration 'came out' during an audit! And, in some ways, a few answers here, while a great place to start with the rationalization of such calibrations, it won't change a person's mind - if they were already thinking like that!
merrick65
I didn't see this mentioned ablove; but I may have missed it. The only part of a counting scale that is legal for trade is the actual weighing; the counting function is not legal for trade. Also look for the accuracy of the counting function you will not find it the accuracy; the accuracy is for the weighing. It's very hard to get a manufacturer to say what the counting accuarcy is (in my opinion). Also the old saying you get what you pay for is correct for this. Do not use a cheap counting scale; spend a some more cash and buy a nice one. I have always had luck using a PC820 from weigh-tronix (I do not work for them). I would also use a small capacity counting scale in tandem with the larger scale as mentioned above. I am a certified scale technician through the state of Illinois.
red53angel
Thank you, thank you. Armed with good information I will be able to make a logical, sound argument for calibration. I was sure it needed to be calibrated, but they were wearing me down and making me second guess myself.
We are using a single scale. We have 4 at different locations. (Setra 500, 1000, 2000, and 5000)
The procedure in place when I started here in September requires that the Setra 5000 not be used to fill orders because it is inaccurate. Actually states that in the procedure!! That will be my next battle when I tell them they have to get it fixed or get rid of it.
Thanks again for all your help.
Mary
rmf180
As always, great advice offered from the group!:applause:
As an additional resource, I am attaching a MS Excel worksheet which will tell you if your scale is capable of measuring the parts you are attempting to measure. When dealing with small parts (light), one must use an appropriate size scale. Many times small parts weigh less than the scales error which results in inaccurate counts.
J Should weigh count scales be in the Calibration System? QS-9000 - American Automotive Manufacturers Standard 4
D Calibration of Small Scales General Measurement Device and Calibration Topics 26
Manix Calibration of Scales to Traceable Standards (Clause 7.6) - Required or Not Calibration Frequency (Interval) 6
A Calibration of Disposable Weight Scales General Measurement Device and Calibration Topics 2
L Is calibration required for weighing scales used for shipping purposes ? Misc. Quality Assurance and Business Systems Related Topics 10
D Single-Point Scale Calibration - Very Large Scales General Measurement Device and Calibration Topics 3
WEAVER Calibration of Measuring Instrument by Adjustment of its Scales IATF 16949 - Automotive Quality Systems Standard 2
F How to calculate the minimum Value of Mass needed for Scales Calibration? General Measurement Device and Calibration Topics 6
C SPC for calibration check data? Daily gram scales check - What is acceptable? Statistical Analysis Tools, Techniques and SPC 5
J UPS owned shipping carton weight scales - Include this in my Calibration system? General Measurement Device and Calibration Topics 9
lanley liao Question regarding the calibration of monitoring and measure equipment. Oil and Gas Industry Standards and Regulations 0
N IATF Calibration Lean in Manufacturing and Service Industries 3
Q Do these certificates of calibration meet ISO 9001 requirements for traceability to NIST? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
E Calibration Records needed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
D Limited Range Calibration - 5000 lb Industrial floor scale General Measurement Device and Calibration Topics 3
I IQOQ or just initial calibration required? General Measurement Device and Calibration Topics 3
B Calibration in real life ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Ron Rompen Calibration by manufacturer ISO 17025 related Discussions 4
Q Calibration verification records 7.1.5.2.1 IATF 16949 - Automotive Quality Systems Standard 2
W Next Calibration Due Date Calibration Frequency (Interval) 5
A OEM On-Site Calibration issues during Covid19 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
M Calibration Certificate Result issued by an accredited external laboratory General Measurement Device and Calibration Topics 9
G Calibration of "Master Parts" Used as Gauges Calibration Frequency (Interval) 5
R Calibration lab environmental monitoring General Measurement Device and Calibration Topics 4
G Calibration of Rotronic probe but not digital readout? General Measurement Device and Calibration Topics 3
F Standard Calibration Procedures: Recommended Practice ISO 17025 related Discussions 0
T Temperature Requirements For In House Calibration - AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
Crimpshrine13 Laboratory Scope - Calibration vs. Test Methods - IATF 16949 IATF 16949 - Automotive Quality Systems Standard 3
Crimpshrine13 Calibration of pH Meter Probe Calibration and Metrology Software and Hardware 3
F ESD workbench "calibration" Manufacturing and Related Processes 2
F Nist traceable calibration certificates General Measurement Device and Calibration Topics 1
G Tool tracebility and First calibration requirements for aerospace (AS9100) organisation AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
D Calibration of Digital thermometer with surface probe General Measurement Device and Calibration Topics 1
T Calibration or Verification -> Cm and Cmk, etc. Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
G Is repeatability required for equipment calibration? General Measurement Device and Calibration Topics 10
was named killer AS 9100D - Calibration Instructions - Controlled documents? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
B Photovoltaic Tester Calibration General Measurement Device and Calibration Topics 0
B Temperature loop: partial calibration General Measurement Device and Calibration Topics 10
