Calibration of Small Scales
duff999
Looking for calibration advice.
We are looking at performing in house calibration for our small scales. We do have a set of weights that we intend to use. How is it best to document the calibration using these set of weights? What sort of documentation should I require from the manufacturer of the weight set we intend to use?
Any help is appreciated, thank you.
duff999
Make sure your weights are calibrated (we have our set done every 5 years). I've attached a simple sheet we use to document. Systems been in place for 15 years, no problems.
Another question regarding the weight set. Can these also be calibrated in house, if I am using a scale/balnce that is currently up to date with its cal, or dies the weight set actually need to be sent out for calibration
dwperron
I am not a metrologist or calibration expert. Having said that, if the weight set is used to calibrate the scale, then the scale is used to calibrate the weight set, that seems to me like circular calibration and would not be acceptable.
You are correct. You need to break such a circular calibration by maintaining traceability to an outside organization.
There is also the question of accuracies - if the weight set is good enough to calibrate the scale then the scale is not good enough
to calibrate the weight set.
dwperron
It depends on what you mean by "calibrate" - and this is a touchy question regarding scales.
Most come with a "Calibrate" function, where you set a test weight on it and the scale adjusts itself to that value.
But is that "Calibration"? I would say not.
You have set the scale to measure a single value accurately. You have done nothing to verify that the scale is accurate throughout its full range (linearity), you have done nothing to verify that it reads the same on any point on the pan (cross pan balance), and that it can tare a weight value accurately. You would also be keeping results, determining if they were in or out of tolerance. That would be a "calibration".
Do you really want to "calibrate" these scales, or just perform a daily check on them using a test weight?
Calibrating your own scales means you are setting up all the infrastructure that a calibration lab needs to withstand audits.
Will that cost more to your organization than having someone else calibrate the scales?
Philip B
We have our scales supplier come in and perform an annual calibration. The cost is reasonable (around £350 for three sets of scales), the calibration is independent, we don't have to faff about with test weights and we get a UKAS accredited calibration certificate.
duff999
Very good points, thank you. It sounds like this weight set would be good for our daily checks, but for our routine calibration (6 mo, year) where would would get a calibration cert, we stick with an outside firm that we are currently using. I thought I would be able to use this set as my primary calibration for my 6 mo. or yearly calibration.
D Looking for Calibration Software for small company General Measurement Device and Calibration Topics 20
D Calibration Method for Small Surface Plates (6" x 6") General Measurement Device and Calibration Topics 8
F Identifying Calibration on Small Tools (Measurement Equipment) General Measurement Device and Calibration Topics 2
P Are we required to register to REACH? Small CMM service and calibration company RoHS, REACH, ELV, IMDS and Restricted Substances 3
S The Best Measurement Capability (BMC) of a Small Calibration Laboratory Measurement Uncertainty (MU) 9
M Calibration in a Small Company with Employee Owned Measurement Equipment General Measurement Device and Calibration Topics 21
R Adjustable c-type gauges and calibration - Small job shop General Measurement Device and Calibration Topics 2
Marc Calibration Issues for Small Companies - Common Sense Calibration General Measurement Device and Calibration Topics 1
Q CMM Calibration Certification - Small CMM Calibration Service General Measurement Device and Calibration Topics 5
lanley liao Question regarding the calibration of monitoring and measure equipment. Oil and Gas Industry Standards and Regulations 0
N IATF Calibration Lean in Manufacturing and Service Industries 3
Q Do these certificates of calibration meet ISO 9001 requirements for traceability to NIST? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
E Calibration Records needed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
D Limited Range Calibration - 5000 lb Industrial floor scale General Measurement Device and Calibration Topics 3
I IQOQ or just initial calibration required? General Measurement Device and Calibration Topics 3
B Calibration in real life ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Ron Rompen Calibration by manufacturer ISO 17025 related Discussions 4
Q Calibration verification records 7.1.5.2.1 IATF 16949 - Automotive Quality Systems Standard 2
W Next Calibration Due Date Calibration Frequency (Interval) 5
A OEM On-Site Calibration issues during Covid19 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
M Calibration Certificate Result issued by an accredited external laboratory General Measurement Device and Calibration Topics 9
G Calibration of "Master Parts" Used as Gauges Calibration Frequency (Interval) 5
R Calibration lab environmental monitoring General Measurement Device and Calibration Topics 4
G Calibration of Rotronic probe but not digital readout? General Measurement Device and Calibration Topics 3
F Standard Calibration Procedures: Recommended Practice ISO 17025 related Discussions 0
T Temperature Requirements For In House Calibration - AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
Crimpshrine13 Laboratory Scope - Calibration vs. Test Methods - IATF 16949 IATF 16949 - Automotive Quality Systems Standard 3
Crimpshrine13 Calibration of pH Meter Probe Calibration and Metrology Software and Hardware 3
F ESD workbench "calibration" Manufacturing and Related Processes 2
F Nist traceable calibration certificates General Measurement Device and Calibration Topics 1
G Tool tracebility and First calibration requirements for aerospace (AS9100) organisation AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
D Calibration of Digital thermometer with surface probe General Measurement Device and Calibration Topics 1
T Calibration or Verification -> Cm and Cmk, etc. Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
G Is repeatability required for equipment calibration? General Measurement Device and Calibration Topics 10
was named killer AS 9100D - Calibration Instructions - Controlled documents? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
B Photovoltaic Tester Calibration General Measurement Device and Calibration Topics 0
B Temperature loop: partial calibration General Measurement Device and Calibration Topics 10
G Glass scale calibration at 74 degrees F? General Measurement Device and Calibration Topics 4
