Hi all,
I am working on a supplier issue between my plant and our supplier the issue is our incoming inspection is rejecting the parts and the supplier is passing parts they are using the exact same fixture which is spring-operated to test parts to ensure the latch is released. Neither of the fixtures has either been validated or calibrated to my knowledge and not even sure how they could be unless you remove the torsion springs and tested them individually.
Any suggestions on how to proceed? My thoughts are design a fixture that you can calibrate and ensure repeatability.
Thanks,
Al40
Thanks,
Al40
