Calibration of Thread Plugs and Ring Gages - Various Thread Standards
millerwl71
I send gages out for calibration and we have a form that's called "Calibration Vendor Requirements" that I need to fill out. I thought putting calibrate per manufacturing specs would be good enough but I guess not.
I e-mailed this to my Quality Manager to see if this is acceptable. "On the calibration of Thread Rings and plug gages, per manufacturing specs is based off of what the Gage labeled size is. I believe they follow ANSI and that is what they calibrate to. So for thread gages, could I say all thread gauges will be calibrated to ANSI standards on the "Calibration Vendor Requirements form"?
He replied. 'Not all threads are ANSI, but I think your point is correct.
You may reference the thread standard of the specific thread type.
This does get sticky however because of revision levels change. So ideally you would name the spec and current rev, however, in most cases you will not know and would be relying on the cal supplier to be up to date. So in this case you should be able to say the spec name and “latest revision” or “current edition” etc.
We have UNC, ACME, NPT threads. Can someone help me understand what standard is used that threads are calibrated to? Or clarify what my quality manager is looking for?
Thanks,
Wayne Miller
Michael_M
Re: Thread plugs and ring gages.
If I understand your question correctly, could you do the following:
For each specific gage, does your system allow you to make a description of the item. For example, part of a description of "9/16-18 UNF 2A" could you add "Calibrate to XXXXX, latest revision"? This would allow you to specify each calibration requirement specific to a gage and if you state, to latest revision, this may allow you to forego specifying a revision level.
Could you use a ISO 17025 lab (I think that is the correct ISO number for calibration). They should be able to help direct the PO and specific requirements.
millerwl71
I fill out the list of gages that I will be sending.
ID# what it is. And its interval.
I send list to calibrating company and they schedule a pickup. So. I have about twenty thread or ring gages that are either UNC, ACME, NPT. So I'm a little confused when you wrote calibrate to XXXX, Revision? All of the gages have been sent out a few time and calibrated before. It just this new form I have to put something in there so there happy.
G
Gkokal
There are hundreds of thread standards, if not more. However, the types that you listed (UNC, ACME, NPT) are ANSI standards. One sentence that could meet your quality requirements while remaining easy to handle could be: "Calibrate to latest applicable ANSI standard, unless otherwise noted".
As a cal lab, most of the time this works for us. We use the nomenclature on the gage and pull the tolerances from that. The only place it gets confusing is custom gages (ex: a 15.5 TPI gage, yes they exist) or metric gages. The ISO nomenclature and the ANSI nomenclature is identical, and the tolerances are not.
It all depends on what your gages are and what your requirements are, but from 1000ft, that is my suggestion.
T In-House Calibration of Thread Plugs/Rings to achieve a 4:1 Ratio Measurement Uncertainty (MU) 4
C Calibration of Tapered Thread Plugs General Measurement Device and Calibration Topics 3
CaliperJim Screw Thread Micrometer Anvil Calibration General Measurement Device and Calibration Topics 7
CaliperJim Double Ended Thread Plug Gauge Calibration General Measurement Device and Calibration Topics 9
B Calibration of Thread Gages with Metric Standards with Conversion to Imperial Units General Measurement Device and Calibration Topics 3
4 In-House Thread Wire Calibration General Measurement Device and Calibration Topics 5
G Sequence and Frequency of Calibration for Thread Gauges General Measurement Device and Calibration Topics 2
C Calibration of Master Thread Plug Gages General Measurement Device and Calibration Topics 2
J Thread Gauge Calibration Failure for Pitch Diameter being too large General Measurement Device and Calibration Topics 3
D Indysoft Calibration Software Thread Plug Template Help General Measurement Device and Calibration Topics 2
K Qualifications I need to adhere to for Thread Gage Calibration Calibration Frequency (Interval) 1
M Thread Gage Calibration - Who to use General Measurement Device and Calibration Topics 5
K Calibration Requirements for Thread and Ring Gages AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
M Sealed in Wax Thread Gages - ISO 9001 Clause 7.6 Calibration ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
D Calibration Frequency of Thread Gages use for Aluminium and Stainless Steel Products Calibration Frequency (Interval) 6
M Thread Plug Gage - Calibration Frequency ISO 13485:2016 - Medical Device Quality Management Systems 1
C Adjustable Thread Ring Gage Calibration General Measurement Device and Calibration Topics 8
D ISO/Metric Solid Thread Ring Calibration General Measurement Device and Calibration Topics 1
R Thread Measurement - Basics on Thread Plug and Ring Calibration General Measurement Device and Calibration Topics 5
M Calibration and Determine Pitch Diameter of Tapered Thread General Measurement Device and Calibration Topics 3
BradM Calibration Fundamentals: The How-To Thread General Measurement Device and Calibration Topics 3
V Calibration Procedure for Thread Pitch Micrometer General Measurement Device and Calibration Topics 3
L Calibration of ring thread gauge with master gauge: How to calculate Uncertainty? General Measurement Device and Calibration Topics 1
R 3 Wire Thread Measuring System - Gage Calibration General Measurement Device and Calibration Topics 8
K HI LO Set Masters for Thread Rings - Calibration Procedure General Measurement Device and Calibration Topics 21
S NPT Thread Calibration Method - NPT Taper Thread Plug Gages General Measurement Device and Calibration Topics 9
B Method for Calibration of Thread Plug Gauges General Measurement Device and Calibration Topics 13
T Calibration and Control - Need help with plug, ring, and thread plug gages General Measurement Device and Calibration Topics 12
M Constant for thread gage calibration with the three wire system General Measurement Device and Calibration Topics 7
5 Calibration of Thread Pitch Micrometers General Measurement Device and Calibration Topics 3
J Thread Gage Calibration: In-House or Outsourced? General Measurement Device and Calibration Topics 7
U Calibration House - Where I can get a PG 13.5 Gut thread ring gage calibrated? General Measurement Device and Calibration Topics 1
R Calibration Check Points for ACME & LPT Thread Plug & Rings General Measurement Device and Calibration Topics 5
apestate Thread micrometer questions, discussion regarding MU and calibration. General Measurement Device and Calibration Topics 3
G Calibration of 200 sets of Thread Ring Gages - Return them to the manufacturer? General Measurement Device and Calibration Topics 19
T Thread Gage Calibration / Verification Instruction needed General Measurement Device and Calibration Topics 21
M Calibration requirements for pins, thread gages, etc? General Measurement Device and Calibration Topics 2
D Calibration of Optical Comparator Overlays - Radius, Thread and Angle General Measurement Device and Calibration Topics 11
M Thread Gage Calibration Software to look up requireds/specs for thread gages Calibration and Metrology Software and Hardware 48
P Thread plug gauge failed calibration - Must I remeasure everything measured with it? General Measurement Device and Calibration Topics 23
J Calibration, should we.... Go-No-Go, thread, pin, and ring gauges QS-9000 - American Automotive Manufacturers Standard 2
C IR thermometer for refrigerated Centrifuge calibration General Measurement Device and Calibration Topics 2
G ISO 17025.2017 Clause 7.8.4.3 Certificate of Calibration Label ISO 17025 related Discussions 5
M CMM Calibration - What, exactly, is the output? General Measurement Device and Calibration Topics 11
J Using MSA instead of calibration Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
P Hierarchy of Calibration in Metrology General Measurement Device and Calibration Topics 1
J Calibration frequency for glass scale Calibration Frequency (Interval) 2
S Calibration SOP and external vendors General Measurement Device and Calibration Topics 2
P IATF16949 External Lab Calibration -CIPM MRA IATF 16949 - Automotive Quality Systems Standard 1
CaliperJim Acclimation time prior to calibration General Measurement Device and Calibration Topics 8
