Calibration of "Working" Tools in Calibration Procedure - ISO 9001:2000
theduke
Good Evening All,
I am the Quality Manager for a small manufacturing company in SC. We manufacture gas-liquid separation equipment for industrial applications. We are currently in the process of obtaining our ISO 9001:2000 registration.
I am working on creating all of our forms and SOPs and am currently working on our calibration procedure. We use three different tools for measuring: calipers, micrometers, and tape measures. The calipers and micrometers are used to measure small components. The tape measures are used to verify our individual modules and the overall assemblies against our documentation. I plan on calibrating a set of calipers, micrometers, and tape measures, which will be used to verify our critical dimensions of the product before shipping to our customer. These will be stored in a dedicated cabinet.
What I'm stuck on is must I identify all the other measuring devices used on the production floor during the daily work details. The guys use these during the build process; they are not used for the critical/final dimension checks. I have been told that I must mark these as "FRO" (For Reference Only). What I want to know is must this be done? I've put a statement in the procedure that indicates any tool not identified as calibrated is by default "For Reference Only". Does this statement cover us per ISO 9001:2000 or must we mark each tool as FRO?
Any help with this will be greatly appreciated.
Helmut Jilling
Auditor / Consultant
Re: ISO 9001:2000 - Calibration of "Working" Tools
Good Evening All,
It does not take long to verify a mic or caliper if your tolerances are not extremely tight. You need to calibrate any gage that "matters." If the readings from a gage are going to be used, then you need to know whether they are correct. (The ISO 9001:2000 did away with the narrow definition you are using.) Anything else should be marked "uncalibrated" or whatever. But, it also shouldn't be used for anything you depend on, either.
BradM
Re: Calibration of "Working" Tools - ISO 9001:2000
Helmut, nice post. The suggestion about quick calibration is a good one. It might be worth the time to go ahead and calibrate what you have, than spending a lot of time trying to segregate/ identify/ control, etc. non-calibrated instruments.
Interesting question. I am having a discussion with a couple of my esteemed colleagues on the ASQ discussion board on this subject right now.
Their take: It is not a requirement to mark the gauges "For Reference Only". The system/process should be such that people know to use calibrated instruments for process/production. In other words, it is silly and useless to use such labels.
My take: Ideally, everyone should know to properly inspect instruments prior to use. However, reality states otherwise. If you don't mark an instrument as "For Reference Only", then without super training that non-calibrated instrument will probably end up in the production.
I think both views have merit. My suggestion to you is to develop a system that works for your shop and your culture. Can you adequately separate the instruments where they are not mixed? Is the probability high that people will always use the correct instrument/ gauge/ meter, or is reality they will grab what they can find, so it should be marked clearly?
Whatever you choose, just make sure that non-calibrated instruments will not be used for acceptance readings.
Helmut Jilling
I agree. It certainly is not a requirement to mark an instrument as "For Reference Only." Problem is, if you don't people will inevitably use them. Mistake proofing is a better preventative.
We have a similar issue at our company. Our current calibration system requires calibration of all tools, whether they be used by inspection or by the machinists. We were on a monthly calibration schedule for all hand tools, but as the company has grown, it is impossible to locate and calibrate over 200 hand tools every month, in addition to your regular duties. Recently we changed the calibration interval of shop tools to 90 days. We are still overwhelmed. One of the biggest problems is just trying to locate these tools. There are 8 machinists, and a shop foreman, most of which have about 20 tools. A couple machinists have no tools of their own, and use the shop tools. There are about 70 shop tools. Basically these tools are all over the place, sometimes locked in a machinist's toolbox, sometimes just missing. (Of course they will resurface during an audit.)
We are ISO 9001:2000 registered FAA Repair Station and have an AS9110 audit coming up. I have a few weeks to come up with a better system.
What are you basing your calibration intervals on? Do you typically find significant numbers of gages that need adjustment?
With the exception of indicators (which are used for shop reference only), we haven't had any issues with tools falling out of calibration. There is the occasional damaged tool, which is either sent for repair or removed from service, but this is usually caught by the operator at the time of use (not during calibration).
This calibration system was set up many years ago, and it is my belief that the original philosophy was to try to do "better than" necessary. (Kind of the metrological version of "over-tolerancing" on repair designs.) This was adequate when there were only about 70 tools and a manager who had a lot of extra time on his hands. Now, we no longer have that luxury, and we really have to analyze our system and revamp the entire process.
If you were doing monthly calibrations without having to do a lot of adjusting, you should be able to use the records to expand your calibration intervals.
In addition to Jim's, Helmut's and Brad's help, it seems to me that you've got a challenge with the use of the calibration system. If you have people who lock equipment away so you can't locate it, I'd suggest you need an awareness session (or three) and some other strategies for dealing with equipment which is personally owned. My belief is that any machining company that doesn't own it's tools, relying on the personnel is asking for a measurement problem. It's a false economy to do it that way and is a 'ticking bomb' in view of the transient nature of some people. They leave and so does your measuring system.....
E
Elynn
My question is... isn't there a tools control list, especially so for those that require Calibration?
We do breakdown the equipment accountability to the technician as they are the user of the equipment. Location of tools and equipment are as per stated in the list. Bi-weekly or monthly inspection will be done to ensure they are in place. Nothing of the sort of misplacing has happened for past 4 years.
Not sure if this works, separate the control process between the 2 sections and ensure the tools are significantly marked and not used in the critical measurement. Also, create evidence that the tools are checked before used (like verification). I believe some recordings are done for critical measurement, which in the recording form, the device serial number can be including as evidence of using the calibrated tool.
D How Working Standard Calibration result use in Verification of Equipment General Measurement Device and Calibration Topics 7
lanley liao Question regarding the calibration of monitoring and measure equipment. Oil and Gas Industry Standards and Regulations 0
N IATF Calibration Lean in Manufacturing and Service Industries 3
Q Do these certificates of calibration meet ISO 9001 requirements for traceability to NIST? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
E Calibration Records needed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
D Limited Range Calibration - 5000 lb Industrial floor scale General Measurement Device and Calibration Topics 3
D Calibration of Small Scales General Measurement Device and Calibration Topics 26
I IQOQ or just initial calibration required? General Measurement Device and Calibration Topics 3
B Calibration in real life ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Ron Rompen Calibration by manufacturer ISO 17025 related Discussions 4
Q Calibration verification records 7.1.5.2.1 IATF 16949 - Automotive Quality Systems Standard 2
W Next Calibration Due Date Calibration Frequency (Interval) 5
A OEM On-Site Calibration issues during Covid19 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
M Calibration Certificate Result issued by an accredited external laboratory General Measurement Device and Calibration Topics 9
G Calibration of "Master Parts" Used as Gauges Calibration Frequency (Interval) 5
R Calibration lab environmental monitoring General Measurement Device and Calibration Topics 4
G Calibration of Rotronic probe but not digital readout? General Measurement Device and Calibration Topics 3
F Standard Calibration Procedures: Recommended Practice ISO 17025 related Discussions 0
T Temperature Requirements For In House Calibration - AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
Crimpshrine13 Laboratory Scope - Calibration vs. Test Methods - IATF 16949 IATF 16949 - Automotive Quality Systems Standard 3
Crimpshrine13 Calibration of pH Meter Probe Calibration and Metrology Software and Hardware 3
F ESD workbench "calibration" Manufacturing and Related Processes 2
F Nist traceable calibration certificates General Measurement Device and Calibration Topics 1
G Tool tracebility and First calibration requirements for aerospace (AS9100) organisation AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
D Calibration of Digital thermometer with surface probe General Measurement Device and Calibration Topics 1
T Calibration or Verification -> Cm and Cmk, etc. Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
G Is repeatability required for equipment calibration? General Measurement Device and Calibration Topics 10
was named killer AS 9100D - Calibration Instructions - Controlled documents? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
B Photovoltaic Tester Calibration General Measurement Device and Calibration Topics 0
B Temperature loop: partial calibration General Measurement Device and Calibration Topics 10
G Glass scale calibration at 74 degrees F? General Measurement Device and Calibration Topics 4
A Digital Timer Calibration Requirements General Measurement Device and Calibration Topics 3
Ron Rompen Barcode Verifier Calibration and Use Calibration and Metrology Software and Hardware 5
S Is Optical Parallel Set required calibration? ISO 17025 related Discussions 1
A Calibration of Power Supplies AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
D Calibration Process Flow Map Example Wanted General Measurement Device and Calibration Topics 3
M Calibration or Verification? What terminology to use ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
N Calibration Requirements for Production Equipment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
