V
Im currently on a InPlant calibration proyect, and im going to buy standards and devices to calibrate, one if my advantages is that i have 2 COORDINATE MEASURING MACHINES in my QA Lab, my question is, what instruments can i check with this machine? or what TYPE of instrumenst can I verifiy with it if Im going to Credit my lab on 17025?
Primarily, the level of confidence that you will have in calibration performed on the CMM will be determined by the confidence in the CMM itself (and your measurement process). Do you have a competent calibration provider for the CMM? On the calibration certificate, they should provide an uncertainty measurement. You can then use that value and the uncertainties calculated in your own measurement process to determine your uncertainty.
