Calibration Procedure for a Thermobalance
ifserav
Hi everybody,
Do you know which standard I must follow to calibrate thermobalances?
Any recommendation to calibrate?
Thanks a lot.
qusys
Hi everybody,
Thanks a lot.
From quality standpoint , first you should evaluation if you can calibrate in house or externally, in a lab with ad hoc accredidation ( for instance ISO 17025). In any case, you should understand if the calibration or not can affect the quality of your product.
If you are capable with competencies. adequate procedures and resources , you can do yourself.
As per ISO 9001 , you shall meet 7.6 clause, if you are ISO TS you shall comply with 7.6.2, 7.6.3.1 and 7.6.3.2.
Hope this helps:bigwave:
Marc
Does anyone here by chance have a thermobalance calibration procedure you can share here? Or any related information?
BradM
From the link that Marc provided:
Automatic external calibration using either 100 g or 200 g calibration weight (depending on the model) guarantees ongoing accurate results
There is a PDF instruction manual at the same link which gives the recommended calibration instructions.
The primary concern with this device is accurately measuring weight. The drying process (as I can see) appears to be an option. Saying, I'm not sure if I see any quality parameter performed by the drying process; it either works or it doesn't. It works, by drying the material.
Does the thermobalance in question display temperature/relative humidity? That may be another parameter which would need to be verified.
However, after looking around at the material on these devices, they can get quite complex:
ftp://ftp.rz.uni-kiel.de/pub/bensch/Mexiko/PDF/tg.pdf
So not sure what device you have. A couple of reference suggested the best place to find out is in the instruction manual for the instrument.:)
M Procedure or Specification For Extending Gages Calibration Calibration Frequency (Interval) 2
S The procedure for replicate check in calibration lab as per ISO 17025 General Measurement Device and Calibration Topics 2
I Tool maintenance and calibration procedure - Calibrating tools/equipment AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
S Clarification of threaded ring gage calibration procedure/requirements General Measurement Device and Calibration Topics 2
J Calibration Recall - Lost Gages procedure example wanted General Measurement Device and Calibration Topics 4
L ISO 17025 Para. 5.4.5 - Method (Calibration Procedure) Validation Requirements ISO 17025 related Discussions 2
S Calibration of Laboratory Equipment in accordance with the manufacturer's procedure ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
M Calibration Procedure Traceable to National/International Standards (API Q1 9th Ed) Oil and Gas Industry Standards and Regulations 3
T Calibration procedure for Bubble Gas Flow Meter General Measurement Device and Calibration Topics 3
D Calibration & Test Laboratory Non-Conformance Procedure Example wanted General Measurement Device and Calibration Topics 3
C Basic Internal Calibration Procedure to check the Accuracy of a Balance Calibration Frequency (Interval) 6
L Calibration Uniformity Procedure for AMS 2750 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
M Calibration Procedure for Gage Blocks General Measurement Device and Calibration Topics 10
C 21 CFR Part 820 - Question About Calibration Procedure Content Requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
L Pneumatic Torque Wrench Calibration Procedure Calibration and Metrology Software and Hardware 1
W Digital Multi-Meter Calibration Procedure for various Meter Brands and Functions General Measurement Device and Calibration Topics 7
W First Draft Micrometer Calibration Procedure ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
S Is this procedure truly calibration? General Measurement Device and Calibration Topics 15
A Quality Procedure for 7.6 Calibration Question ISO 13485:2016 - Medical Device Quality Management Systems 6
C Calibration Procedure for Ammeter and Voltmeter wanted General Measurement Device and Calibration Topics 4
K Calibration Procedure for ID Micrometer Calibration & Extension Rods General Measurement Device and Calibration Topics 5
S QMS (Quality Management System) and Calibration Procedure ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
R Documented Procedure for the Calibration of Pulse Current Monitors/Tranformers General Measurement Device and Calibration Topics 4
L Calibration Procedure for an IC (Integrated Circuit) Test Socket Calibration and Metrology Software and Hardware 6
R Calibration Procedure for a MS8201H Mastech Multimeter General Measurement Device and Calibration Topics 6
M Sorvall 100S Centrifuge Calibration - SOP (Method and Procedure) Needed General Measurement Device and Calibration Topics 5
H Calibration Procedure Level of Detail - ISO Procedure question Document Control Systems, Procedures, Forms and Templates 8
L Calibration Procedure for Internal Spline Plug Gage Needed General Measurement Device and Calibration Topics 4
A Implementation of 820.72 and 820.120 - Problem with Calibration Procedure 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
2 TS 16949 Cl. 7.6.3.1 - Internal Calibration Procedure not Traceable to ASTM, EN etc. IATF 16949 - Automotive Quality Systems Standard 20
C Equipment Owner's Manual used for Calibration - Is it uncontrolled procedure? Document Control Systems, Procedures, Forms and Templates 15
R Environmental Controls Procedure for Calibration of Dimensional Gages General Measurement Device and Calibration Topics 3
T Advice regarding a Calibration Plan and Procedure wanted Calibration Frequency (Interval) 2
M Writing a Calibration Procedure for Groove Micrometers General Measurement Device and Calibration Topics 4
V Calibration Procedure for Thread Pitch Micrometer General Measurement Device and Calibration Topics 3
N Plan and Procedure for Calibration Laboratory Intermediate Checks General Measurement Device and Calibration Topics 2
V Calibration procedure for Torque Meter Needed General Measurement Device and Calibration Topics 6
K HI LO Set Masters for Thread Rings - Calibration Procedure General Measurement Device and Calibration Topics 17
S Calibration procedure wording ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
M Help writing a Radiometer Calibration Procedure General Measurement Device and Calibration Topics 3
C Gage pin calibration procedure for accurately calibrating gage pins General Measurement Device and Calibration Topics 18
B Pin Gage Calibration Procedure - ISO 17025:2005 accreditation requirements? ISO 17025 related Discussions 8
M Zebedee CL-100 Clarity Meter Calibration Procedure needed General Measurement Device and Calibration Topics 2
A Procedure for Calibration of Ovens, Baths and Furnance needed General Measurement Device and Calibration Topics 2
T Calibration of "Working" Tools in Calibration Procedure - ISO 9001:2000 General Measurement Device and Calibration Topics 11
J Calibration Procedure for Digi-Check style Height Gage General Measurement Device and Calibration Topics 5
I Procedure for Calibration of my Load Cell Testing Equipment - Needed General Measurement Device and Calibration Topics 5
J Sine Plate Calibration Procedure General Measurement Device and Calibration Topics 5
apestate Micrometer Calibration Procedure - Please critique General Measurement Device and Calibration Topics 20
R Auditor wants to know where our calibration procedure came from - TS16949 General Measurement Device and Calibration Topics 14
