Calibration Procedure for Gage Blocks
MetroBioCen
Hello everybody
I've been assigned with the task to develop a calibration procedure for standard lenght blocks sets (Apologise in advance if they are not named like that in English).
I'm referring to metal blocks which dimension are considered standard lenght and are used to calibrate calipers and micrometers. We call them in Spanish: "Medidas Plano-paralelas Patrones".
I really don't know where to begin as I think that the required standard for this would be a very expensive instrument, and I have never worked with this kind of devices.
I would appretiate any help regarding this.
Thank you very much in advance
MetroBioCen
Re: Calibration Procedure for Standard Length Blocks
Hello there
Yes, you do have the correct name. Length or gauge blocks, also know as slip gauges.
Will you be setting up the whole process, i.e. temperature controlled room, measuring equipment and master gauge blocks?
I can give you some help if you are.
Regards
Paul
Correct me if I'm wrong but it appears you (and your company) is new to in house calibration.
If this is the case and if these are the blocks used for in house calibration, I would strongly suggest using an outside service for these because you are right the standards on these are very tight and doing the job right can be time consuming.
When I was doing calibration at a small shop,I had a dedicated set of blocks that I would use to calibrate in house tools. I sent the blocks out to a certified lab and this gave me "traceability" to NIST.
The turnaround time on the blocks was not problematic so this worked well for us.
Once those blocks started showing wear past what I felt comfortable with for calibration purposes - I bought a new set and downgraded the old set to "shop use".
Hope this helps.
Peace
James
MetroBioCen
Thank you for your kind and quick answers I will use some technical words that I don't know if they are correct. If you don't understand, please let me know. I do work in a metrology lab already. We have all the stuff needed for the job, i.e: controlled temperature room, optimeter . Our lab is recognized by the National Accreditation Service. We usually use these equipments to calibrate thread profiles, but since we have seen that there is a market opportunity calibrating standards blocks, the staff decided to get in this adventure and I am the "lucky guy" :( destinated to write the calibration procedure. I would like to get some help as I don't have experience about this specific activity. Thanks in advance.
NikkiQSM
We send our blocks out every 2 years - We use an outside calibration source so that we do not have to purchase the equipment to calibrate them. Also it is all NIST traceable and just provides a lot of convinence for us.
MetroBioCen
I think I have not been clear enough as your answers are not in the direction I'm expecting. Sorry, I think I have not been able to explain myself well.
I do not intend to calibrate my own blocks, I intend to calibrate other people's blocks as I have the required equipment to do that task, but I don't know the method (procedure) to perform such calibrations. I need help regarding this.
BradM
MetroBioCen,
Thank you for coming here and asking your questions. :agree1: Don't worry about using perfect English. We're here to help.
You ask a good question. For starters, Wiki has a pretty good write-up on calibrating micrometers:
From that site, here is a link to a sample procedure, which I have also attached.
Is this what you were looking for? The attached procedure is quite detailed, which is good. You can then trim it down for your needs.
Let us know.
Add edit... :)
After reading your last post, I realize I totally missed the mark. Are you going to use a laser micrometer to verify the blocks?
Ahhh...Yea we are thinking in a whole different direction.... Sorry... Unfortunately I don't have that kind of expertise so will have to bow out..sorry.
James
MetroBioCen
Thank you very much for you attention. We already have a procedure to calibrate micrometers and calipers. Our intention is to begin to calibrato Gage blocks. That's the procedure in which I need help. Thanks again.
sarasheed
We are using the equipment Called TESA MODULE for calibrating the GAUGE BLOCKS.(Photo enclosed).For calibration we should have a Master Gauge Block set .The gauge blocks to be calibrated will be compared with the Master gauge Blocks using this equipment.
S Clarification of threaded ring gage calibration procedure/requirements General Measurement Device and Calibration Topics 2
L Calibration Procedure for Internal Spline Plug Gage Needed General Measurement Device and Calibration Topics 4
C Gage pin calibration procedure for accurately calibrating gage pins General Measurement Device and Calibration Topics 18
B Pin Gage Calibration Procedure - ISO 17025:2005 accreditation requirements? ISO 17025 related Discussions 8
J Calibration Procedure for Digi-Check style Height Gage General Measurement Device and Calibration Topics 5
M Procedure or Specification For Extending Gages Calibration Calibration Frequency (Interval) 2
S The procedure for replicate check in calibration lab as per ISO 17025 General Measurement Device and Calibration Topics 2
I Tool maintenance and calibration procedure - Calibrating tools/equipment AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
J Calibration Recall - Lost Gages procedure example wanted General Measurement Device and Calibration Topics 4
L ISO 17025 Para. 5.4.5 - Method (Calibration Procedure) Validation Requirements ISO 17025 related Discussions 2
S Calibration of Laboratory Equipment in accordance with the manufacturer's procedure ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
M Calibration Procedure Traceable to National/International Standards (API Q1 9th Ed) Oil and Gas Industry Standards and Regulations 3
T Calibration procedure for Bubble Gas Flow Meter General Measurement Device and Calibration Topics 3
D Calibration & Test Laboratory Non-Conformance Procedure Example wanted General Measurement Device and Calibration Topics 3
C Basic Internal Calibration Procedure to check the Accuracy of a Balance Calibration Frequency (Interval) 6
L Calibration Uniformity Procedure for AMS 2750 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
C 21 CFR Part 820 - Question About Calibration Procedure Content Requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
L Pneumatic Torque Wrench Calibration Procedure Calibration and Metrology Software and Hardware 1
W Digital Multi-Meter Calibration Procedure for various Meter Brands and Functions General Measurement Device and Calibration Topics 7
W First Draft Micrometer Calibration Procedure ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
S Is this procedure truly calibration? General Measurement Device and Calibration Topics 15
A Quality Procedure for 7.6 Calibration Question ISO 13485:2016 - Medical Device Quality Management Systems 6
C Calibration Procedure for Ammeter and Voltmeter wanted General Measurement Device and Calibration Topics 4
K Calibration Procedure for ID Micrometer Calibration & Extension Rods General Measurement Device and Calibration Topics 5
S QMS (Quality Management System) and Calibration Procedure ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
R Documented Procedure for the Calibration of Pulse Current Monitors/Tranformers General Measurement Device and Calibration Topics 4
I Calibration Procedure for a Thermobalance Calibration and Metrology Software and Hardware 4
L Calibration Procedure for an IC (Integrated Circuit) Test Socket Calibration and Metrology Software and Hardware 6
R Calibration Procedure for a MS8201H Mastech Multimeter General Measurement Device and Calibration Topics 6
M Sorvall 100S Centrifuge Calibration - SOP (Method and Procedure) Needed General Measurement Device and Calibration Topics 5
H Calibration Procedure Level of Detail - ISO Procedure question Document Control Systems, Procedures, Forms and Templates 8
A Implementation of 820.72 and 820.120 - Problem with Calibration Procedure 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
2 TS 16949 Cl. 7.6.3.1 - Internal Calibration Procedure not Traceable to ASTM, EN etc. IATF 16949 - Automotive Quality Systems Standard 20
C Equipment Owner's Manual used for Calibration - Is it uncontrolled procedure? Document Control Systems, Procedures, Forms and Templates 15
R Environmental Controls Procedure for Calibration of Dimensional Gages General Measurement Device and Calibration Topics 3
T Advice regarding a Calibration Plan and Procedure wanted Calibration Frequency (Interval) 2
M Writing a Calibration Procedure for Groove Micrometers General Measurement Device and Calibration Topics 4
V Calibration Procedure for Thread Pitch Micrometer General Measurement Device and Calibration Topics 3
N Plan and Procedure for Calibration Laboratory Intermediate Checks General Measurement Device and Calibration Topics 2
V Calibration procedure for Torque Meter Needed General Measurement Device and Calibration Topics 6
K HI LO Set Masters for Thread Rings - Calibration Procedure General Measurement Device and Calibration Topics 17
S Calibration procedure wording ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
M Help writing a Radiometer Calibration Procedure General Measurement Device and Calibration Topics 3
M Zebedee CL-100 Clarity Meter Calibration Procedure needed General Measurement Device and Calibration Topics 2
A Procedure for Calibration of Ovens, Baths and Furnance needed General Measurement Device and Calibration Topics 2
T Calibration of "Working" Tools in Calibration Procedure - ISO 9001:2000 General Measurement Device and Calibration Topics 11
I Procedure for Calibration of my Load Cell Testing Equipment - Needed General Measurement Device and Calibration Topics 5
J Sine Plate Calibration Procedure General Measurement Device and Calibration Topics 5
apestate Micrometer Calibration Procedure - Please critique General Measurement Device and Calibration Topics 20
R Auditor wants to know where our calibration procedure came from - TS16949 General Measurement Device and Calibration Topics 14
