Calibration procedure for radius gages
K
kristi
I am in the process of writing a calibration procedure for radius gages, for our plant, but have come to a standstill. Can anyone help me out?
thanks.
Al Dyer
Kristi,
Are you taking about the usual radius gage we have in out pockets, or a more advanced type of gage?
ASD...
CarolX
Kristi,
Are these gages getting a lot of use and subject to wear? My remondation would be to toss them, get a new set that is certified and then just replace the set every few years. It will be more cost effective in the long run that having them calibrated and then buying individual replacement for the worn ones.
Just MHO,
CarolX
AJLenarz
Example:
Wipe each gage clean, check for nicks or burrs on the gaging surfaces and dress the edges if necessary, using a hard Arkansas stone. Visually check to make sure there are no flats or interruptions in the gaging surfaces. Lay each gage on a surface plate or other plane level surface to make sure the gage is not warped or bent.
Size and conformity of the radial contour of each gage may be verified using an optical comparator which is equipped with a radi chart
Record any discrepancies or adjustments made on the Gage Calibration Record
The radius gages are acceptable if they exhibit no flats or deep imperfections in the contour surfaces are within 0.005” of the size marked on the gage.
Al Dyer
Aj,
From a calibration novice:
Did you (or you company) write this calibration procedure, or is it from some formally approved calibration standard that might be part of an A2LA or other nationally approved system?
Has it proved out with your registrar/auditor?
Would you use such a radius gage to approve product for final shipment to the customer? (I guess that is tolerence dependant)
A hand held radius gage capable of .0005 discrimination, not with my eyes!
If I had a radius that tight called out on a print I would think about accepting the job first, then probably use A CMM or laser type gage, rather that a handheld.
Not a dig, just looking for more information.
I like CarolX's idea.
ASD...
Hi all,
I've seen two methods. A visual (preferable) or touch probe CMM with a lot of hits, or comparison to calibrated pin gages using an indicator for outside radii. A CMM with a touch probe doesn"t work well on the smaller gages. Optical comparators generally aren't accurate enough but help to locate flats.
When you consider the cost of buying new, calibrated gages, you'll say ouch.
Mike
N
I'm not a radius gage expert, but from a calibration management perspective, if you discard a gage rather than recalibrate, as recommended above, don't you lose the opportunity to confirm the gage was in-tolerance, and the chance to recall/retest affected products if it was not?
Al Dyer
Good Point Norm,
I guess it comes down to the variables in each individual company.
Is the gage used for verification of a set-up and not first artical approval?
What is the calibration frequency?
Is the gage mastered before final artical inspection?
etc.......
I believe that a robust system will use pre-mastered gages to verify the validity of final artical inspection and preclude the need to notify the customer. (hopefully!)
As always, there are holes in the system and if an unverified and/or out of calibration gage is used to verify final product the customer must be notified.
Up front planning on gaging is a must in my view and not enough companies take advantage of the systems that they can set up to ensure that only qualified gages are used to accept final product.
If a proper gaging sytem is implemented the chance of sending nonconforming product is minimized. Prevent, don't detect. In the end, protect the customer, they pay your bills!
ASD...
DICKIE
AJ's procedure is right on the money. We have been calibrating them this way for 10+ years. Under normal use these kind of gages last for decades so repurchasing is not necessary. Al the "Tolerance" AJ referanced was .005 not .0005.
Strange Juan HP 85054B Standard Mechanical Calibration Kit Calibration Procedure General Measurement Device and Calibration Topics 1
M Bourdon gauge calibration procedure failure ISO 17025 related Discussions 3
M Procedure or Specification For Extending Gages Calibration Calibration Frequency (Interval) 2
S The procedure for replicate check in calibration lab as per ISO 17025 General Measurement Device and Calibration Topics 2
I Tool maintenance and calibration procedure - Calibrating tools/equipment AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
S Clarification of threaded ring gage calibration procedure/requirements General Measurement Device and Calibration Topics 2
J Calibration Recall - Lost Gages procedure example wanted General Measurement Device and Calibration Topics 7
L ISO 17025 Para. 5.4.5 - Method (Calibration Procedure) Validation Requirements ISO 17025 related Discussions 2
S Calibration of Laboratory Equipment in accordance with the manufacturer's procedure ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
M Calibration Procedure Traceable to National/International Standards (API Q1 9th Ed) Oil and Gas Industry Standards and Regulations 3
T Calibration procedure for Bubble Gas Flow Meter General Measurement Device and Calibration Topics 3
D Calibration & Test Laboratory Non-Conformance Procedure Example wanted General Measurement Device and Calibration Topics 3
C Basic Internal Calibration Procedure to check the Accuracy of a Balance Calibration Frequency (Interval) 6
L Calibration Uniformity Procedure for AMS 2750 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
M Calibration Procedure for Gage Blocks General Measurement Device and Calibration Topics 10
C 21 CFR Part 820 - Question About Calibration Procedure Content Requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
L Pneumatic Torque Wrench Calibration Procedure Calibration and Metrology Software and Hardware 1
W Digital Multi-Meter Calibration Procedure for various Meter Brands and Functions General Measurement Device and Calibration Topics 7
W First Draft Micrometer Calibration Procedure ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
S Is this procedure truly calibration? General Measurement Device and Calibration Topics 15
A Quality Procedure for 7.6 Calibration Question ISO 13485:2016 - Medical Device Quality Management Systems 6
C Calibration Procedure for Ammeter and Voltmeter wanted General Measurement Device and Calibration Topics 4
K Calibration Procedure for ID Micrometer Calibration & Extension Rods General Measurement Device and Calibration Topics 5
S QMS (Quality Management System) and Calibration Procedure ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
R Documented Procedure for the Calibration of Pulse Current Monitors/Tranformers General Measurement Device and Calibration Topics 4
I Calibration Procedure for a Thermobalance Calibration and Metrology Software and Hardware 4
L Calibration Procedure for an IC (Integrated Circuit) Test Socket Calibration and Metrology Software and Hardware 6
R Calibration Procedure for a MS8201H Mastech Multimeter General Measurement Device and Calibration Topics 6
M Sorvall 100S Centrifuge Calibration - SOP (Method and Procedure) Needed General Measurement Device and Calibration Topics 5
H Calibration Procedure Level of Detail - ISO Procedure question Document Control Systems, Procedures, Forms and Templates 8
L Calibration Procedure for Internal Spline Plug Gage Needed General Measurement Device and Calibration Topics 4
A Implementation of 820.72 and 820.120 - Problem with Calibration Procedure 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
2 TS 16949 Cl. 7.6.3.1 - Internal Calibration Procedure not Traceable to ASTM, EN etc. IATF 16949 - Automotive Quality Systems Standard 20
C Equipment Owner's Manual used for Calibration - Is it uncontrolled procedure? Document Control Systems, Procedures, Forms and Templates 15
R Environmental Controls Procedure for Calibration of Dimensional Gages General Measurement Device and Calibration Topics 3
T Advice regarding a Calibration Plan and Procedure wanted Calibration Frequency (Interval) 2
M Writing a Calibration Procedure for Groove Micrometers General Measurement Device and Calibration Topics 4
V Calibration Procedure for Thread Pitch Micrometer General Measurement Device and Calibration Topics 3
N Plan and Procedure for Calibration Laboratory Intermediate Checks General Measurement Device and Calibration Topics 2
V Calibration procedure for Torque Meter Needed General Measurement Device and Calibration Topics 6
K HI LO Set Masters for Thread Rings - Calibration Procedure General Measurement Device and Calibration Topics 21
S Calibration procedure wording ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
M Help writing a Radiometer Calibration Procedure General Measurement Device and Calibration Topics 3
C Gage pin calibration procedure for accurately calibrating gage pins General Measurement Device and Calibration Topics 18
B Pin Gage Calibration Procedure - ISO 17025:2005 accreditation requirements? ISO 17025 related Discussions 8
M Zebedee CL-100 Clarity Meter Calibration Procedure needed General Measurement Device and Calibration Topics 2
A Procedure for Calibration of Ovens, Baths and Furnance needed General Measurement Device and Calibration Topics 2
T Calibration of "Working" Tools in Calibration Procedure - ISO 9001:2000 General Measurement Device and Calibration Topics 11
J Calibration Procedure for Digi-Check style Height Gage General Measurement Device and Calibration Topics 5
I Procedure for Calibration of my Load Cell Testing Equipment - Needed General Measurement Device and Calibration Topics 5
