Calibration Procedure Traceable to National/International Standards (API Q1 9th Ed)
MalDu
It is a requirement that calibration instructions/procedures for instruments/equipment used for product testing are traceable to national/international standards.
When calibration is done based on previous experiences and national/international standards are not available, what would be a good justification/way to be presented to auditors to overcome this issue.
Thanks.
Stijloor
Re: Calibration Procedure Traceable to National/International Standards (API Q1 9th E
A Quick Bump!
Can someone help?
Thank you very much!
BradM
Hello MalDu!
Forgive me for responding to a question with a question, but this is posted in the oil and gas industry forum; and you made this reference: API Q1 9th Ed. So are you asking in terms of this industry/ requirement, or in general?
Too, let's say there are two different components of the calibration: 1) The measurement standard and 2) the procedure standard. So if we're calibrating a pressure gauge for example, 1) would be the master calibration gauge and 2) would be the written standard specifying how to calibrate the particular gauge. Is that correct?
1 must be N.I.S.T. (or equivalent National Standard) traceable; or a Naturally Accepted Standard.
For 2, are you asking if it must come from ASME or some other "recognized" source of such procedures?
I am unfamiliar with oil/gas and of the above requirement, so I would be speaking in general terms. It's alway better to use an existing procedure that is validated and accepted. However, that is not always possible. So if you have to develop your own calibration procedure, it must be demonstrated that the procedure has been tested and validated for use.
Sidney Vianna
Post Responsibly
Don't confuse instructions/procedures (DOCUMENTS) with standards in this context.
The standards referred to in this context relate to physical, electrical, etc. standards. Not specifications, norms, etc.
So, for example, if you measured a dimension with a micrometer, that device (the micrometer) should be verified/calibrated against a standard (maybe a master gage block) which is calibrated verified against a higher standard and the chain of traceability of these verifications/calibrations should lead as high up as a national (or recognized) standard.
2 TS 16949 Cl. 7.6.3.1 - Internal Calibration Procedure not Traceable to ASTM, EN etc. IATF 16949 - Automotive Quality Systems Standard 20
Strange Juan HP 85054B Standard Mechanical Calibration Kit Calibration Procedure General Measurement Device and Calibration Topics 1
M Bourdon gauge calibration procedure failure ISO 17025 related Discussions 3
M Procedure or Specification For Extending Gages Calibration Calibration Frequency (Interval) 2
S The procedure for replicate check in calibration lab as per ISO 17025 General Measurement Device and Calibration Topics 2
I Tool maintenance and calibration procedure - Calibrating tools/equipment AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
S Clarification of threaded ring gage calibration procedure/requirements General Measurement Device and Calibration Topics 2
J Calibration Recall - Lost Gages procedure example wanted General Measurement Device and Calibration Topics 7
L ISO 17025 Para. 5.4.5 - Method (Calibration Procedure) Validation Requirements ISO 17025 related Discussions 2
S Calibration of Laboratory Equipment in accordance with the manufacturer's procedure ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
T Calibration procedure for Bubble Gas Flow Meter General Measurement Device and Calibration Topics 3
D Calibration & Test Laboratory Non-Conformance Procedure Example wanted General Measurement Device and Calibration Topics 3
C Basic Internal Calibration Procedure to check the Accuracy of a Balance Calibration Frequency (Interval) 6
L Calibration Uniformity Procedure for AMS 2750 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
M Calibration Procedure for Gage Blocks General Measurement Device and Calibration Topics 10
C 21 CFR Part 820 - Question About Calibration Procedure Content Requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
L Pneumatic Torque Wrench Calibration Procedure Calibration and Metrology Software and Hardware 1
W Digital Multi-Meter Calibration Procedure for various Meter Brands and Functions General Measurement Device and Calibration Topics 7
W First Draft Micrometer Calibration Procedure ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
S Is this procedure truly calibration? General Measurement Device and Calibration Topics 15
A Quality Procedure for 7.6 Calibration Question ISO 13485:2016 - Medical Device Quality Management Systems 6
C Calibration Procedure for Ammeter and Voltmeter wanted General Measurement Device and Calibration Topics 4
K Calibration Procedure for ID Micrometer Calibration & Extension Rods General Measurement Device and Calibration Topics 5
S QMS (Quality Management System) and Calibration Procedure ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
R Documented Procedure for the Calibration of Pulse Current Monitors/Tranformers General Measurement Device and Calibration Topics 4
I Calibration Procedure for a Thermobalance Calibration and Metrology Software and Hardware 4
L Calibration Procedure for an IC (Integrated Circuit) Test Socket Calibration and Metrology Software and Hardware 6
R Calibration Procedure for a MS8201H Mastech Multimeter General Measurement Device and Calibration Topics 6
M Sorvall 100S Centrifuge Calibration - SOP (Method and Procedure) Needed General Measurement Device and Calibration Topics 5
H Calibration Procedure Level of Detail - ISO Procedure question Document Control Systems, Procedures, Forms and Templates 8
L Calibration Procedure for Internal Spline Plug Gage Needed General Measurement Device and Calibration Topics 4
A Implementation of 820.72 and 820.120 - Problem with Calibration Procedure 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
C Equipment Owner's Manual used for Calibration - Is it uncontrolled procedure? Document Control Systems, Procedures, Forms and Templates 15
R Environmental Controls Procedure for Calibration of Dimensional Gages General Measurement Device and Calibration Topics 3
T Advice regarding a Calibration Plan and Procedure wanted Calibration Frequency (Interval) 2
M Writing a Calibration Procedure for Groove Micrometers General Measurement Device and Calibration Topics 4
V Calibration Procedure for Thread Pitch Micrometer General Measurement Device and Calibration Topics 3
N Plan and Procedure for Calibration Laboratory Intermediate Checks General Measurement Device and Calibration Topics 2
V Calibration procedure for Torque Meter Needed General Measurement Device and Calibration Topics 6
K HI LO Set Masters for Thread Rings - Calibration Procedure General Measurement Device and Calibration Topics 21
S Calibration procedure wording ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
M Help writing a Radiometer Calibration Procedure General Measurement Device and Calibration Topics 3
C Gage pin calibration procedure for accurately calibrating gage pins General Measurement Device and Calibration Topics 18
B Pin Gage Calibration Procedure - ISO 17025:2005 accreditation requirements? ISO 17025 related Discussions 8
M Zebedee CL-100 Clarity Meter Calibration Procedure needed General Measurement Device and Calibration Topics 2
A Procedure for Calibration of Ovens, Baths and Furnance needed General Measurement Device and Calibration Topics 2
T Calibration of "Working" Tools in Calibration Procedure - ISO 9001:2000 General Measurement Device and Calibration Topics 11
J Calibration Procedure for Digi-Check style Height Gage General Measurement Device and Calibration Topics 5
I Procedure for Calibration of my Load Cell Testing Equipment - Needed General Measurement Device and Calibration Topics 5
J Sine Plate Calibration Procedure General Measurement Device and Calibration Topics 5
