Calibration Recall - Lost Gages procedure example wanted
J Allen
We have a calibration recall system in place. Sometimes, personnel are unable to locate the gages on recall and they are presumed lost until they turn up. Of course they do not always turn up.
How should I address lost gages in the recall.
Does anyone have a lost gage procedure?
I was just notified by a potential customer that my procedure must address lost gages.
BradM
Hello there!!
Good question.
What we started doing was issuing deviations for lost instruments. We then keep track of the deviations in two categories: Lost/broken instruments; and instruments that exceed tolerance.
Once the deviation is issued, the status of the instrument is changed to lost. If the instrument is located again, it can be calibrated and re-enrolled in the system. If the instrument stays lost for a couple of years, the instrument owner can choose to change status to retired/decommissioned.
These deviations can then be reported (and handled) down two different paths.
normzone
Ho ho ho !
No, it's not Christmas, that's me chortling over somebody else admitting that this problem exists.
Although I've never had a customer require that my documentation address this issue.
Over the years I've tracked the percentage of calibrated items that are delivered for re-calibration when due. Regardless of where I worked (granted, only two different outfits for the last 17 years), it ranged from 92% - 97%.
Now, some of that is because I calibrate employee-owned tools if they bring them in - I have a no questions asked policy regarding that. I figure if they can bring it in for calibration, they may also have it in the building and on their desk when a customer or other external auditor walks by, and it hurts less to calibrate those instruments than to deal with the resulting drama of them not being in current calibration status.
And I'm not innocent - I have a couple of meters at home that I commandeered because they were out of calibration, and after resolving that issue they went home with me to work on a motorcycle issue and have not returned.
Employees come and go, and things disappear sometimes. My cal log does include " last known location / user " and that helps me to round up the missing dogies. When an item does not get delivered I remove it from my "active" list and track it as "inactive". Sometimes they resurface after a couple of years, sometimes never.
J Allen
Our recall lists the department that the gage has been assigned to. Sometimes the gages seem to grow legs and make their way to another department or some distant Galaxy never to be seen again.
I think I will update the recall list as inactive and send a note to the responsible departments that gages found past their due date must be returned for calibration.
dwperron
Your plan makes good sense for a couple of reasons.
First, the owner / user of the equipment is responsible for it. They should know its location, how it was being used, etc. They should be required to either produce the instrument for calibration or take responsibility for it not being available for whatever reason.
Second, I'm sure that you could face problems if you just send notices out that calibration is due but there is no follow up. You should continue to consider the equipment overdue for calibration until it is otherwise dispositioned. The onus should be on the user to determine it is lost, not you.
tmann
Same scenario, my customer is asking I update my calibration procedure to address the potential of missing items. Any available procedure examples available?
normzone
I addressed this issue in our process documentation as follows:
Tools used in work areas are managed by area supervisors, and after calibration events area supervisors will update the tool status in the database.
The person managing the calibration program will then review the database updates and verify that database is up to date after onsite calibration events, and take any appropriate action as needed.
Any items that should have been calibrated and were not calibrated will be located and calibrated. Any items that cannot be located by reasonable methods are identified as lost and will be moved to the inactive list in the database.
R Calibration Recall/Reminders ISO 17025 related Discussions 2
W Calibration Recall or Due Dates - Latitude Calibration Frequency (Interval) 14
G Gage Recall Analysis - Threaded Plug Gage has failed Calibration General Measurement Device and Calibration Topics 10
E AS9100 Equipment Calibration Recall Methods and Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
C IR thermometer for refrigerated Centrifuge calibration General Measurement Device and Calibration Topics 2
G ISO 17025.2017 Clause 7.8.4.3 Certificate of Calibration Label ISO 17025 related Discussions 5
M CMM Calibration - What, exactly, is the output? General Measurement Device and Calibration Topics 11
J Using MSA instead of calibration Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
P Hierarchy of Calibration in Metrology General Measurement Device and Calibration Topics 1
J Calibration frequency for glass scale Calibration Frequency (Interval) 2
S Calibration SOP and external vendors General Measurement Device and Calibration Topics 2
P IATF16949 External Lab Calibration -CIPM MRA IATF 16949 - Automotive Quality Systems Standard 1
CaliperJim Acclimation time prior to calibration General Measurement Device and Calibration Topics 8
S How to report a measurement and relate it to calibration certificate General Measurement Device and Calibration Topics 1
R Do I need to get calibration certificate from ISO 17025 for IATF Audit IATF 16949 - Automotive Quality Systems Standard 8
S Netsuite Preventive Maintenance and Calibration Manufacturing and Related Processes 0
D Roughness specimen calibration Calibration and Metrology Software and Hardware 5
dhuot1990 General Calibration SOP Manufacturing and Related Processes 3
B Gage calibration Gonogo (calcul of cgk) General Measurement Device and Calibration Topics 0
Vader22 As-Found FAILED calibration ISO 14001:2015 Specific Discussions 16
M Gravimetric blender for resin in automotive industry - periodical calibration via external lab with certification Reliability Analysis - Predictions, Testing and Standards 0
N Calibration Method for Scales and Flowmeters Reliability Analysis - Predictions, Testing and Standards 7
T Calibration Tracking ISO 13485:2016 - Medical Device Quality Management Systems 4
Q Considering addition of mass calibration to ISO17025 scope ISO 17025 related Discussions 6
Z Resolution in calibration General Measurement Device and Calibration Topics 1
J Run Down Adapters Calibration Processes General Measurement Device and Calibration Topics 4
S Looking for accredited calibration lab - Onsite up to 650A and 1 kV. General Measurement Device and Calibration Topics 3
CaliperJim Screw Thread Micrometer Anvil Calibration General Measurement Device and Calibration Topics 7
Strange Juan HP 85054B Standard Mechanical Calibration Kit Calibration Procedure General Measurement Device and Calibration Topics 1
H Air Pressure Gage Calibration General Measurement Device and Calibration Topics 6
T Calibration on AVL AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
C Determining an as received OOT condition during calibration does not affect measurements taken prior to calibration. General Measurement Device and Calibration Topics 16
Sam.F Do heat treatment ovens need calibration? General Measurement Device and Calibration Topics 25
J Selecting reference standards for calibration General Measurement Device and Calibration Topics 3
C IATF 16949:2016 Major NC pertaining to 7.1.5.2.1 Calibration/verification records IATF 16949 - Automotive Quality Systems Standard 15
E Calibration Records during AS9100 Audit AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
John Predmore Calibration Determination decision Calibration Frequency (Interval) 16
J ISO 17025 Calibration Other Medical Device Related Standards 2
A Electronic Weighing scale calibration Calibration Frequency (Interval) 4
M Bourdon gauge calibration procedure failure ISO 17025 related Discussions 3
Ed Panek Calibration question Manufacturing and Related Processes 4
S Calibration/Worn gages Manufacturing and Related Processes 9
A Settings rings calibration General Measurement Device and Calibration Topics 4
R 7.1.5.2 -- Calibration AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
C CALIBRATION CERTIFICATE REQUIREMENTS General Measurement Device and Calibration Topics 11
S Calibration Label issues General Measurement Device and Calibration Topics 21
H Calibration / Capability in a PCP FMEA and Control Plans 1
R First Time Managing Calibration and Measurement System. Need Help. General Measurement Device and Calibration Topics 19
M CE marked medical device - do they need UKAS certified calibration provider ISO 17025 related Discussions 4
JDJohnson Micrometer & Caliper Calibration (ISO-9001) General Measurement Device and Calibration Topics 26
