Calibration Records during AS9100 Audit
E. Jackson
Hello!
Does anyone have 1st hand experience with auditors requesting to see calibration records during an AS9100 audit? I’m the sole inspector at my shop and it’s becoming abundantly clear that my predecessor was not actually performing any calibrations in house and basically fleecing my boss. There are no recorded results, we don’t have the types of minimum gauging required to perform the calibrations and yet every gauge has a sticker ……hmmmmm. There is only some nonsense excel spreadsheet and a couple of certs for thread rings that were sent out for calibration. Luckily my boss is very receptive to purchasing what his needed; it’s a small family owned machine shop and he’s kinda green to running it since his father (the owner) is now semi-retired. Anyway, I’m trying to catch up for our 1st “real” AS9100 audit but I’m basically starting from scratch. Luckily I will have minimal interaction with the auditors and every place I’ve been at it’s always the managers, supervisors, owners who deal with the auditors directly. I was mentioning to my manager that I’m creating calibration worksheets to record my results since none existed and he’s under the impression that they're not gunna want to see them during the audit? Every place I’ve been at, the auditor has requested from myself to see a handful of them to verify but my manager thinks they’ll only look to see if the gauging has a sticker? This doesn’t seem right at all for numerous reasons and my manager doesn’t see why that’s an issue. He’s not a dumb guy, he’s just an old guy who’s not really “hip” to current regulations and that it’s 2022 not 1972 lol. I guess I’m just a little stressed and I don’t want us to get hit with violations but I’m not really familiar with the one-on-one auditor interactions. Any words of advice?
Sidney Vianna
Post Responsibly
Just do your job and don’t try to second guess what the auditor is going to ask. Auditors are as dissimilar and inconsistent as snow flakes. No two are the same. Some are donuts connoisseurs and don’t leave the conference room. Others are as inquisitive and savvy as Sherlock Holmes. Let the chips fall where they may and support the audit as well as you can when and if you get involved.
Cari Spears
... Anyway, I’m trying to catch up for our 1st “real” AS9100 audit but I’m basically starting from scratch.
Hi!
What do you mean first "real" audit? Is this is your company's initial AS9100 registration?
And for what it's worth, I've never had an auditor that did not verify calibration records. Typically, they gather gage or equipment numbers throughout their time auditing manufacturing and inspection processes, then look at the records for those to ensure the requirements in 7.1.5 are being met.
E. Jackson
Hi!
We will be going thru stage 2 of the process; they already completed stage 1 before I started working there; at the time of my post I wasn’t sure of the correct naming of what step in the process so I apologize for not being clear in the first place.
Basically I’m going to have to calibrate active gages that are not due yet because there is no traceability of them getting calibrated in the first place. This was the issue I brought up with my manager and he seemed to be under the impression that just showing the auditor a gage with a calibration sticker on it will suffice and the auditor isn’t gunna want to see any calibration record with recorded errors. My experience was only at a shop past stage 2 so I wasn’t sure if calibration records are not necessary at stage 2? I just can’t imagine that that is acceptable.
I really like this shop a lot so mostly on my own time I’ve created actual worksheets to fill out, written up the calibration procedures, acquired the proper masters and temp/humidity gage to perform the calibrations. The fact that none of those basic elements needed to actually do calibrations were there in the first place really shows that the last guy was just faking it. What really drove it home was when I sorted the log by due date and saw that he calibrated 100 various gages in 1 day! It was definitely very suspicious.
I’ve only personally dealt with an auditor at my last shop and the auditor had a list of 5 active gages and requested from me to see the calibration records for them. Mind you my last shop was already certified and this shop is just at stage 2 so I wasn’t sure if that would be requested for stage 2.
Thanks so much for your feedback!
E. Jackson
PS: I am going to remove some gaging from circulation/make inactive to save some time but I can’t do it with all of them lol.
I guess I just don’t feel comfortable using ANYTHING the last guy “calibrated” because I really think he didn’t calibrate it to begin with!
Cari Spears
^I'd probably do the same. Make as much as you can inactive until you've got a handle on the stuff you're using regularly.
Since you're the gage guy now, have you read AS9100 Section 7.1.5?
Just do your job and don’t try to second guess what the auditor is going to ask. Auditors are as inconsistent as snow flakes. No two are the same. Some are donuts connoisseurs and don’t leave the conference room. Others are as inquisitive and savvy as Sherlock Holmes. Let the chips fall where they may and support the audit as well as you can when and if you get involved.
Exactly. And if you receive a nonconformance, it's not the end of the world. You already know what your plan is to keep this from happening again.
What you're doing now is containment, but your containment should also include determining the validity of previous measurement results. Could nonconforming product have been called good and shipped to your customer?
darkopsghost
I would suspect everything until you have validated those instruments. That being said, what about escapement for those products measured using instruments which failed calibration? How do you plan to mitigate those items? Things could get REAL MESSY, REAL QUICK!
I would definitely have a CA in the system before your next audit. Don't blame the person, but do blame the Process for not catching it, however, if it was the QM that failed to do the Calibration/ Verification, you would have hoped that he/ she had the integrity to do so without oversight...
