Calibration Room Environmental Condition Requirements
jfgunn
#11
My thought would be that you do not need a new thermostsat, but you need a new heating / cooling system. Most systems are not desgned to go from hot to cold or vice versa.
I would suggest one of the following (depending on the size of the room, how accurate you want to be, and how much money you want to spend)
Option 1: (Really accurate and really expensive) Get a precision cooling system that use electric reheats. This is basically an air conditioning system that constantly pumps cool air into the room. The thermostat then pumps in heat to keep the temperature constant. We have a syatem made by Liebert that keeps the temperature at 68 +/-1F in a room that is 20 X 20. This syatem was about $20K to buy and install including changing all of the celining tiles to create a vapor barrier so we could gontrol humiidty as well.
Option 2: Get an air conditioner and mount it in the wall where it blows the cold air into your room and exhausts somewhere else. Depending on the size of the room , this could be up to $1K. Basically, the air conditioner runs all day to varying degrees to fight the normal heating and cooling in the building.
Hope this helps
Hershal
Metrologist-Auditor
#12
It depends on the calibration being performed.
For dimensional calibration, the norm is 20 C, +/- 2 C; 20% to 50% RH is allowable, but tighter control of RH is highly desirable.
For electrical calibration, the norm is 23 C, +/- 3 C; 40% to 60% RH is perferable.
In electrical measurements, anything below 20% is considered ultra-low RH and the static electricity has the potential to affect calibrations.
In dimensional calibrations, above 50% is considered to have a potential negative influence to the UUT.
You may also look at wind, dust, vibration, and other environmental influences if they exist where you are.
Hope this helps.
P Clean Room Calibration (Validation) Other ISO and International Standards and European Regulations 4
N Setting up a new Calibration Room in a Machine Shop Calibration and Metrology Software and Hardware 3
S Calibration of Foundry Tool Room Equipment General Measurement Device and Calibration Topics 15
E Building a Calibration Room Test Bench - Finding components, test leads, etc. General Measurement Device and Calibration Topics 8
K Dimensional Lab (CMM Room) vs. Physical Test/Calibration Lab - Same required temp/hum General Measurement Device and Calibration Topics 2
lanley liao Question regarding the calibration of monitoring and measure equipment. Oil and Gas Industry Standards and Regulations 0
N IATF Calibration Lean in Manufacturing and Service Industries 3
Q Do these certificates of calibration meet ISO 9001 requirements for traceability to NIST? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
E Calibration Records needed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
D Limited Range Calibration - 5000 lb Industrial floor scale General Measurement Device and Calibration Topics 3
D Calibration of Small Scales General Measurement Device and Calibration Topics 26
I IQOQ or just initial calibration required? General Measurement Device and Calibration Topics 3
B Calibration in real life ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Ron Rompen Calibration by manufacturer ISO 17025 related Discussions 4
Q Calibration verification records 7.1.5.2.1 IATF 16949 - Automotive Quality Systems Standard 2
W Next Calibration Due Date Calibration Frequency (Interval) 5
A OEM On-Site Calibration issues during Covid19 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
M Calibration Certificate Result issued by an accredited external laboratory General Measurement Device and Calibration Topics 9
G Calibration of "Master Parts" Used as Gauges Calibration Frequency (Interval) 5
R Calibration lab environmental monitoring General Measurement Device and Calibration Topics 4
G Calibration of Rotronic probe but not digital readout? General Measurement Device and Calibration Topics 3
F Standard Calibration Procedures: Recommended Practice ISO 17025 related Discussions 0
T Temperature Requirements For In House Calibration - AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
Crimpshrine13 Laboratory Scope - Calibration vs. Test Methods - IATF 16949 IATF 16949 - Automotive Quality Systems Standard 3
Crimpshrine13 Calibration of pH Meter Probe Calibration and Metrology Software and Hardware 3
F ESD workbench "calibration" Manufacturing and Related Processes 2
F Nist traceable calibration certificates General Measurement Device and Calibration Topics 1
G Tool tracebility and First calibration requirements for aerospace (AS9100) organisation AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
D Calibration of Digital thermometer with surface probe General Measurement Device and Calibration Topics 1
T Calibration or Verification -> Cm and Cmk, etc. Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
G Is repeatability required for equipment calibration? General Measurement Device and Calibration Topics 10
was named killer AS 9100D - Calibration Instructions - Controlled documents? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
B Photovoltaic Tester Calibration General Measurement Device and Calibration Topics 0
B Temperature loop: partial calibration General Measurement Device and Calibration Topics 10
G Glass scale calibration at 74 degrees F? General Measurement Device and Calibration Topics 4
A Digital Timer Calibration Requirements General Measurement Device and Calibration Topics 3
Ron Rompen Barcode Verifier Calibration and Use Calibration and Metrology Software and Hardware 5
S Is Optical Parallel Set required calibration? ISO 17025 related Discussions 1
