Calibration System was In-House now Outside (External Service Provider)
D.Scott
#11
Sorry to jump in late on this but I am a little confused.
You say your internal calibrations are being done by this "new business" but they are using your procedures and won't accept responsibility for their work because they aren't certified yet.
I understand they are no longer employees but are they doing the work in your building? Are they using your standards? Are they maintaining the calibration records of your company? If they are not taking the work off site and they are not providing certificates of calibration, are they not just contract workers in your facility?
Do you still send your standards to an accredited lab for calibration and maintain records of traceability to NIST?
My point here is to suggest that even though the personnel performing the calibrations are contracted, you are still complying with the calibration and internal lab requirements of the standard (both ISO 9001 and TS 16949).
You would, of course, need to demonstrate the competence of the contract workers. Presumably the use of temporary contract workers is already covered somewhere in a procedure or policy.
Just a thought.
Dave
StanH - 2009
#12
They are not doing work in our building, they actually have building next door. They are using our standards updating our cal cert records (word doc form) & forwarding them to us for entry in our system.
They send gold standard equipment out for calibration to keep traceability to NIST standards.
I think as long as our procedure states an ourside source is doing calibration in some wording will cover us. I am just trying to figure out now what to remove and update in the procedure relating to in-house calibration, which has decreased drasticly.
Everyone has given me some great advice I think I know which way to head now.
#13
It appears to be a very informal situation that your management have caused to happen. As such, until they fully understand the risk (not simply of another 'major') of not having confidence in what this supplier is doing (it even applies when they were in-house, of course) they are unlikely to allow you or anyone to change much. I'd be finding the data to identify the risks ($$$ or your local currency) that are faced by doing calibrations like this. The accreditation is a nice to have, but management who make these types of decisions are clearly not worried by a certificate.
But then, they may not see much of a risk in their decisions, either...........
Hershal
Metrologist-Auditor
#14
StanH,
You have several potential solutions to your challenges......
First, keep them as an external provider and treat them as such. Have them sign a contract so if they use your procedures and records, they "rent" them (likely just give a discount, but works out the same). Otherwise, since you mentioned FCC, have them join GIDEP to obtain procedures.
Second, call it an internal "contract staffed" lab, which means you still own the space, standards, procedures and so on, but they provide the people and experience.
In the contract you have them sign, make sure you put in a requirement that they obtain accreditation from an ILAC signatory body (don't just say something like "A2LA or NVLAP") and then even help them shop all five ABs here in the U.S. prior to selecting one.
WATCH TRACEABILITY!!!!!!! That is a hang-up.....for the calibrations they provide, they must provide you or have quickly available the measurement uncertainty of that calibration or type of calibration. If you do not have uncertainty available you do NOT have traceability! Also, the traceability chain requires documentation showing the next link up. In other words, an unbroken chain of comparisons to National or international standards with stated uncertainties at each step. Oh, and the traceability chain (not knowing your equipment) may/may not run through NIST; perhaps someone like NRC (Canada).
Validation of procedures could be an issue, if they wrote the procedures. Validate them, don't wait and see, get the evidence of validation on file so you have it before you need it.
Records are always an issue, so check the records yourself and have your internal auditor check them since they are basically running your lab, in spite of the terms considered thus far.
Hope this helps.
Helmut Jilling
Auditor / Consultant
#15
If they were former employees, and were competent to do this work, and continue to use your standards and such, it might make sense to class them as contract employees and seek a solution in that fashion. Nowadays, employees, temps, independent employees...there are all sorts of payroll approaches. Who knows, pretty soon GM might have just independent assembly contractors working onsite.
F Calibration Issue - Continuous Temperature Monitoring System was not Acceptable General Measurement Device and Calibration Topics 7
M Accredited Calibration Sevice Provider using computerized system to issue calibration certificate Qualification and Validation (including 21 CFR Part 11) 3
M Accredited Calibration Sevice Provider using computerized system to issue calibration certificate General Measurement Device and Calibration Topics 2
G ISO 9001 and ISO 17025 - Measuring tools not in calibration system General Measurement Device and Calibration Topics 3
W Equipment for Oven Calibration, Uniformity and System Accuracy Tests AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
Gman2 The current state of our Calibration System General Measurement Device and Calibration Topics 28
A Calibration system must meet ISO 10012, ISO 17025 or ANSI/NCSL Z540? ISO 17025 related Discussions 38
H Measurement System in Control if the Equipment requires Daily Calibration? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
R Incorporating New Electronic Test Equipment into our Calibration System Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
J AS9100C Calibration System Compliance Requirements General Measurement Device and Calibration Topics 8
S QMS (Quality Management System) and Calibration Procedure ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
W Calibration Register - Traceability - Data Transfer to a New System General Measurement Device and Calibration Topics 7
3 Vision System Optical Calibration Standard General Measurement Device and Calibration Topics 6
M Druck DPI 620 Advanced Modular Calibration System General Measurement Device and Calibration Topics 1
AnaMariaVR2 Laboratory Equipment Quality System - Calibration, Maintenance and Inspection Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 10
S Do you include Penetremeters used in Radiography in your Calibration System General Measurement Device and Calibration Topics 2
T System Calibration vs. Component Calibration Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
R 3 Wire Thread Measuring System - Gage Calibration General Measurement Device and Calibration Topics 8
D Looking for a "User Friendly" calibration system software package Calibration and Metrology Software and Hardware 18
M Constant for thread gage calibration with the three wire system General Measurement Device and Calibration Topics 7
A TS16949 Calibration system - Concerned with Qualification of Administrator. IATF 16949 - Automotive Quality Systems Standard 3
K TS 16949 Calibration System Audit - What questions will they ask me? General Measurement Device and Calibration Topics 11
J Advice on Handling a Camera Vision System Calibration Master General Measurement Device and Calibration Topics 7
M How to implement a proper Calibration System? General Measurement Device and Calibration Topics 5
C Vision System which verifies the correct part is present - Calibration / Verification Calibration Frequency (Interval) 9
H Employee owned gages not entered in calibration system - AS9100 Clause 7.6 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
F Digital Multimeter - Verification vs. Calibration MSA (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
V Poke Yoke Gage Calibration - Do you have them in your calibration system? General Measurement Device and Calibration Topics 8
D Calibration - Out of Tolerance - Trace Back System General Measurement Device and Calibration Topics 1
M Calibration System - Finding Product Made with Out of Tolerance Torque Drivers General Measurement Device and Calibration Topics 7
J UPS owned shipping carton weight scales - Include this in my Calibration system? General Measurement Device and Calibration Topics 9
J Should weigh count scales be in the Calibration System? QS-9000 - American Automotive Manufacturers Standard 4
J Do Process gauges need to be in Calibration control system? QS-9000 - American Automotive Manufacturers Standard 2
I Calibration Items - Necessary to include the hand crimp tools into the system? General Measurement Device and Calibration Topics 10
lanley liao Question regarding the calibration of monitoring and measure equipment. Oil and Gas Industry Standards and Regulations 0
N IATF Calibration Lean in Manufacturing and Service Industries 4
Q Do these certificates of calibration meet ISO 9001 requirements for traceability to NIST? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
E Calibration Records needed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
D Limited Range Calibration - 5000 lb Industrial floor scale General Measurement Device and Calibration Topics 3
D Calibration of Small Scales General Measurement Device and Calibration Topics 26
I IQOQ or just initial calibration required? General Measurement Device and Calibration Topics 3
B Calibration in real life ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Ron Rompen Calibration by manufacturer ISO 17025 related Discussions 4
