This is completely out of my area of expertise but a quick google brought up the manual with a calibration section that has this:
"4. Maintenance
[FONT=Arial,Arial][FONT=Arial,Arial]4.1 Periodic calibration check
[/FONT][/FONT][FONT=Arial,Arial][FONT=Arial,Arial]
[/FONT][/FONT][FONT=Arial,Arial][FONT=Arial,Arial]Both the Pt 100 RTD temperature sensor and associated electronics are very stable and should not require any calibration after the initial factory adjustment.
Long term stability of the ROTRONIC Hygromer humidity sensor is typically better than 1 %RH per year. For maximum accuracy, calibration of the HL20 should be verified every 6 to 12 months. Applications where the data logger is exposed to significant pollution may require more frequent verifications.
[/FONT][/FONT]Note:
[FONT=Arial,Arial][FONT=Arial,Arial]Calibrating and adjusting the data logger typically require a humidity-temperature generator or other specialized equipment that may not be available to all users.
[/FONT][/FONT]Procedure for adjusting the data logger with the ROTRONIC HW4 software:
[FONT=Courier New,Courier New][FONT=Courier New,Courier New]o [/FONT][/FONT][FONT=Arial,Arial][FONT=Arial,Arial]Use cable AC3006 to connect the service connector of the data logger to the USB port of a PC with the ROTRONIC HW4 software installed. Note that the ROTRONIC USB driver must be installed on the PC as explained in the HW4 manual [/FONT][/FONT]E-M-HW4v3-Main
[FONT=Courier New,Courier New][FONT=Courier New,Courier New]o [/FONT][/FONT][FONT=Arial,Arial][FONT=Arial,Arial]Start HW4 on the PC and search for the data logger (HW4 Main Menu Bar > Devices and Groups > Search for USB Masters).
[/FONT][/FONT][FONT=Courier New,Courier New][FONT=Courier New,Courier New]o [/FONT][/FONT][FONT=Arial,Arial][FONT=Arial,Arial]After finding the data logger with HW4, expand the device tree to see the data logger functions. Select [/FONT][/FONT]Probe Adjustment[FONT=Arial,Arial][FONT=Arial,Arial].
[/FONT][/FONT][FONT=Courier New,Courier New][FONT=Courier New,Courier New]o [/FONT][/FONT][FONT=Arial,Arial][FONT=Arial,Arial]For further instructions see HW4 manual [/FONT][/FONT]E-M-HW4v3-A2-001 "
