Can a Attribute Study be considered a Visual Inspection?
RookieQuality
My co-worker decided to update our Gauge R&R procedure to include visual inspection criteria. "All visual inspection is classified as attribute gaging. To comply with this method, employees shall be required to pass a visual inspection quiz to ensure they are qualified to make pass/fail judgments. "
Is a visual inspection quiz considered an attribute study, if the quiz only contains 10 or so questions?
Well ‘study’ covers many situations...in this case your Customer requirements - if any - might matter, if they specify certain study designs,
A typical ‘attribute’ study would involve many parts that were good, bad and several at the ‘cutoff’ limit to truly challenge the inspector’s ability to discriminate between marginal parts. The inspection may also be performed at the expected speed during normal inspections. The study is also performed twice with the run order of parts randomized between the two tests.
10 seems really small and inadequate for a study that is truly insightful.
A bit of clarification may help: what are the ‘questions’?
RookieQuality
The questions are multiple choice. The questions consist of a picture of a noticeable defect and the operator has to choose the correct answer "defect description". I've informed my co-workers that these "quizzes" are competency test, not attribute studies. My goal is to remove the quizzes from our procedure. I don't think these quizzes meet an attribute criteria?
ah OK.
you are correct that 'quizzes' do not meet the intent of an 'attribute gage' measurement system study. (or attribute gage R&R).
not sure that they are useless tho. quizzes are like calibration. they can be a good first screen...
Repeated readings of many good, marginal and bad pieces is a measurement repeatability and reproducibility study....
optomist1
A Sea of Statistics
shouldn't the question be re-phrased; "can a visual inspection be construed to be or fulfill the requirements of an Attribute Study/Survey"?
AMIT BALLAL
The questionnaire can be used to test knowledge, but cannot be considered as an attribute MSA study. You can do a Kappa study.
The OP correctly phrased their question given his original and subsequent explanation of his situation. He/she could have more completely stated their question by reiterating that they were asking about the suitability of a quiz as a “Attribute Gage R&R Study for visual inspection”.
Your statement is off a bit. Visual inspection is a form of “Attribute gaging” and a attribute gage R&R (or attribute measurement system study) is used to determine the repeatability and reproducibility of the visual inspection process...in order to execute these studies the inspector does visually inspect good, marginal and bad parts at least twice.
K IATF & Attribute Study requirements IATF 16949 - Automotive Quality Systems Standard 9
A Does an attribute study (Go/NoGo pin gage) need two studies (1 for each pin) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
B Attribute Gage R&R study according to "Charbonneau" Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
V Minitab - Attribute Gage Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
S Visual Inspection Galvanized Attribute Study Quality Tools, Improvement and Analysis 2
K MINITAB 16 - Attribute gage study (Analytic method) and Gage R&R Study (Expanded) Using Minitab Software 2
S Cross Tab Attribute Gauge Study form Excel .xls Spreadsheet Templates and Tools 3
V MSA Attribute Data Analysis Study IATF 16949 - Automotive Quality Systems Standard 1
Manix MSA - How to Approach a Gauge R&R Go/NoGo Attribute Study Statistical Analysis Tools, Techniques and SPC 2
A Inspection Capability Study (Kappa Analysis / Attribute R&R) as Certification Req't Training - Internal, External, Online and Distance Learning 7
Rameshwar25 Acceptance Criteria for Attribute MSA Study Effectiveness Summary Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
S What is a Reference Value and how can we find it for Attribute Study? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
J Attribute Data and Capability Study of Holes in Parts Capability, Accuracy and Stability - Processes, Machines, etc. 11
J Gage R&R Study by Attribute (ACCEPT-REJECT-INVESTIGATE) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
V MSA (Measurement System Analysis) Doubt on Analytic Method (Attribute Study) IATF 16949 - Automotive Quality Systems Standard 8
M Procedure for Attribute R&R Gage Study?? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
B Visual Inspection - Capability Study on Attribute Data Capability, Accuracy and Stability - Processes, Machines, etc. 13
B Attribute Measurement System Study on Aesthetic Characteristics Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
J Attribute R&R Study for 10 Operators - .xls Excel form or advice wanted Excel .xls Spreadsheet Templates and Tools 5
P Attribute Gage Study using MiniTab Using Minitab Software 2
T Wind Turbine Blade Attribute Gage R&R Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
S Separate attribute MSA study required for each Go/No Go gauge? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
C Attribute MSA Study using Kappa - Why Kappa value is low Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 13
A MSA - Is an attribute study required for visual inspection? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
D Attribute Gage R&R study - Automatic machine that tests for a particular feature Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
A Do we need to perform Stability, Linearity & Bias study for Attribute data? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
O Attribute MSA Study Requirements? Marginally good & marginally bad with good & bad Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
J How to do attribute data GR&R (Gage R&R)? Do a Kappa study or follow the MSA book? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
Ron Rompen Attribute Gage Study Assistance - Drop gauge - 2 gauges, used by 4 operators Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
Z Simple assembly service - How could we do process study? Attribute data Statistical Analysis Tools, Techniques and SPC 1
O Standard "bogey" parts for an attribute study with 50 parts / 3 people / 3 times Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
C Is X-Ray Data Variable or Attribute? How to do a capability study? Statistical Analysis Tools, Techniques and SPC 3
B Ford Specific Attribute Gage Study - 50 samples, 3 trials, 3 ops - Spreadsheet Wanted Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 14
A GR&R (Gage R&R) - MSA - Section 6 Attribute Gage Study - Short Method Requirements Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
M Attribute MSA-CrossTab Study Example in MSA Manual:How to compute the Expected Count? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
Y Attribute Measurement Systems Study---Risk Analysis Methods & Analytic Method Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
J AIAG's MSA Manual 3rd Edition Attribute Gage Study - Calculating the UCI and LCI Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
T Attribute MSA-AIAG 4th How to calculate sample size IATF 16949 - Automotive Quality Systems Standard 12
T Destructive Attribute GR&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
Q Attribute MSA with limited test samples Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
PastorBee13 Attribute Gage R&R with no bad samples Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
P Comparing Two Test Variables Using Attribute Data Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
F Attribute sampling plan ISO 13485:2016 - Medical Device Quality Management Systems 7
D Question: How to analyze numerical and attribute data Reliability Analysis - Predictions, Testing and Standards 11
A Attribute , for example C chart Statistical Analysis Tools, Techniques and SPC 16
S MSA for attribute relation gage Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
I Overwhelmed with attribute MSA requirement for visual inspection IATF 16949 - Automotive Quality Systems Standard 11
A Attribute Analysis for colour matching scale Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
