Can a Fabless Semiconductor Company achieve TS16949 Certification (Registration)?
Hello All,
I'm trying to find out if a fabless semiconductor company, one without any in-house manufacturing capability, (front end, back end and ATE capability), can acheive TS16949 certification?
I've managed to trace a few fabless companies that have TS16949 (parrot, SSSL & xilink) however they all have some form of manufacturing capability, usually production ATE.
Is anyone aware of, or has TS certified, a wholly fabless company?
Thanks,
Nathan
Sidney Vianna
Post Responsibly
Re: Can a Fabless Semiconductor Company acheive TS16949 Certification (Registration)?
Hello All,
Thanks,
Nathan
Nathan, I don't believe that a fabless organization is eligible for TS-16949 certification. By definition, only MANUFACTURING sites are certifiable to TS. An organization that assembles ATE's should not be certifiable to TS either because ATE's are not automotive products, such as production or replacement parts.
My 3 million lire or 4.7 billion yens.
:2cents:
V
vanputten
I am familiar with at least one fabless organization that is TS 16949 certified. Since TS allows for outsourcing of any process, they can be TS 16949 certified. Even though the manufacturing is outsourced, the organization is still responsible for the outsourced process.
This is a sticky point with TS that I have never understood. Outsourcing is allowed. The outsourced process is still the reponsibility of the organization. But if you outsources a Product Realization process, then you cannot get a TS certification? Doesn't make sense to me. The organziation is still responsible.
Regards,
Dirk
V
vanputten
By the way, when you say "production ATE", do you mean ttat the organizaiton in question does automatic testing of the semiconductors?
Do you consider electrical test of product "manufacturing?" The organzition that I am familair with only tests and ships semiconductors. All other processes are outsourced. They are TS certified.
Personally, I don't see testing as "manufacturing."
Regards,
Dirk
cheahga
Fully agreed with Dirk & Sidney that "Testing" is not manufacturing process which does not add value to the manufacturing process per TS definition.
Read the attachment on the last column on TS & semiconductor industries...
I still wonder how those fabless or testing house industries ever get certified with so called under scruntinization of IATF under the application scope ......:confused:
jeffrey_Chang
:confused:
I do not concur to the fact that final test does not add value to the manufacturing process. As a matter of fact, I view it as part of the value stream. IC final test is about ensuring that the product are performing and complying to its design intent. Without such test, how can one be sure that the product is functioning as design.
As to obtaining TS certification for testing house as mentioned, sorry not sure about fabless, so long as you have customers from the automotive industry, you can be certified to TS.
thks.
jeffrey.:)
Sidney Vianna
Post Responsibly
No sir. That is BAD advice.
Question: Which Organizations can obtain Certification/Registration to ISO/TS 16949:2002?
Answer: Any Organization in the Automotive Supply Chain meeting the criteria below can obtain Certification to ISO/TS 16949:2002
1. Scope 1.1 General
- This Technical Specification, in conjunction with ISO 9001:2000, defines the quality management system requirements for the design and development, production and, when relevant, installation and service of automotive-related products.
- This Technical Specification is applicable to sites of the organization where production and/or service parts specified by the customer are manufactured.
2. "Automotive" shall be understood as including the following:
- Cars, Trucks (Light, Medium and Heavy), Buses, Motorcycles
3. "Automotive" shall be understood to exclude the following:
- Industrial, Agricultural, Off-Highway (Mining, Forestry, Construction, etc.)
4. 3.1.11 "Site"
- Location at which value added manufacturing processes occur.
5. “Manufacturing”
- Process of making or fabricating:
· Production materials
· Production or service parts
· Assemblies, or
· Heat treating, welding, painting, plating, or other finishing services
jeffrey_Chang
Thks Sidney,
I do have a question "How do you define value added manufacturing processes?" Is 100% final testing a value added process?
What I'm trying to say here "if you have customers in the automotive industry, you can be certified to TS" is that if you have an automotive customer, you should be providing some form of "value added" services or manufacturing content to them, as such, you should be meeting the requirements as stipulated above.
Again, my question here is if I'm a testing house for a automotive customer, can I be certified? If not, then I think it is time I should fire the TS/ISO consultant.
thks.
jeffrey.
Thanks for the inputs.
In response to some earlier queries. Yes ATE is final electrical test and is the final inspection/verification point.
As I understand it the production test is an inspection gate.
Therefore an NVA process (much like in line QA inspections) as we are inspecting and rejecting product defects introduced by the manufactuiring process.
According to TS this cannot be adding value (even though it classes as a finishing service) therefore TS certification on the back of a test servide is not possible.
Am I missing something?
Thanks,
Nathan
Just had another thought (dangerous I know).
Are tape and reel, dry-packing and labeling classed as value added manufacturing (e.g. finishing operations)?
If so, then a test house can be certified.
Or as these processes are essentially packaging steps are they exempt from the manufacturing process as far as TS is concerned:confused: ?
Comments?
Thanks,
Nathan
N TS16949 Quality manual for a fabless semiconductor company Quality Management System (QMS) Manuals 0
N ISO 9001 Implementation - Fabless Semiconductor (ASIC) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
G Choosing a Sampling plan for Start Up Fabless IC Company - Guarantee a 200 DPM limit Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
Y DFMEA Sample in Semiconductor FMEA and Control Plans 2
K What are the current ISO/ TS 16949 Semiconductor Manufacturer Requirements IATF 16949 - Automotive Quality Systems Standard 12
L FMEA Rankings for Semiconductor Products FMEA and Control Plans 9
H How is a Semiconductor / Electronic Part Manufacturing APQP and PPAP 1
I Should chemical use within a semiconductor facility be an aspect? ISO 14001:2015 Specific Discussions 2
S Can enclosure of semiconductor or electrolytic capacitor provides basic insulation? IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
Q Semiconductor Inductor Failure - Will HAAS/HALT or any other test detect it? Manufacturing and Related Processes 4
R Semiconductor Reliability Testing for System - Operating Life Test Reliability Analysis - Predictions, Testing and Standards 11
A Cleanroom class in semiconductor Other ISO and International Standards and European Regulations 8
T Mil Std Certification for a Semiconductor Burn-In Process provider Various Other Specifications, Standards, and related Requirements 2
Q Definition Excursion - Semiconductor, Definition for Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 4
Jen Kirley Cleanroom Standard for Semiconductor Fabrication Wanted Various Other Specifications, Standards, and related Requirements 3
R TS Certification Scope - Semiconductor subcontractor providing assembly and testing IATF 16949 - Automotive Quality Systems Standard 14
A Supplier Quality Management Strategies - Semiconductor Assembly and Test Services Supplier Quality Assurance and other Supplier Issues 6
antoine.dias What are the current automotive semiconductor requirements? IATF 16949 - Automotive Quality Systems Standard 2
K Predictive Quality Indicators - Manufacture of semiconductor optoelectronic products Quality Tools, Improvement and Analysis 2
D Should the clean room be called a laboratory? Semiconductor industry IATF 16949 - Automotive Quality Systems Standard 7
Q Defunct SAC (Semiconductor Assembly Council) Standards Various Other Specifications, Standards, and related Requirements 11
Q FMEA for Inspection and Test required by TS 16949? Semiconductor Sector FMEA and Control Plans 6
D Is Wafer Probe (On Wafer Test) a Laboratory? Semiconductor Industry IATF 16949 - Automotive Quality Systems Standard 8
Q Concerning Special Characteristics Interpretation - Semiconductor commodity standard IATF 16949 - Automotive Quality Systems Standard 3
W ISO/TS16949 Certificate Withdrawn by CB - Burn-in services to semiconductor companies IATF 16949 - Automotive Quality Systems Standard 7
C Semiconductor Subcontractor Quality System Supplier Quality Assurance and other Supplier Issues 6
D Gage RR to train operators? QS-9000 Semiconductor Supplement 4.11.4.S Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
X Modeling and Analysis of Semiconductor Manufacturing (MASM) Conference Statistical Analysis Tools, Techniques and SPC 3
R Is Gage R&R with measurement data possible in a Semiconductor Fab? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
V TS 16949 Semiconductor Supplement Status - Obsolete? IATF 16949 - Automotive Quality Systems Standard 1
V Semiconductor Supplement to TS 16949 - Is the Semiconductor Supplement obsolete? ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 24
C Semiconductor Commodity Supplement 7.3.2s - Leadframe for semiconductors Customer and Company Specific Requirements 0
W Is the AIAG's Automotive Semiconductor Supplement Obsolete?? IATF 16949 - Automotive Quality Systems Standard 10
D First Pass Design Success - TS 16949 Semiconductor Supplement Design and Development of Products and Processes 5
Raffy SAC - Semiconductor Assembly Council General Auditing Discussions 1
J Looking for FMEA software for Semiconductor Industry Quality Assurance and Compliance Software Tools and Solutions 5
M Traceability - Semiconductor supplement QS-9000 - American Automotive Manufacturers Standard 14
W Semiconductor supplement General Auditing Discussions 4
A PMS and reportable incidents for company that outsources manufacturing? ISO 13485:2016 - Medical Device Quality Management Systems 2
A Small Company Implementing ISO 13485 Timeline/Process/Steps Advice ISO 13485:2016 - Medical Device Quality Management Systems 5
C ISO Certified Company ERP implementation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
S Pros and cons to transition to AS9100 for non aerospace company AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
L ISO13485:2016 and Subsidiary Company ISO 13485:2016 - Medical Device Quality Management Systems 4
M Does any one know if company is allowed to submit appeal for rejected registration file Other Medical Device Related Standards 0
T Company AS9100D External Audit Preparation AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 17
E Device compatibility with other company's devices US Food and Drug Administration (FDA) 0
M An interesting question about import company Other Medical Device Regulations World-Wide 5
T ISO9001:2015 for Work-from-home company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 48
M Role of Quality Manager in a manufacturing company AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
R How many process maps are adequate for a company for IATF 16949? Process Maps, Process Mapping and Turtle Diagrams 17
