Can a fail still be a pass? (Criteria Level B for 61000-4-6 Conducted Immunity)
qu1nn
My company has been trying unsuccessful in passing precompliance testing conducted immunity (61000-4-6). We are prepping up for our 3rd attempt.
The product is an electronic weight scale the stated accuracy in the manual is 0.2% . The output is a LCD display showing weight.
During the conducted immunity testing the output of the scale went well outside the stated accuracy. After the test no intervention is required (the displayed weight error goes away when the test is complete) thus, the degradation of performance ceases after the disturbance ceases and there is full recovery to normal performance, without operator intervention.
Is it possible to fail the conducted immunity testing (Criteria Level A) at various frequencies but yet still be able to move forward by utilizing Criteria Level B?
where
Criteria level A: normal performance withing equipment specifications
Criteria level B: degradation or loss of function or performance which is self recoverable when the interfering signal is removed.
Criteria level C: degradation or loss of function or performance that requires system reset or operator intervention when the interfering signal is removed.
It sounds straight forward.... (thus written into the spec, thus in answering my own question .... YES)...
I am assuming that it would have to be clearly stated in the Guidance and Manufacturers Declaration contained in the manual....
Are there any pitfalls that I should watch out for if going with Criteria Level B that I am missing?
I look toward your response,
qu1nn
Peter Selvey
I guess these are medical scales, so you are looking at IEC 60601-1-2.
In theory the EMC immunity levels are intended to represent the "normal environment", so there should be no degradation.
Lets say the scales also need to be waterproof, as the intended purpose requires use while the patient is wet (for whatever reason). It would not be acceptable if the accuracy of the scales went outside of spec during the waterproof test, even if it returned to specified accuracy after being dried out.
In principle it is the same for EMC.
The difference with EMC is that in reality the type and nature of electrical noise is so wide and varied, so the tests try to simulate this with a wide range of frequencies, amplitude modulation and direction of the EM field.
So there is two broad possibilities: one is that your design is really poor and there are a lot of EM field conditions that cause problems. In this case, it really is hard to justify Criteria B. If during the whole tests the scales showed an error, it makes no sense. They are basically useless in the real world.
Another possibility is that it just happens that a particular frequency, modulation or field direction that resonates with your sensor circuit and causes an error result. In this case, Criteria B can make sense if the severity is low and probability is low. Good design would be to at least look into the problem and try to understand the cause and effect. For example, it may be that some sensor types unavoidably show errors with certain EM field conditions, but these conditions are relatively rare.
Simply taking a fail result, and automatically switching from Criteria A to Criteria B would not fit with the fundamentals of risk management.
J Can a Surge test fail to a test level and still considered as Compliant? IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
N Voltage Doubler fail - can gas tubes be used? IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
P NCMRs on in-proccess rejections - Products that fail during assembly ISO 13485:2016 - Medical Device Quality Management Systems 2
J AMS 2750 E Clause3.5.17.13 TUS Pass/Fail Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
Z Inspection Form With Pass/Fail Formula Excel .xls Spreadsheet Templates and Tools 11
S ISO 9001:2008 Lead Auditor Exam Fail - How to follow up? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
L Find the right Test to fail method according to the standards of LV 124 FMEA and Control Plans 1
C Difference between "Pass/Fail Testing" "Test To Failure" "Degradation Test" FMEA and Control Plans 1
Gman2 Give it to me straight - We are going to fail our TS 16949 Re-Certification Audit IATF 16949 - Automotive Quality Systems Standard 11
S Fractional cycle fail in Eto sterilization validation ISO 13485:2016 - Medical Device Quality Management Systems 3
S ISO 9001:2008 Sec 7.6 - Can we just log measurement devices as 'Pass/Fail'? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 118
S Verify Software System Testing: Verify that results meet the Pass/Fail Criteria IEC 62304 - Medical Device Software Life Cycle Processes 1
B Shall issue CAR when KPI fail? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
A Why Copper Wirebonded Devices often fail at uHAST (130C, 85%RH, 96hrs) Nonconformance and Corrective Action 2
J Reliability Prove-out, Pass-Fail Testing Reliability Analysis - Predictions, Testing and Standards 2
I Supplier Using Reference Part for PASS/FAIL Inspection Supplier Quality Assurance and other Supplier Issues 8
Hami812 Gage R&R on Automated Tool that supports Pass/Fail and some Parametric Testing Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
Hami812 Gage R&R Process Method - Pass/Fail Criteria Offered to Operators vs. Parametric Data Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
Sidney Vianna Why do so many ISO 9001 Implementation Programs Fail? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 171
G Hoffman Scratch Hardness Test - General Parameters for Pass/Fail (Paint Coatings) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
K False Pass/Fail Information from GR&R (Gage R&R) Minitab Using Minitab Software 6
I Service Supplier Rating where Objective Pass/Fail Data is not Available Service Industry Specific Topics 7
M Top Three Reasons why TPM (Total Productive Maintenance) Initiatives Fail Manufacturing and Related Processes 39
D Cytotoxicity testing to ISO 10993-5 results - Is 1/ mild a pass or fail? Other Medical Device Related Standards 7
A Gage Reproducibility & Repeatability for POKA-YOKE (pass/fail) gage? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
M PVC balls fail out laquered process drying Manufacturing and Related Processes 3
goofygiggler What it looks like to fail... Funny Stuff - Jokes and Humour 0
Marc German Engineers Fail the Paternity Test World News 4
P Fail with Flair Funny Stuff - Jokes and Humour 11
R Quality Management System not active for 6 months. Registration let it Lapse or Fail? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
J Unilateral Gage R&R (GR&R) - Minitab 13 - Does this study pass or fail and WHY? Using Minitab Software 17
D Gage R&R On Pass Fail Gauge - Photograph Analysis Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
T Return to Vendor processes - Supplier parts which fail incoming inspection Supplier Quality Assurance and other Supplier Issues 5
C Question Regarding MSA (Measurement Systems Analysis) - Pass / Fail Criteria tests Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
S Why Does a Thread Plug No Go Gage Mean Fail? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
J How to deal with operators who fail to follow work instruction? Misc. Quality Assurance and Business Systems Related Topics 52
I How many fail ALL ISO 9001 registration audits - How many never make it? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 46
Marc Did QS-9000 Fail? If so, Why? QS-9000 - American Automotive Manufacturers Standard 16
R Management & Internal Audits (Oil & Water?) Audits as a pass/fail test Internal Auditing 19
A Will A Customer Complaint Cause Us To Fail Registration? Customer Complaints 5
B Continuous Improvement Tools - Why do continuous improvement efforts fail Preventive Action and Continuous Improvement 18
D Hostile Assumptions - 7 out of 10 organizations which attempt to implement TQM fail Preventive Action and Continuous Improvement 24
Tagin Hosting in the cloud still requires DR (OVH fire) Business Continuity & Resiliency Planning (BCRP) 1
S Are EC type examinations still being conducted under MDR? EU Medical Device Regulations 5
N What is our product classification? (Does Unclassified classification still exists) Other US Medical Device Regulations 14
E Can we still use MEDDEV 2.4/1 rev. 9 when classifying a medical device product under MDR? EU Medical Device Regulations 4
H Can a calibration lab still use ISO 6789:2003 as guide for torque calibrations Other ISO and International Standards and European Regulations 1
S IMDRF or still GHTF for STED and other guidance? Other Medical Device and Orthopedic Related Topics 5
