It depends on the dimension you are looking for. I've had some luck getting the minor diameter by scanning against the pitch and using some filters but if you are looking for the PD, you're most likely out of luck. Perhaps with a custom probe set to the size of the ball you'd use, careful helical scanning, and some programming tricks to find the center of the thread you could get there but I wouldn't trust it.
