Can automatic machine testers be subject to GR&R?
WEAVER
Hi what type of msa should we use on automatic ic testers attached to machine? is it possible to use gr&r?
if so,what would represent appraiser variation?:bonk:
bobdoering
Stop X-bar/R Madness!!
My preference is to do an attribute gage r&r on testers. Their goal in life is simply to determine if a part is good or bad, and provide virtually no information on process adjustment or control. Variable gage R&R, therefore, is overkill. Therefore a 50 pc study replicated over 3 operators (or 9 replicates if only one operator with no operator influence on results from loading and unloading - using "time" an "operator" using time gives you stability, too) and do kappa study. 25 pcs targeted to have detectable defects that the machine looks for as a part of the 50 pc. study.
V
vince c
the automatic tester only have repeatability, so the type 1 gage study is suitable, just need one part and one operator, repeat measuring 20 times minimum, then calculation repeatability% by Minitab.
J The appropriate Attribute MSA for Automatic Visual Inspection Machine Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
S Gage R&R analysis for a fully automatic machine Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
K GR&R for an Automatic Optical Inspection Machine (AOI) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
D Attribute Gage R&R study - Automatic machine that tests for a particular feature Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
T Need supplier for automatic thread inspection go / no go machine Supplier Quality Assurance and other Supplier Issues 3
D MSA for Attribute data - Automatic Hy-pot test machine Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
R MSA for ATE (Automatic Test Equipment Embedded Software) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
M Automatic Data Gathering Requirements and Privacy Implications Medical Information Technology, Medical Software and Health Informatics 0
G GR&R in A.T.E. (Automatic Test Equipment) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
P MSA on an in-line automatic X-ray thickness measuring gage Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
S Design Standards for Automatic Fare Collection System Various Other Specifications, Standards, and related Requirements 2
O IEC 61010-1 Ed 2: "Automatic Disconnection of the supply" CE Marking (Conformité Européene) / CB Scheme 3
D Back to Back MSA - Two "identical" automatic measuring systems Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
P Change the way you think about SPC - Automatic Data Collection Statistical Analysis Tools, Techniques and SPC 8
N Does OHSAS 18001 require organization to have AED (Automatic External Defibrillator) Occupational Health & Safety Management Standards 4
I ADR (Automatic Data Recorder) Calibration Requirements Calibration and Metrology Software and Hardware 2
E MSA for criteria Automatic Video Measurement Systems Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
S Smartphone based software with automatic "rating" from remote servers Medical Information Technology, Medical Software and Health Informatics 4
F CMM Scanning Feature Delays - Brown and Sharpe automatic CMM using PC-DMIS CAD 4.3 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
L MSA in Automatic Equipment - PCB Assembly - Help! Quality Tools, Improvement and Analysis 6
W Is a Non-Automatic Weighing Instrument a Medical Device? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
optomist1 GD&T Flatness Automatic Indirect Control Rule #1 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 20
B Conducting a study on Hexagon Nuts "turned" on a multi-spindle automatic lathe Statistical Analysis Tools, Techniques and SPC 9
B Attribute MSA for Visual Inspection via Camera Automatic Inspection Tool Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
P Gage R&R with ATE (Automatic Test Equipment) - Newbie here... Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
B Attribute MSA of Automatic Inspection Equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
K Gage R&R's on automatic gages with robots Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 18
B What local standards are needed for ISO 9001 - Automatic doors ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
S How to carry out Gage R&R for automatic machines? Automated Equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 22
K MSA for Steam Autoclave Automatic Controller and Measurement System Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
Z Supplier of Automatic Gaging Systems need to be on our Approved Supplier List? IATF 16949 - Automotive Quality Systems Standard 6
Q Over sampling - Product on an automatic line with a predetermined lot size Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
J Reproducibility error between instruments for automatic measuring equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
I ATE (Automatic Test Equipment) "Gage" process for electronic modules? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
G GR&R on automatic equipment such as a CMM - Do you still have to use 3 operators Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
B Gage R&R for Automatic Test Systems - No operator influence on readings Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
C Need 3 appraisers for GR&R (Gage R&R) of Automatic Test Measurements? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
S Determining MSA Bias in Automatic Test Equipment for Electronics Modules Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
A Gage R&R with ATE (Automatic Test Equipment) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 15
J How & how often to perform verification of Test Software of Automatic Test Equipment? General Measurement Device and Calibration Topics 3
Z Control Charts and sample size for automatic measurement Statistical Analysis Tools, Techniques and SPC 1
Jerry Eldred Gauge R&R studies for Automatic Gages and Test Equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
E Tensile test machine, tinius olsen 602 Manufacturing and Related Processes 1
M Class II type machine , and its compliance with 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 14
S Any ISO standards around Artificial Intelligence and Machine Learning? Medical Information Technology, Medical Software and Health Informatics 4
K Machine Capability Capability, Accuracy and Stability - Processes, Machines, etc. 2
H Software Validation for FFS Packaging Machine Qualification and Validation (including 21 CFR Part 11) 1
K Regulatory requirement of SaMD with machine learning component IEC 62304 - Medical Device Software Life Cycle Processes 3
