Can calibrated device values be used instead of manufacturers spec?
greif
We use a calibrated thermometer (cal done at several points near our usage points) to report the temperature at which a linear dimension was measured.
One opinion is that the accuracy of this thermometer is only considered accurate to the tolerance stated on the cal report (the mfg. Specs)((1.8 F)
My opinion is that it is accurate to what the cal lab found the error to be (reading verses cal reading, plus the cal lab stated uncertainty. ( around 0.5 F).
What are your opinions?
Thanks!
dwperron
When you are using a manufacturer's specification you are assuming that the instrument is capable of maintaining the published accuracy over some period of time. That is based on the OEM's knowledge of the design process, component choices, their internal testing, etc. that went into the building of it. OEM's also tend to be conservative in their specifications, allowing for some drift while retaining published accuracies.
When you take a series of measurements you are taking a snapshot of the instrument performance. You really do not have the expertise to extrapolate that data into a new, more aggressive set of specifications. Maybe if you conduct a study for repeatability, reproducibility, stability, etc. under a range of environmental conditions then you could make a valid claim to some "limited" calibration with tighter specs.
Thanks!
example: some digital temperature controllers handle the least significant digit (LSD) + the tolerance of the indication
This LSD: the manufacturer does it to contemplate the conditions, the temperature conversion, the measurement scales, etc.
look for something similar in the manufacturer's manual,
regards,
J Calibration Justification - Requirements for Measurement with a Calibrated Device General Measurement Device and Calibration Topics 1
D Interesting Discussion Using "Not A Calibrated Device" or "No Calibration Required" stickers General Measurement Device and Calibration Topics 63
J Gear Surface Finish - Print with the word "calibrated" Manufacturing and Related Processes 2
M What kind of instrument that must be calibrated? General Measurement Device and Calibration Topics 3
M Where to obtain a calibrated DICOM image? ISO 13485:2016 - Medical Device Quality Management Systems 1
Q Calibrated Equipment Managment Software Suggestions General Measurement Device and Calibration Topics 12
O Storage of Calibrated Tools General Measurement Device and Calibration Topics 12
I Uncalibrated source to calibrated meter, then compare to UUT General Measurement Device and Calibration Topics 4
K Looking for Calibrated Tool Shadowboard Substrate Ideas AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
N Calibration Traceability - Fluke 753 dpc with thermocouple Calibrated by Fluke ISO 17025 related Discussions 4
T Auditor states my Oven Thermocouples must be Calibrated General Measurement Device and Calibration Topics 18
L Should Air Screwdrivers be Calibrated? General Measurement Device and Calibration Topics 15
S Using Calibrated OD mic over non-Calibrated ID mic for final dimension Manufacturing and Related Processes 17
G Filling out inspection report using calibrated pins Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
P What are the uncertain digits of a 1/64" calibrated ruler? Measurement Uncertainty (MU) 6
M Establishing traceability from calibrated glassware to non calibrated ones General Measurement Device and Calibration Topics 5
M Auditor has requested that the granite table in the lab be Calibrated Calibration and Metrology Software and Hardware 19
B AS9100C 7.5.1 d and calibrated equipment in the production areas AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
M Need help with Network Analyzers and which DUT can be Calibrated with it Calibration and Metrology Software and Hardware 2
T New Equipments calibrated by Manufacturer need Calibration from Independent Labs? General Measurement Device and Calibration Topics 2
L Acceptance Criteria for External Calibrated Standards IATF 16949 - Automotive Quality Systems Standard 1
A Calibrated Surface Plates treated as General Use Tables General Measurement Device and Calibration Topics 9
N Is there a standard which states how often instruments should be calibrated? Calibration Frequency (Interval) 12
Chennaiite Is Design Verification Software required to be Calibrated IATF 16949 - Automotive Quality Systems Standard 7
L Can new guy use his Calibrated Tools? Calibration and Metrology Software and Hardware 12
C Measuring Equipment on Injection Machine should be Calibrated by 3rd party? General Measurement Device and Calibration Topics 21
Jerry Eldred Where to get UV Intensity Meter Calibrated General Measurement Device and Calibration Topics 3
C ISO 9001 Surveillance Audit Nonconformance - Thermometers not Calibrated General Measurement Device and Calibration Topics 117
Y Do Thermocouples need to be Calibrated? General Measurement Device and Calibration Topics 18
M Disposal of Calibrated Measurement and Test Equipment General Measurement Device and Calibration Topics 18
J Do desktop calendars need to be calibrated? General Measurement Device and Calibration Topics 31
D Calibration of Pin Gages using a Calibrated Caliper that measures to 4 decimal places General Measurement Device and Calibration Topics 15
H "Internal Calibration" using other Calibrated Equipment Calibration Frequency (Interval) 13
N Can a Calibrated Digital Thermometer be used to monitor my oven? General Measurement Device and Calibration Topics 12
Q Acceptance Procedure for Receiving Calibrated Equipment & Tools Document Control Systems, Procedures, Forms and Templates 13
hogheavenfarm Does anyone know of a calibrated Fillet weld gage? General Measurement Device and Calibration Topics 12
S Can Laser Alignment Tools be Calibrated General Measurement Device and Calibration Topics 7
G New gage calibrated at factory do I need the certificate? Calibration Frequency (Interval) 4
D Scales calibrated by an ISO 17025 accredited organization? TS 16949 requirement? ISO 17025 related Discussions 44
A Usage of Calibrated Equipment - Vernier Caliper Misc. Quality Assurance and Business Systems Related Topics 10
howste Condition of Item Calibrated - ISO 17025 Clause 5.10.2f - Calibration Certificate ISO 17025 related Discussions 13
5 Gage not calibrated to full use/range of the gage - Surveillance Audit - Calibration General Measurement Device and Calibration Topics 7
B Must a vernier caliper and a rule be calibrated according to ISO 9001? General Measurement Device and Calibration Topics 50
M Inhouse Calibration of Regulated Power Supplies (RPS) using calibrated Multimeter General Measurement Device and Calibration Topics 7
R How to define Acceptance criteria for Calibrated equipment before use AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
G Leak Tester Calibration - Sentinal C-20 controller with a calibrated orifice General Measurement Device and Calibration Topics 1
J CNC Calibration - What should be calibrated on a HAAS machine? General Measurement Device and Calibration Topics 7
V Traceability of Standards - Where can I send my standards to be calibrated? General Measurement Device and Calibration Topics 9
U Calibration House - Where I can get a PG 13.5 Gut thread ring gage calibrated? General Measurement Device and Calibration Topics 1
