Can FMEA's and CP's be process specific according to the PPAP handbook?
annd928
I have just received my QS 9000 certificate, as of 2/24/2000. Yet, Delphi pops in on friday to walk the shop with the control plans from 4 of there PPAP'ed parts. No problem. I am a heat treater, and we have created our fmea's and control plans to be process specific since we make no parts here. Our Auditors like the set up and thought it was value added for us to set it up this way. Delphi's Rep is not happy. He says that it states in the QS books that it must be part specific. I understand that they can request this "Section II", but he is saying he shouldn't have to, it is in the book. I am searching, He could not tell me which book. Any ideas for finding this statement, or for batteling this statement would be appreciated. We have over 500 Customers only 4 which require PPAP's if I have to create a Control Plan for every part we ever do... well we just could not do it. This way our operators can use them daily.
Al Dyer
You wrote:
"Yet, Delphi pops in on friday to walk the shop with the control plans from 4 of there PPAP'ed parts."
Did you bring up the point that the PPAP warrant had been approved, and therefore the contol plan had been accepted?
It would be hard to gig you when you hold an approved warrant.
Were there four distinct (part specific) control plans?
It sounds as though you have utilized a control plan for a family of like parts which is acceptable. I believe that as long as the part numbers appear on the "family" control plan there should be no problem.
Is Delphi asking you to change your system?
I think you need to determine which section of the manual they think you are not following.
If they couldn't give you the section of the maunual they believe you are noncompliant to, I think they need a refresher in auditing 101.
I hope you keep in touch (and register)with the forum and give us updates.
Good Luck!
ASD...
Marc
I have had clients deal with this by using a matrix which contained part numbers vs. process or simply putting multiple part numbers on the control plan.
Part specific control plans are silly when you can do it by family.
->I understand that they can request this "Section II", but
->he is saying he shouldn't have to, it is in the book.
So - you got an idiot a__hole for an auditor this time. Better luck next time.
It is also my understanding that you only have to have control plans to address automotive parts you make - not every part.
L
Laura M
Marc,
Unfortunately the "idiot" you refer to is the customer this time, and it may not go away as easy as the 3rd party - where they have formal complaint channels. My guess is the customer rep is either inexperienced, was told (notice I didn't say 'trained') to ask for a PCP for each part number, and then could not find his/her way out of a wet paper bag if it wasn't on the checklist.
I would have them site the clause they are referring to and what does Section II have to do with it? Did Delphi publish their own Section II customer specifics? Was it provided with contract review? Section 2 Customer specific requirements aren't at the whim of the auditor or even particular division of Delphi you may be working with. If they've published an equivalent the the B3 Section 2 requirements, I'd like to see it. I've asked periodically and come up empty.
A little punchy tonite, sorry.
Marc
->I would have them site the clause they are referring to
->and what does Section II have to do with it?
I agree. "Show me where it says that." is key. Thanks.
You are right "show me" is the best way to go. Before I do anything else for them I will find out where it is written. With regards to Section II, the original purchase order issued to us was from GM, they just amend it, this document requires Section II, we have to use GM's web site for our PRR's and in turn the GM 9000 manual is required(Auditor). Our Auditor believes Delphi to be Section II, and we are under the impression anyone can call it out. We also address Customer specifics in our system. We are preparing to say "no problem but there will be an additional charge", that may just do it.
J Process FMEA Template with examples - Cold and Hot Forged components FMEA and Control Plans 4
C FMEA Process assessment In the Draft for the AIAG/VDA FMEA Manual is gone FMEA and Control Plans 0
Jimmy123 Example of a P-Diagram for Process FMEA - Uncontrollable noises FMEA and Control Plans 39
eule del ayre Merging FMEA and Quality Control Process Flow FMEA and Control Plans 0
K AIAG/VDA FMEA & Process Control Plans FMEA and Control Plans 0
S New AIAG FMEA Process - How to complete the new format FMEA and Control Plans 32
D Where does FMEA fit in your ISO 14971 Risk Management process? ISO 14971 - Medical Device Risk Management 13
N Process FMEA Occurrence Ranking for New Process FMEA and Control Plans 3
G AIAG FMEA - Major customers of the FMEA process FMEA and Control Plans 3
E How do I create a FMEA for the Internal Audit process? Internal Auditing 11
D How to fill a Process FMEA - Three columns - Severity, occurrence and Detection FMEA and Control Plans 16
L Injection & Extrusion Process FMEA FMEA and Control Plans 1
S Pilot Process FMEA Occurence Rankings FMEA and Control Plans 4
K Process FMEA Ranking Table for for Landing Door of an Elevator FMEA and Control Plans 7
G Severity in Process FMEA for Rework Process FMEA and Control Plans 1
R Is PFMEA (Process FMEA) for OEM sufficient to address Risk? ISO 13485:2016 - Medical Device Quality Management Systems 7
H FMEA sample for complete CNC machining process FMEA and Control Plans 1
T Software for linking Process Flow Diagram, Process FMEA and Control Plan APQP and PPAP 9
V Process FMEA for Stamping Process FMEA and Control Plans 5
G FMEA for Steel Tube Process for Automotive FMEA and Control Plans 4
L Most appropriate Auditor to check the FMEA & PCP of a Manufacturing Process IATF 16949 - Automotive Quality Systems Standard 5
C List Error Proofing in the Process FMEA or the Control Plan FMEA and Control Plans 2
J Process FMEA w/ Contracted Manufacturing ISO 14971 - Medical Device Risk Management 2
B FMEA example for Cokemaking Process at a integrated Iron and Steelmaking Plant IATF 16949 - Automotive Quality Systems Standard 3
S FMEA Process Step or Current Control FMEA and Control Plans 3
Z Pass-Though Characteristics in PFMEA (Process FMEA) FMEA and Control Plans 2
Q Chrysler required FMEA and Control Plan Document Audit Forms and Process Audit Check FMEA and Control Plans 7
V Examples of Design and Process FMEA for Pharmaceutical Product Development ISO 14971 - Medical Device Risk Management 7
S Galvanize and Chrome Plating Process FMEA wanted FMEA and Control Plans 2
S Product FMEA vs. Process FMEA - Aerospace Industry Machine Shop FMEA and Control Plans 5
R PFMEA (process FMEA) for Incoming Material stage FMEA and Control Plans 7
P PFMEA (Process FMEA) Recommended Actions help FMEA and Control Plans 9
J What is Incorporation in Assembly/Manufacturing Process in FMEA? FMEA and Control Plans 4
A Will Inspection Process need an FMEA? FMEA and Control Plans 7
F Process FMEA for Welding and Laser Cutting FMEA and Control Plans 3
G Very Basic PFMEA (Process FMEA) Guidelines FMEA and Control Plans 17
R Process to use Special Characteristics as FMEA Inputs IATF 16949 - Automotive Quality Systems Standard 3
M PFMEA (Process FMEA) - What is the best approach? FMEA and Control Plans 14
F FMEA Optimization for our Die Setup Process FMEA and Control Plans 2
M PFMEA (Process FMEA) for Attribute Data Inspection Process FMEA and Control Plans 2
A Current Control Periodic Document Reviews - Process Updates in the FMEA FMEA and Control Plans 3
T PFMEA (Process FMEA) Recommended Actions Column FMEA and Control Plans 10
B Process FMEA (PFMEA) Same Multiple Causes for Different Effects FMEA and Control Plans 6
M Changing PFMEA (Process FMEA) RPN Values based on a Rejection FMEA and Control Plans 5
Chennaiite FMEA for Business Process Imported Legacy Blogs 6
K Does FMEA include Inspection Process? FMEA and Control Plans 11
Q Using a Custom Process FMEA (PFMEA) Form FMEA and Control Plans 4
H What should be included in a Machining Process FMEA? FMEA and Control Plans 8
